Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 05-02-2006, 10:59 PM   #1
cinemaster
Member#: 76127
2005 WRX wgn 5spd
Obsidian Black Pearl
Default 235/40/17 tires on 17x7 rims.
I'm about to purchase new 17x7 rims.
235/40/17 tires will fit on 17x7? I should check it out before getting the rims.
cinemaster is offline   Reply With Quote
Old 05-02-2006, 11:42 PM   #2
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
wooo
not really
215 is what you should get
Hyper is online now   Reply With Quote
Old 05-03-2006, 12:04 AM   #3
cinemaster
Member#: 76127
2005 WRX wgn 5spd
Originally Posted by Hyper
wooo
not really
Hm... even 225 doesn't fit?
Old 05-03-2006, 12:08 AM   #4
AlpoRS
Member#: 81338
2005 2.5 RS Wagon
Crystal Gray Metallic
i run 225's on 17x7 wheels on my wagon, works fine. no rubbing either
AlpoRS is offline   Reply With Quote
Old 05-03-2006, 12:15 AM   #5
Hyper
Member#: 15822
1999 WRB GM6
2.12cc V9 Type RA
225 is pretty much as wide as I would go on them, just make sure that the 225 tire isn't "wide"
Old 05-03-2006, 02:06 AM   #6
rkkwan
Member#: 5596
2010 Honda Fit Sport
You need to look up the specifications on the specific tire you want to get. For example, most (if not all) Bridgestone 235/40r17 tires require rim width of 8in to 9.5in. I definitely will not recommend mounting a tire on a non-approved rim.
225/45r17, on the other hand, will fit rims 7-8.5in, and that's what you can and should get.
rkkwan is offline   Reply With Quote
Old 05-03-2006, 08:18 AM   #7
Synx
Member#: 43712
60's B-52H
03 WRX WRB
I've got 235's on a 7in no problems. They do recommend a 8in for my tire but it fits just fine. Hankook Ventus RS2 (should note... 235/40/17)
Synx is offline   Reply With Quote
Old 05-03-2006, 08:46 AM   #8
cinemaster
Member#: 76127
2005 WRX wgn 5spd
Oh, really? Thanks for the info.
Old 05-03-2006, 08:59 AM   #9
Valhakar
Member#: 39514
2003 WRX 2.5L Hybrid
Mostly Blue
The basic premise. Wide tire on narrow wheel bad.
Now for more detail.
More tire on lesser rim = more stress on the sidewall.
More rime on lesser tire = less stress on the sidewall.
If you are just putting tires on for show (ie. you brag about your performance car but you have never tracked it) then 235 on a 7 inch will fit and will roll around on the ground. However the sidewall will take the brunt of the lateral load in hard cornering. For most daily drivers, even those who's drivers think they are pushing the car, it will work fine. For those that are going to push the car to the limit, a few high G corners and the sidewalls become rice paper.
I run mine at the track, AutoX, street, and general parkinlot asshattery. For that reason I went with a wider wheel and a smaller tire. 235/40-17 Eagle F1 GS-D3s on 5Zigen 17x8.5 wheels. I am going to pick up some dedicated SSRs for the track and plan on running 9 inch wide wheel for the 245 R compound rubber I am going to use.
I would not go more than 225 on that wheel. Azenis in 215 would be a better choice, they are about as wide as most 225s but are rated to fit well on your wheel.
Valhakar is offline   Reply With Quote
Old 05-03-2006, 11:36 AM   #10
Synx
Member#: 43712
60's B-52H
03 WRX WRB
Ya, im not at all saying its ideal. However it seems that with this random wheel that i have which says its 7in, althought its got the wrong bolt pattern cast on the back even thought it is the correct one, that my RS2's in 235/40/17 fit well and feel great. I push the car both autox and just having fun in said parkinglot asshattery (well somewhat hehe) and have had no flex issues as of yet.
235/45/17 tires on 17x7.5 rims cinemaster Tire & Wheel 2 05-01-2006 08:57 PM
HELP 235/40/17 Tires on stock 04 STI rims fastXT04 Tire & Wheel 12 07-20-2005 05:45 AM
Is it okay to mount 235/40/17 tire on a 17/7.5 wheel?? WRXinEffect Tire & Wheel 17 05-30-2005 08:56 AM
Looking for pics of a 235/40/17 tire on 7.5 STi wheel rich728 Tire & Wheel 7 06-29-2004 12:47 PM
does anyone have 235/40 17 tires on 7.5" wide wheels? rex n effect Brakes, Steering & Suspension 0 02-03-2003 01:22 AM
