Notices
Old 05-03-2006, 02:15 PM   #1
SpeedElement
Member#: 18920
2004 WRX/STI
Default Cusco Rear Subframe Brace w/ STi Rear Diffuser
Here are some pix of Cusco Subframe Brace w/ STi Rear Diffuser Installed on one of our customer's car.
Cusco Subframe Brace CUS-673-487A, Cusco Subframe Brackets CUS-672-487S, and STi Rear Diffuser
Cusco Subframe Brace Installed (Under Car View)
STi Rear Diffuser Bracket #1 (comes w/ 2 brackets)
Cusco Subframe Brace Installed on the Right side of chassis
Cusco Subframe Brace Installed on Left side of chassis
SpeedElement is offline   Reply With Quote
Old 05-03-2006, 02:19 PM   #2
SpeedElement
Member#: 18920
2004 WRX/STI
Subframe Brace installed along w/ STi Diffuser Bracket installed.
STi Mounting Bracket installed (black piece)
STi Mounting Bracket #2 (near the License plate frame)
The Exhaust is Apex'i WS Exhaust. The muffler is quite big compare to other types of exhaust systems. However it clears just fine with the diffuser.
Overall impression: The install took about 1 hour. As you can see, the car still on stock rear swaybar, but the rear feels much stiffer with this subframe brace installed after we took for a spin. The installation of the STi rear diffuser was a breeze with these Cusco pieces in place. We think the diffuser will work pretty good if we go over 100+mph.. But it looks good nontheless.
Old 05-03-2006, 02:29 PM   #3
Vampyr
Member#: 31761
2005 sold! STi
Aspen White w/ Gold rims
Great pics!!!!
thanks for the info!
Vampyr is offline   Reply With Quote
Old 05-03-2006, 02:32 PM   #4
SpeedElement
Member#: 18920
2004 WRX/STI
no problem. These subframe brace will also fit GC/GF chassis Imprezas, GD/GG Sedan/Wagon and of course 04-05 STi
Thanks
MPJ
Old 05-03-2006, 03:29 PM   #5
sjs0433
Member#: 86061
any pics from farther behind the car....i'm actually more curious to know how the apexi exhaust looks on the car
sjs0433 is offline   Reply With Quote
Old 05-03-2006, 04:30 PM   #6
slowscooby
Member#: 69520
- '05 STi
"White Thunder"
Cool write up. Always wondered if that brace did anything except give you a mounting support. They charge enough for the damn thing.
slowscooby is offline   Reply With Quote
Old 05-03-2006, 04:54 PM   #7
SpeedElement
Member#: 18920
2004 WRX/STI
This Apex'i WS exhaust actually looks quite stock from behind. I will post some more pictures when my friend comes back to the shop.
As for the price, the STi Diffuser is actually about $79 free shipping.
The Cusco Subframe Brace and Subframe brackets cost about $165 free shipping.
The subframe brackets are not needed if you don't plan on using the rear diffuser.
Thanks
Calvin
Old 05-04-2006, 04:48 PM   #8
SpeedElement
Member#: 18920
2004 WRX/STI
still have some left! plz give us a call if you have install questions
Old 05-04-2006, 07:40 PM   #9
calmnothing
Member#: 75053
Does the brace provide any noticable stiffening?
calmnothing is offline   Reply With Quote
Old 05-04-2006, 08:40 PM   #10
SpeedElement
Member#: 18920
2004 WRX/STI
yes it does. The car in the pictures above did not have any rear swaybar, we noticed the rear had stiffened up a bit after the subframe brace/diffuser install.
Old 06-24-2006, 11:32 PM   #11
jwtarbaj
Member#: 45032
2003 WRX Sport Wagon
Sedona Red
Any idea what level of modifcation is required for WRX owners with afermarket RSB mounts? I have seen that there is a fitment issue with aftermarket mounts. That's a problem for us 02-03 owners especially since we had crappy stock mounts.
jwtarbaj is offline   Reply With Quote
Old 06-25-2006, 09:33 PM   #12
perfusionista
Member#: 59471
2006 WRX Wagon
Crystal Gray
Sorry, but I'm going to call "placebo effect": you knew that something had been done to the car, so you felt that the performance had changed appropriately. I'm not convinced that placing a bar between the sway bar mounts can produce a palpable change in the rear suspension (maybe if we had F1 standard telemetry! )
Go drive around the same test course, with the mechanics changing the set-up between runs but not telling you what they're doing, then you can find out what really changes the performance (BTW they must include no-change in their mods, that's usually the most revealing!)
EDIT: I'm actually planning on adding this bar and the diffuser, because I think it places the diffuser in a better position (vs bolting it right up to the bottom of bodywork) but I'm not convinced the bar itself is any improvement.
perfusionista is offline   Reply With Quote
Old 06-25-2006, 10:13 PM   #13
BIGSKYWRX
Member#: 7958
09 GH B+
^ I'd have to agree, but it did line up the diffuser nicely . You can read my impressions on the rear diffusor w/ the under side aero bits in exterior.
If you have a 02/03- upgrade to the 04+ rear mounts- it's a good upgrade even if you don't do the cusco/diffuser- and it's pretty cheap too.
Old 06-25-2006, 10:31 PM   #14
desertaero
Member#: 88954
'05 Saab 92X Spec C
desert silver metallic
does it require any drilling for the rear two bracket bolts?
desertaero is offline   Reply With Quote
Old 06-26-2006, 01:58 AM   #15
ralliharri
Member#: 85035
2011 WRX 5-door
KTM 690 Duke
No drilling required, only 2 M6 bolts and nuts is needed in addition to the kit, real easy to install.
ralliharri is offline   Reply With Quote
Old 06-26-2006, 02:38 AM   #16
IIdiceII
Member#: 90438
sorry to be a tiny bit off topic
any pics of the exhaust from further away?
IIdiceII is offline   Reply With Quote
Cusco Subframe Brace + 06 STI Diffuser? Uncle Ben Interior & Exterior Modification 39 03-08-2010 12:34 PM
FS: 06-07 STi Diffuser and Cusco Rear Subframe Brace SlammedREX Exterior/Styling 8 07-09-2009 04:13 AM
Brand new cusco rear suframe brace with STi Rear Diffuser Combo aceking66 Suspension/Brakes/Handling 6 04-23-2009 10:19 PM
Feeler: FT Cusco rear subframe brace+diffuser brackets and diffuser generalganja SCIC Private Classifieds 10 10-11-2007 11:38 AM
Cusco Rear Suframe Brace and STi Rear Diffuser- 02+ WRX / 04+ STi Sheep master Suspension/Brakes/Handling 2 03-01-2007 12:30 AM
