Old 05-03-2006, 03:30 PM   #1
Snoopy
Member#: 700
99 Impreza RS
Silverthorn Metallic
Default Ah well...my gasket leaked again and mechanic thinks the heads are warped.
Gonna cost about $3,500 to fix.
I had them repair it under the recall for the gasket problems when the car was at 75,000 miles. Been using the conditioner since but it would stop the leak temporarily until I got another conditioner.
Now it's 104k miles and decided to take it in for the timing belt change. Asked them to check on the gasket. Told me it was leaking and the heads could be warped. Could be. But the cost to fix it was about as much as a new engine.
Told them to replace the timing belt only.
Snoopy is online now   Reply With Quote
Old 05-03-2006, 04:10 PM   #2
wrx_driver_2002
Member#: 25952
1995 Impreza Coupe
w/ "Extras" :-)
You can buy a longblock phase 2 2.5 Engine from someone in your area who has done a swap anywhere from 100-1000 and then do all of the work yourself... Will be alot cheaper than 3,500 for the work. If you've got headgasket concerns before installing the new engine, then put them in before installing the engine...Im sure if you posted about needing help installing an engine, there would be some nasioc people to help ya
If you want more information about that, feel free to PM me, or contact me on AIM.
wrx_driver_2002 is offline   Reply With Quote
Old 05-03-2006, 04:22 PM   #3
tylerq219
Member#: 68213
92? justy rally car
white/blue/mud #44
Default huh
i work at a local subie dealership and i see me share of headgasket leaks. But thers is really no way to tell if the heads are warped from looking at them id get a 2nd opnion. just my two cents
tylerq219 is offline   Reply With Quote
Old 05-03-2006, 07:55 PM   #4
Hayes
Member#: 11808
Is it an external leak? If so, is it leaking enough that you can't live with it at that milage?
Hayes is offline   Reply With Quote
Old 05-04-2006, 06:13 PM   #5
Snoopy
Member#: 700
99 Impreza RS
I can live with the leak....but I need to do the engine swap. no way I'm going back to car payments. I emailed www.eastcoastswappers.com already.
Well-Melted my brake caliper boots and heat pitted the piston-Question? Rudywrx04 Brakes, Steering & Suspension 4 11-04-2009 03:47 PM
Why does my cell phone flash and beep when the batteries are dying?!! skimmilk68 Off-Topic 6 03-21-2006 01:18 AM
Turbo leaking coolant, and inlet pipe severed, Things are looking up? D-I-Z-Z-L-E Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 11-18-2004 12:19 PM
I think the dealers are BS'ing people into saying there selling into MSRP LinuxGuy STi Forum Archive 12 01-11-2003 08:24 AM
and then went the head gasket... herzy2.5RS New England Impreza Club Forum -- NESIC 5 11-04-2002 12:55 PM
