Old 05-02-2006, 10:41 PM   #1
scottmcphee
Member#: 111378
Default "tap turn" modification
I test drove an 06 Jetta, and have since found out that BMW and Audi .. and other cars have this feature: you just tap the signal stalk and get three signal blinks in the indicated direction and it self cancels. You don't have to click the stalk into position, and you don't have to hold it. You just make contact and release and it springs back to the neutral position as the 3 blinks happen. I wanted to add the feature to my Legacy, so I built a circuit to do it.
If you think the idea could be useful (as I do for highway driving) you might want to build it. The circuit attaches to 4 of the wires going to the flasher module, which is mounted on top of the relay pack attached to the side of interior fuse panel. You can use pinch on wire taps, don't need to cut any car wires.
After several little tweaks and lots of test miles.. I'd say the bugs are worked out and it's ready to enjoy.
I was wondering if I should put this in the interior/exterior mods or perhaps the electrical/lighting forums.. Because this mod should work for any Subaru model that uses the same Denso flasher module. I just don't know how wide or limited that might be. Works well on my 06 Legacy wagon and that's all I care!
Here's the circuit..
img300.imageshack.us/img300/4912/circuit2sp.jpg
Note the chip is a CD4538, google it..
only "half" the circuit is shown because the other half is a mirror image,
all the capacitors should be rated 50volts,
none of the tolerances are tight, so 10% is fine
any old diodes should work...
Cheers,
Scott
Last edited by scottmcphee; 05-03-2006 at 03:47 PM. Reason: finding a way to attach the diagram? eesh
scottmcphee is offline   Reply With Quote
Old 05-02-2006, 10:51 PM   #2
UTCiv
Member#: 30695
BOOM , Get her to
sew THAT!
What is the format?
If it's an image, you will have to host it. I use imageshack.us.
If its a file, it may be best to alt+print screen it and host the image. Sounds like a neat mod .
UTCiv is offline   Reply With Quote
Old 05-02-2006, 11:20 PM   #3
sha_zapple
Member#: 41012
1998 Legacy L
Cant see it, gotta sign in. Host it somewhere else as UTCiv suggested
sha_zapple is offline   Reply With Quote
Old 05-02-2006, 11:28 PM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
Nice idea. I just hold it down, doesn't bother me though. Honestly seems like another thing that could break.
But I'll stop being stuffy now
Wiscon_Mark is offline   Reply With Quote
Old 05-03-2006, 03:49 PM   #5
scottmcphee
Member#: 111378
OK you should see it now.. hosted as suggested.
Thoughts on whether this is the correct forum or not for this posting?? (I'm new around here).
thanks
Scott
Old 05-03-2006, 04:07 PM   #6
sha_zapple
Member#: 41012
1998 Legacy L
Thats very cool. What kind of schooling did you do to learn that?
For the non electrically inclined I wouldnt have the first clue what the box in the middle translates to in real life
Old 05-03-2006, 07:02 PM   #7
badbasser98
Member#: 104801
2011 WRX Limited
hmm.. very interesting. Makes me want to give it a shot
It is a fancy little Integrated Circuit that just has pins on the exterior that are labeled by the charaters on the inside of his "box" to show their function.
It makes our job easier as it preforms certain functions for us that we do not have to build ourselves from scratch.
badbasser98 is offline   Reply With Quote
Old 05-03-2006, 11:58 PM   #8
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
Hmmm... I suspect a lot of Japanese and Koren cars all use this exact same Denso flasher module. Put a kit together and I bet you could make a mint selling this circut (either as a you build it yourself kit, or as a pre-assembled module that plugs in between the flasher module and the circut connector).
for $29.95 (Plus shipping) you too could be the owner of 6 diodes, 6 capaciters, and 4 resisters in a fancy plastic box that plugs into your flasher unit.
Jonathan is offline   Reply With Quote
Old 05-04-2006, 02:17 PM   #9
scottmcphee
Member#: 111378
we're not supposed to talk about selling in these forums (I just found out by a moderator)... PM me if you're interested.. I'm trying to decide if I should become a vendor membership, or whatever.
ALSO - I think it would be better if we moved this discussion to the electrical mod's forum. So that's where I'll continue the idea.
Regards
Scott
Everytime I see someone wearing a "Tap Out" t-shirt... Drink Off-Topic 198 08-12-2008 09:37 AM
"tap turn" modification scottmcphee Electrical & Lighting 33 05-27-2006 07:47 PM
OnStar "Turn-by-Turn" GPS Navigation NYCshopper Non-Subaru News & Rumors 6 02-08-2006 02:17 PM
Prox. with Compustar "tap here" feature conflits? Tur1smoWRX Car Audio, Video & Security 2 09-01-2005 11:41 AM
Airflow modification Vs. IDC modification Hitokiri Engine Management & Tuning 7 06-07-2004 03:48 PM
