Old 05-02-2006, 11:30 PM   #1
ooberdoob
Member#: 70418
Five Subarus later I
drive a lifted TJ.
Default worsening starting problem
when i go to start my car from a cold state, it really doesn't like starting. it started with having to turn over a little too long a few days ago, but while trying to leave work tonight it was barely firing till it got above a 1200 rpm. then it ran like a champ.
that's what throws me off, that it runs so good once it is running.
i want to change the plugs back to OE NGKs from the v-powers that are in it now. if that doesn't help, i fear my timing belt is stretching and it needs to be fixed NOW.
anyone have any input for me?!
ooberdoob is offline   Reply With Quote
Old 05-03-2006, 12:25 AM   #2
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Has the timing belt been done?
I know you have a few miles on it, if it hasn't, do it NOW.
Test the coil pack/wires, etc too.
Wiscon_Mark is offline   Reply With Quote
Old 05-03-2006, 12:39 AM   #3
ooberdoob
Member#: 70418
drive a lifted TJ.
i think it's the plugs.
wires and plugs are about 10,000 miles old i'd say.
i'm gonna change the plugs tomorrow if i can get some. i doubt it, so she has to last a couple more days. they come in over night through work. i might second source them. we'll see.
Old 05-03-2006, 09:05 AM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
10k?
Probably not.
Old 05-03-2006, 11:34 AM   #5
ooberdoob
Member#: 70418
drive a lifted TJ.
so i went out and woke it up.
i think it's the fuel pump.
reason:
the anti-drainback valve. if it sets for an extended time, like during work or overnight, i has a hell of a time starting.
this morning, i primed the system 3 times. started a little rough, took a few turns over more than usual, but fired pretty well. idled for a few, cut it off.
after about 20 second, started like a charm.
i think the fuel is draining back during the long periods.
cause once it's been running, it fires right back up, even up to an hour or two later.
we'll see
Old 05-04-2006, 11:44 PM   #6
ooberdoob
Member#: 70418
drive a lifted TJ.
well new pump is in, runs great, only had one cold-start so far though.
i'll update tomorrow night, that'll be 3 more starts.
Old 05-22-2006, 03:05 AM   #7
ooberdoob
Member#: 70418
drive a lifted TJ.
oh yeah, still doing it. if i just hold the key a second longer, all is well, but still, what the hell's the deal?
the confusing thing is that except for that hiccup, it runs great otherwise!
oi vey.
anyone OTHER than mark have input?
Old 05-22-2006, 07:11 AM   #8
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
This issue is news to me.
Perhaps you could do a little test.
If you turn the ignition to the "run" position, does the electric fuel pump run on its own ?
If so could you try priming the pump for 30 seconds or so before starting it, and see if that allieviates your cold starting issues ? Just a thought.
Jonathan is offline   Reply With Quote
Old 05-22-2006, 10:53 AM   #9
Trin_Starr
Member#: 102416
1995 Legacy L
red
What Johnathan said should work. I leave my key in the "on" position for 4 beeps and then start the car. It normally fires up faster than just cranking right away.
Trin_Starr is offline   Reply With Quote
Old 05-22-2006, 11:10 AM   #10
ooberdoob
Member#: 70418
drive a lifted TJ.
if i prime it 3 times or so, it seems to help a little...
the problem didn't jsut appear, it slooowly got worse till i noticed it.
hopefully it'll be fixed with the new timimg belt in a couple weeks.
Cold start problem.. I Love Turbo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 08-15-2002 05:36 PM
Very intermittent no start problem NotAnRS Normally Aspirated Powertrain 6 05-15-2002 09:39 AM
Starting Problems Yanofsky Service & Maintenance 15 02-05-2002 09:39 PM
Can the unichip cause cold-start problems MARTY5446 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 01-04-2002 03:00 PM
Cold Start Problems? Kapwi Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 08-10-2001 05:36 PM
