#51 |
Member#: 92783
NWIC
Vehicle:2004 WRX WRB |
Anybody know the correct part number for the AVCS solenoid O-rings?
My car is leaking either from the cam sensors or the AVCS solenoid. Its not leaking much but it is for sure coming from one of these two spots. If I remember correctly there wasn't any o-rings on the cam sensors, they just sit in the holes. Thanks.
#52 |
Member#: 60836
SCIC
Vehicle:2006 Mod Class STI TIMEATTACK!! |
I just put together a big list of seal part numbers for the 2.0, 2.5, and dual avcs motors, any interest in a new version of this thread?
#53 |
Member#: 132583
Vehicle:02 stock white |
Yes please.
#54 |
Member#: 15543
Vehicle:90BJ Legacy LS ABS AWD 946 Rio Red Jpn built |
#55 |
Member#: 93667
Vehicle:'03 Build'n a 2.12L 331whp/331wtq |
Hey guys, what is this gasket for? I am building a 2.12l EJ205 and haven't yanked the motor yet, so I haven't seen this one before.
#56 | |
Member#: 261290
Vehicle:2004 WRX Aspen White |
#57 |
Member#: 93667
Hahaha! I never would have even thought of the oil cap. I've had a Prodrive one for 6 years.
Thanks! |
#58 |
Member#: 261290
I actually need a new one if you wanna get rid of it?
#59 |
Member#: 15543
#60 |
Member#: 93667
#61 |
Member#: 226199
Vehicle:2005 Legacy 2.5gt Silver |
anyone know part numbers of these orings. im kinda stuck.
![]() Last edited by rip25rs; 04-23-2012 at 05:15 PM. |
#62 |
Member#: 266230
NWIC
Vehicle:2006 WRX STI Aspen White |
Gah what happened to the photos from the OP??? They arent working
#63 |
Member#: 127745
NWIC
Vehicle:06 WRX 30r 6 speed 99L EJ255 6 Speed |
Bump for fixing the pics
#64 |
Member#: 200436
Vehicle:2004 Forester XT Black |
#65 | |
Member#: 127745
NWIC
Most of the orings don't fit perfectly and are a bit large |
#66 |
Member#: 340526
Vehicle:2004 WRX STi rotated hx35/850cc/93oct |
Bumping this. OP have the pics??
#67 |
Member#: 98747
South East
Vehicle:07 WRX WRB |
I've got one out in the garage I'm trying to piece together. I'll try and get new pics but I'm lost with all the O-rings. the kit I have is for a 08+.
Here's whats left of my gasket kit, Outfront built the block so they used the rear main and the case half O-rings. I already put on the oil pump crank seal too. Head Gaskets are Cometic but stock ones should be included. Intake manifold gaskets ![]() Intercooler, Header/ Exhaust, and Oil pump - O-ring looks like 2 o-rings connected within each other (minus oil pump crank seal) ![]() Water pump, Oil pan (rear drain tube o-ring has a channel around it (not sure which side face up), and Misc ![]() Valve seals, Cam seals, Valve cover gaskets, and crush washers for turbo oil feed and water lines and AVCS Solenoids ![]() Timing covers, 7x o-rings go to rear covers where it bolts to the heads and block, Long rubber seals are for the center cover, and Foam trim sticks to the back of the covers. ![]() Unknowns, Rear main is big and brown and like a cam seal (my last kit had 3x), Oil pump crank seal is smaller than the cam seals and brown (should be the only one that fits in the pump) Labeled O-rings A-F, if they can be identified I'll update it next to the letters: A) (2x) B) (2x) C) D) E) F) (2x) ![]() Last edited by Justin V; 03-29-2013 at 11:51 PM. |
#68 |
Member#: 180514
E. Canada
Vehicle:2004 Sti White |
A- AVCS exhaust cam gear cap gaskets (for 08+ wrx/sti)
B- AVCS intake cam gear cap gasket C- Oil warmer/cooler gasket D- ??? Could be oil fill tube O ring E- ??? F- Oil dip stick o rings Last edited by Serkan; 04-14-2013 at 01:58 PM. |
| Thread Tools | |
| Display Modes | |
| Axis Stage 2 vs. USDM STi 2.5 | Chad W | Built Motor Discussion | 14 | 04-29-2007 11:40 PM |
| V2 RA STi block vs. 2.5 USDM STi block with '05 wrx heads? | saab-on-the-cobb | Subaru Conversions | 6 | 09-18-2006 07:03 PM |
| Pros/Cons of 2.0 JDM STI vs. 2.5 USDM STI engines | TooSlow | Factory 2.0L Turbo Powertrain | 61 | 01-24-2005 12:14 AM |
| 2.5 USDM STi short block | KZ_Scoob | Private 'Wanted' Classifieds | 6 | 10-06-2004 11:10 AM |
| 2.5 USDM STI Motor is strong! Race Tested! | WorldOne | Factory 2.5L Turbo Powertrain | 102 | 06-23-2004 12:42 PM |
