Welcome to the North American Subaru Impreza Owners Club Saturday February 6, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 05-03-2006, 08:17 AM   #1
LegacyJones
Member#: 48791
02 bugeye
wagon
Default E-manage Help
Is anyone that has e mang. running it with a MAP based car? I've heard it doesn't work to well. I don't have any $ for the ulti. before somone says to get it. I'm trying to find a fix with the blue.Is there any extra wires or a way to trick the ECU? Let me know what you got.
Jason
LegacyJones is offline   Reply With Quote
Old 05-05-2006, 04:49 PM   #2
LegacyJones
Member#: 48791
02 bugeye
wagon
To the top. Any info???
Old 05-05-2006, 05:21 PM   #3
Master2192
RIP 10/12/83 to 02/10/08
Member#: 83254
98 2.5 RS
04 WRX
If you are only using the fuel trim part of it I would guess that it doesn't work as well.
The problem is the E-manage blue only tunes by changing the signals the ECU gets from the sensors to trick the ECU into a certain fuel or timing range. I think the ECU gets upset when it doesn't see a certain map range per throttle position.
The injection harness only seems to be able to control 2 additional injectors, you can't control the stock ones directly.
I am not sure what you are trying to do...
Old 05-06-2006, 07:07 PM   #4
LegacyJones
Member#: 48791
02 bugeye
wagon
Thanks for chiming in!
This is what I have:
Wrx block
2.5 heads, intake, and sensors
T3/T4 stage 2 63 trim
RC 550 injectors
Walbro 255
gauges: boost, fuel press., egt, air fuel/ wide band
Hks turbo timer
blitz dual stage boost cont.
That's the set up. I'm using the stock ecu. The car idles great 800 -1000 rpm's. Anything after that it bogs down, It's getting way to much fuel. I just bought the e manage press and harness, I hope it helps.
Jason
e-manage help on my wrx railguy Engine Management & Tuning 2 02-03-2005 07:11 PM
Exhaust and engine management help! litlechina Engine Management & Tuning 3 09-13-2004 09:04 AM
fuel managment help Sparticus Normally Aspirated Powertrain 0 06-03-2004 01:15 AM
Engine Management help IJust8Chris Engine Management & Tuning 5 04-14-2003 06:28 PM
R/C 440s without Engine Management? Help!! adamsrs Normally Aspirated with bolt-on Forced Induction Powertrain 14 10-16-2001 05:21 PM
