Old 07-10-2006, 12:23 PM   #1
Paraskass
Member#: 51735
2006 2.5i
Steel Gray
Default Irregular engine revs?
On my 2006 2.5i, the following happened once. Today.
I started the car this morning, shifted into reverse and prepared to drive out of my parking lot. I went into first gear and kept my foot on the clutch and my other foot off the gas as I waited for a car on the street to drive by. Without giving it any gas, my car was reving steady at 2.5-3k RPM...
I let the car out of first and removed my foot from the gas and it was still reving at 2k...
I just ignored this and drove off. Problem did no reoccur.
I noticed sometimes that unless I put the car in neutral, RPMS might stay around 2-2.5k if I press the clutch pedal without touching the gas. Is this normal?
Paraskass is offline   Reply With Quote
Old 07-10-2006, 12:29 PM   #2
AbsolutShyam
Member#: 116261
2008 Legacy GT
Dark Grey
I had the same problem and asked around in here, as well as my subie dealership. Apparently it is normal, especially if the A/C is on. Annoys me sometimes. The subie dealership said it was nothing to worry about, and if there is anything even the slightest wrong with the drive-by-wire, the check engine light should come on.
AbsolutShyam is offline   Reply With Quote
Old 07-10-2006, 04:12 PM   #3
Paraskass
Member#: 51735
2006 2.5i
Steel Gray
Ok,
thanks for the info!
I know when I turn the AC on the revs go up... but today it was off...
I'll see if the car keeps doing it and I'll tell the dealership.
Old 07-10-2006, 06:49 PM   #4
AbsolutShyam
Member#: 116261
2008 Legacy GT
Dark Grey
No Problem, and let me know if they tell you something else. The guy at my dealership didn't looked too concerned, and I am not sure if that was because it is not a problem, of if he just didn't care enough to pay attention to me.
Help!? Engine revs up and down in the high end of 4th and 5th gear. Robmat Normally Aspirated Powertrain 7 06-09-2003 11:52 PM
Big Problem: Engine revs cutting out Redneck Ricer Normally Aspirated Powertrain 7 12-21-2002 06:18 PM
Engine rev sounds through my tweeter. subarex Car Audio, Video & Security 4 10-23-2002 12:48 PM
Engine Revs RChampion Normally Aspirated Powertrain 13 08-07-2002 03:28 PM
