Old 05-02-2006, 08:51 PM   #1
Hagbard
Member#: 16126
2010 Aluminum Falcon
Angry Need inexpensive, effective tool to cut Heat shield.
Dangit. I have to replace my front O2 sensor on my 99 RS. I found out just how hard it is to get to that bastard, but I hear that removing the heat shield or cutting some of the heat shield off can help. Being that it's a 99, the bolts holding the shield are just lumps of rust. I need to either:
A. Cut a notch out of the heat shield so that I can easily reach the O2 Sensor to replace it.
B. Cut off the bolts holding the shield on.
I do not currently have anything that can do the job. Any suggestions?
Hagbard is offline   Reply With Quote
Old 05-02-2006, 09:07 PM   #2
teiva-boy
Member#: 22825
For the shield, a dremel will work with a few cutting wheels. you'll break or wear down the emery type ones, so best to use a fiberglass wheel.
You should really try to soak the bolts in liquid wrench or WD40. Then try to break them free. If not, you'll have to use a air grinder with cutting wheel to get it off. Or a ton of dremel cutting wheels
teiva-boy is offline   Reply With Quote
Old 05-02-2006, 10:05 PM   #3
Hagbard
Member#: 16126
I might try soaking them, I've got some PB blaster that I can try. Problem is I'm not sure it will do any good, the bolt heads really have no shape left to them at all, they just look like a solid mass of rust.
I'll have to see if I can a replacement chuck for my dremel and try that too.
Looks like I can get the Chuck and the fiberglass cutting disks at Home Depot. Sonofahell, I'm cutting! Woohoo!
Old 05-02-2006, 11:29 PM   #4
B16A2NR
Member#: 88676
Wink
Bring it to Home depot and use their heavy duty cutting shears in the tools department. If anybody asks "Your testing to make sure they work before you buy"
B16A2NR is offline   Reply With Quote
Old 05-03-2006, 04:34 PM   #5
refuse
Member#: 88133
04 wrx wagon
Get a dremel tool if you don't have one. That is my favorite tool. I have had to use it so many times while working on my car.
refuse is offline   Reply With Quote
Old 05-03-2006, 07:19 PM   #6
hulkSTi
Member#: 96355
2005 STi
dremel works great. i have done a few heatshields with mine. it will get the job done
hulkSTi is offline   Reply With Quote
Old 05-03-2006, 08:05 PM   #7
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
remove 6 exhaust manifold stud nuts, remove bolt for mount by trans, remove foward hangers, lower front of exhaust down, replace 02 sensor with ease.
Jay
Old 05-05-2006, 09:56 PM   #8
matt7102
Member#: 12051
1999 Impreza
That Silver color
Default tool
Dremel tool gets my vote...
matt7102
matt7102 is offline   Reply With Quote
Old 05-06-2006, 09:57 PM   #9
Hagbard
Member#: 16126
Well looks like Dremel is the recommended tool. I just pulled mine out of the box it's been in for 5 years and it still works great. Last time I used it was to cut a Japanese N64 Super Mario 64 cartridge so that it would fit a USA N64.
Need someone to weld heat shield back on Diamond Bar area DirtstyleWRX Southern California Impreza Club Forum -- SCIC 17 05-06-2008 04:59 PM
Need help installing the SPT Turbo Heat Shield...I am stuck! joserpm Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 03-27-2008 06:10 PM
How hard to remove heat shield on cilinder #4 for EGT??? BBBsti LTD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-26-2005 03:25 PM
A simple, possibly effective way to cut down on reposts. rogue Off-Topic 36 10-13-2005 07:04 PM
cut heat shield - how? zosima Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-03-2003 04:38 PM
