Old 10-08-2001, 03:33 AM   #1
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Default hex head bolt remover part number
Need head bolt remover part number.
Thanx!
WRXwannbe is offline   Reply With Quote
Old 10-08-2001, 03:41 AM   #2
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
swap and N20. gone. : (
Dude, the head bolts are only a 12 point socket
Eric
Eric SS is offline   Reply With Quote
Old 10-08-2001, 03:50 AM   #3
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
One more thing, I believe that it is 14mm. It takes some force to break them lose but once you do it's not to bad. They take forever to back them all the way out though! I just did it about a week ago
Eric
Old 10-08-2001, 12:42 PM   #4
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Eric,
Were you able to get all the head bolts out without pulling the motor? I couldnt, the bolts were JUST a llittle bit too long.
Chad
93 1.8t
subachad is offline   Reply With Quote
Old 10-08-2001, 02:59 PM   #5
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
I finally got all of the motor and tranny mounts out of the car and was able to lift the engine enough and have it move forward so I could get the head off. otherwaise I would not have been able to get the head off The driver comes out but not the passenger
Eric
Old 10-08-2001, 03:08 PM   #6
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Honestly, I don't think I'd ever even try pulling the heads without fully pulling the motor, or at least lifting it a good 6-8" (more then the coolant hose can handle - might as well pull it and make life easy).
Old 10-08-2001, 03:57 PM   #7
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
It was actually extremely easy. but, i do already have all the wires and hoses and accesories, etc. off the engine so maybe that made it easier
Eric
Old 10-09-2001, 02:45 AM   #8
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
Did you go with buying new bolts after you took off the old ones?
Old 10-09-2001, 02:58 AM   #9
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
You have too to get the torqued properly. THe bolts are made to stretch a little so never reuse head bolts!
Eric
Old 10-09-2001, 03:12 AM   #10
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
how much torque are we taling about? Did you ever need to hela-coil a bad thread?
Old 10-09-2001, 03:14 AM   #11
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Have I had to, yes. Have I had to on a Subaru aluminum block, no. Why would one be messed up? if the factory did that I would be extremely upset. Especially on a head bolt! THose need to be pretty darn perfect. I'm not sure of the torque specs or patern on our engines. sorry
Eric
Old 10-09-2001, 03:25 AM   #12
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
There is also an allen wrench looking nut right in the middle of the head. What is that about?
Old 10-09-2001, 03:34 AM   #13
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
OK, those are kind of weird. There are 6 of those. I believe that those are T-35's. They connect the top part of the head to the bottom. It's hard to explain. don't worry about those until you get the head off. you don't need to take those out to get the head off.
Eric
Old 10-09-2001, 03:40 AM   #14
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
did you have to replace the cam journals and seals when you took off the camshaft to get the head off?
Old 10-09-2001, 03:47 AM   #15
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
You don;t have to take the cam out to get the head off. All you need to do is take the valve cover off and then remove the 6 bolts that hold the head on.
Eric
Old 10-09-2001, 03:48 AM   #16
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Also, the cam journal is ground into the cam, you can;t replace it. You shouldn;t have to replace any seals either.
Eric
Old 10-09-2001, 04:01 AM   #17
WRXwannbe
Member#: 1954
1997 Impreza L/WRS
DOHC!!!!
sorry if I didn't tell you before.
same principle though.
Old 10-09-2001, 04:06 AM   #18
Eric SS
Sooby Guru
Member#: 1914
2000 2.5RS w/ EJ22T
Oh, I guess I should have noticed that you have a MY97. Not sure about the 97's. sorry
Eric
SPEC B axle part numbers GraphicWRX Private 'Wanted' Classifieds 8 06-03-2010 12:27 AM
Head bolt removal & tighten - sequence? skottm Normally Aspirated Powertrain 3 02-27-2010 09:58 PM
Lower Strut Bolt/Nut Part Number? vision.dynamix Brakes, Steering & Suspension 2 03-17-2009 10:56 AM
Head bolt removal order pilfflip Legacy Forum 3 06-01-2006 06:09 PM
98 Legacy Camber Bolt, need part number jmseven7 Brakes, Steering & Suspension 0 11-21-2003 03:54 PM
