Old 11-28-2006, 06:27 PM   #26
kiwee
Member#: 119232
once you get over 300+whp you are playing with fire on the na2.0L block. supporting upgrades will get you about 290-295. unless you go with a really conservative tune on a 18/20g.
i am tuned to run 18.6psi with boost cut at 21.
the vf22/23 is good to go with an oversized tmic, anything fmic is overkill imo!
kiwee is offline   Reply With Quote
Old 11-28-2006, 06:30 PM   #27
fastwrx25
Member#: 126441
03 bugeye
^^any links to a dyno plot? how much hp/tq you making if you are running a 23?
fastwrx25 is offline   Reply With Quote
Old 11-28-2006, 06:31 PM   #28
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
that's only if you have a crap tune.
Quack is offline   Reply With Quote
Old 11-29-2006, 07:51 AM   #29
kiwee
Member#: 119232
^^^^ how can you possibly push more out of the 2.0 block?
i see you are getting some good numbers on an 04 rex. what block are you running?
Old 11-29-2006, 07:56 AM   #30
Quack
Member#: 57264
stock USDM block
could always add meth, a bigger turbo, EWG.
i have 83k miles on the wagon since i bought it in March 2004
42k miles with the 18g
30k miles with a VF30
10k miles at Stg2
~1k bone stock
Old 11-29-2006, 09:39 AM   #31
kiwee
Member#: 119232
^^^^ what psi are you hitting? running a boost controller?
how conservative is the tune on the 18g?
Old 11-29-2006, 10:13 AM   #32
Quack
Member#: 57264
Old 12-16-2006, 01:31 AM   #33
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
WRXRallyBlue is offline   Reply With Quote
Old 01-20-2007, 05:20 AM   #34
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
bump!
Just installed the VF-23, haven't gotten the chance to flash the ECM yet so i am just running wastegate pressure right now. I have a question though, what are you guys running as a helper spring and how are you installing it? I know PE used to offer the springs/wastegate actuators but they were a bit pricey. I would like to run a 14psi spring to help with spool and since the car is already a bit of wiring nightmare i think it's a better option then the GM BCS.
Here's what the modlist is
2003 WRX Swap
IHI VF-23(currently 7psi wastegate)
TurboXS Stealth Back W/ Prodrive Box
TurboXS V1 Hyperflow Top Mount
Modded Stock WRX Injectors
Warlbro 255LPH Pump
OpenECU Reflash
JDM STi Up-pipe
Any pointers you guys can reccomend?
ride5000 what kinda IDC's are you seeing with the fuel pressure that high? Also what kind of A/F Ratios?
I'm looking for about 250whp/250tq and starting to get excited after seeing that boost onset graph. For what its worth my TD-04 was on it's last legs and i wasn't getting full boost on it till 3200 RPM(then again maybe it was the cast iron TXS up-pipe that would leak at random not helping matters).
Jeremy
Old 01-20-2007, 07:15 AM   #35
SQC120
Member#: 39677
2008 Land Rover
02 WRX
ont waste w/ the helper spring just yet. get a tune first.
SQC120 is offline   Reply With Quote
Old 01-24-2007, 08:31 PM   #36
bObby
Member#: 66959
04 STi and E46
M3
i would get tuned before thinking about the wastegate acuator.
this weekend im installing my ewg setup and have a top mount now. so sometime next week its going to get tuned. ill have to show whats the final outcome is for my project
bObby is offline   Reply With Quote
Old 01-24-2007, 09:52 PM   #37
ITP
Member#: 131227
Who's doing your tuning? Just curious. There aren't many suby tuners in Ohio.
ITP is offline   Reply With Quote
Old 01-25-2007, 04:11 AM   #38
bObby
Member#: 66959
04 STi and E46
M3
Pure Tuning which is in Toledo, OH
or Slowmotion Motorsports in Columbus, OH
and thennnnn Im going to retune again when Tim Bailey from PDX finds time to fly out to Ohio and tune at Buschur Racing. But Im going to one of the two I mentioned so I can atleast drive the car for the time being. Tim is just bad azz
Old 01-25-2007, 10:02 AM   #39
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
Originally Posted by HndaTch627 View Post
bump!
2003 WRX Swap
Warlbro 255LPH Pump
OpenECU Reflash
JDM STi Up-pipe
Jeremy
i missed this the first time around.
idcs go static @ 300g/s and high 11s to 1 afr. by my napkin calcs running ~30psi over base gives me "pinks," and that jives with my max airflow mass and afr when they go static. pinks are 300whp injectors on 93 pump gas, and 300whp is ~300g/s airflow.
i only hit 300g/s on cold days.. ie <35*F or so.
i put the home depot spring on. iirc it was rated as a 15 or 20# spring. wastegate pressure went up to 12-13psi. perfect, imho. i can personally attest to the fact that the turbo will hold 27+ psi with that gate pressure. i'd put it on and get the car tuned with it on.
if your td04 was hurting spool-wise like that, the vf23 will be all and no !
Old 01-25-2007, 01:58 PM   #40
ITP
Member#: 131227
What tuning software/hardware are you using? I thought that Pure Tuning's dyno was only 2wd. The guys at Slomotion are pretty nice. I have tuned a few cars over there using they're Dynopac. Didn't know that they had a suby guy in-house.
Old 01-26-2007, 03:35 AM   #41
bObby
Member#: 66959
04 STi and E46
M3
Pure Tuning bought a AWD Mustang dyno almost a year ago. They have been doing quite a bit of evos and stis. Keith is pretty good with working with the UTEC. The guy who tunes at SloMo does Subarus too. I was told he pull down over 600whp in a STi. So Ill just flip a coin and see who I will go to soon
Bobby
Old 01-26-2007, 09:51 AM   #42
ITP
Member#: 131227
I know the Sti that you are talking about. It put down 670 ish at SloMo. But they didn't tune it. Phil from Element was brought in by the customer to tune the Hydra.
Old 01-26-2007, 11:16 AM   #43
Quack
Member#: 57264
yep, tuned by Element, put down 678whp on the SloMo dyno, came up the next day to dyno on Bushurs. go the nut-kick when he put down ~500whp
it's been sold since then and now it's up here in cleveland. the motor's out again for the 2nd time since the guy bought it.
Old 01-26-2007, 12:58 PM   #44
ITP
Member#: 131227
No wonder buschers dyno is dubbed 'heartbreaker'.
Yeah, I had heard that the new owner promptly blew it up.
The previous owner(Alex) is builing another car as we speak. At least that's the rumor.
Old 03-08-2007, 09:53 AM   #45
kiwee
Member#: 119232
bumpage!
this is the official vf23 thread. heh!
any new installs?
i want more pressure! ~18.6psi now.
Old 03-08-2007, 10:14 AM   #46
Rasmusson14
Member#: 77658
2004 ej207, ppg dogs
3" green, ITS ALL 4 SALE!
bumpage!
any new installs?
Bobby is getting tuned at the end of this month by Tim again. This EWG and TMIC needed to be optimized. He should spool very quickly.
I too shall be joining the vf23 flock soon enough. I pick one up tomorrow In regards to tuning, does anyone have a OpenECU map or Street Tuner map I could look at? This turbo isn't getting put on until I learn some more over @ 'enginuity' and 'openecu'.
Rasmusson14 is offline   Reply With Quote
Old 03-08-2007, 10:45 AM   #47
Quack
Member#: 57264
there were problems with the motor (can you say valve float). it was down twice since the guy bought it. the motor is rebuilt now, and shouldn't have any problems.
Old 03-08-2007, 11:34 AM   #48
SloRice
Member#: 44351
2004 Mitsubishi Evo
701whp [email protected]
Don't have much to say about the first motor build, but the second motor build was poor to say the least. It's now back up and running and going strong so far.
Alex is building a turbo H6 in a GC8 body.
SloRice is offline   Reply With Quote
Old 03-08-2007, 05:24 PM   #49
aps2fast4u
Member#: 57871
2004 WRX
13.4 @ 102
^^ Ahh, so that's the secret weapon that's gonna take-out Buschur in the shootout huh??
aps2fast4u is offline   Reply With Quote
Old 03-09-2007, 12:43 PM   #50
Farfrumwork
Member#: 10202
'07 Spec B
'85 EJ25 Syncro Westy
Originally Posted by ride5000 View Post
besides the 22, it's the only other vf with a p20 hotside.
Does anybody know the difference between a P20 and an 20R exhaust housing?
I have a VF12 that will be going on (finally) in about a week, and it has a 20R hotside. I believe (think) that the vf12 has the same hot side as a vf22/23 but a smaller compressor
The 20R housing has a inlet of 44.5mm, and the turbine is 53mm major dia/46mm minor dia - not sure of the actual terminology here either, but I'm sure you get what I'm talking about.
The vf12 is very hard to get any info on....
(edited for correct turbine size info)
Farfrumwork is offline   Reply With Quote
FS: PDX Tuning STG4 GT30R KIT, EVERYTHING! W/PDX Tuning Map rbrjr82 Engine/Power/Exhaust 19 05-04-2008 12:44 PM
PDX- 93 oct by PDX Tuning? advanracing62 North West Impreza Club Forum -- NWIC 7 06-06-2007 07:37 PM
PDX Tuned WRX Dyno Results! ScoobySnacker Proven Power Bragging 10 04-02-2007 04:02 PM
1/4 times for PDX tuning stage 4 wrx??? jester458 Proven Power Bragging 21 02-22-2007 12:09 PM
2.5l WRX Hybrid - PDX Tuning Remnex Proven Power Bragging 12 08-30-2006 01:59 AM
