Welcome to the North American Subaru Impreza Owners Club Friday August 28, 2015
Old 05-03-2006, 05:36 PM   #1
SyntheticDefect
Member#: 107546
2005 Impreza RS
Red
Default OBX EL header
Has anyone put the OBX EL header pipes on their 2005 RS's yet, if so how did you like it and what did you do so you didn't get a check engine light?
SyntheticDefect is offline   Reply With Quote
Old 05-03-2006, 08:43 PM   #2
fenix_black
Member#: 112180
05 2.5 RS
fenix_black is offline   Reply With Quote
Old 05-03-2006, 08:48 PM   #3
SyntheticDefect
Member#: 107546
2005 Impreza RS
Red
Ya i know how to use the search button, but thanks anyways. I cant find anything about anyone putting them on the 2005s. Thats why i posted that.
Old 05-03-2006, 09:21 PM   #4
BlkTS02
Member#: 50142
2002 2.5TS
MBP
From an exhaust perspective the 05 is the same as every other 99-04 N/A impreza.
BlkTS02 is offline   Reply With Quote
Old 05-03-2006, 10:29 PM   #5
SyntheticDefect
Member#: 107546
2005 Impreza RS
Red
Well i ordered mine from ebay, hopefully there are no fitment issues or any kind of issues for that matter
Old 05-04-2006, 12:15 AM   #6
ArcAnGeL
Member#: 99731
2007 CGM
project on hold till 08
synthetic let me know how is goes... and more details... im looking for headers, and a catless mid pipe
ArcAnGeL is offline   Reply With Quote
Old 05-04-2006, 12:17 AM   #7
JonzFaSTi
Member#: 85575
2013 STi
Dark Gray Metallic
if you go to rs2.5 they talk a lot about the obx.
JonzFaSTi is offline   Reply With Quote
Old 05-04-2006, 12:19 AM   #8
ArcAnGeL
Member#: 99731
2007 CGM
is that a website?
Old 05-04-2006, 12:29 AM   #9
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Originally Posted by ArcAnGeL
is that a website?
Yep!
www.rs25.com
gtwagon941 is offline   Reply With Quote
Old 05-04-2006, 10:32 AM   #10
SyntheticDefect
Member#: 107546
2005 Impreza RS
Red
Old 05-04-2006, 10:46 AM   #11
SyntheticDefect
Member#: 107546
2005 Impreza RS
Red
should work nice with my custom cat back exhaust, i used 2 1/4" piping, removed the resonator, used Flo-Pro stainless exhaust with 4" stainless tip. Sounds nice, hopefully it wont go to much louder with the equal length headers
Also got the Injen Intake
After the header pipes i will get the Perrin light weight crank pulley and then suspension
Old 05-04-2006, 02:17 PM   #12
ArcAnGeL
Member#: 99731
2007 CGM
sounds like exactly what i wanna do..
also check out http://www.rallitek.com/yhst-4918738...5/rapeecu.html
this would be a great addition!@
Old 05-04-2006, 02:40 PM   #13
SyntheticDefect
Member#: 107546
2005 Impreza RS
Red
ya, i want one of those too
Old 05-04-2006, 02:53 PM   #14
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Originally Posted by SyntheticDefect
Not to burst your bubble, but you wasted $30 on that 02 sensor extension.
Search under "mechanical CEL fix" if you'd like to find out why.
Old 05-04-2006, 03:39 PM   #15
SyntheticDefect
Member#: 107546
2005 Impreza RS
Red
Oh well, not much i ca do now. Just hope that it works. Besides 30$ isn't that much.
Old 05-04-2006, 03:39 PM   #16
bahboy20
Member#: 6726
Default obx header
hey, you are doing what I have been thinking of.
Why did you get that injen intake and not the newer one with the big hp gains that dips into the fender well??? yours looks just like it just sucks air from the hot engine bay?
I have a 2002 2.5 RS with a injen intake and greddy evo2 exhaust. I have been debating getting the obx EL header, mainly because it seems to be a pain to get a HFC and get that welded in. The auction only includes a catless straight pipe.
I heard that the sound will be terrible with equal length header. You will no longer have the boxer rumble, and the car will sound like a bumble bee, a-la honda civics, etc.
Can you pass emissions if you have a CEL fix but no cat at all, and just use the EL header and catless straight pipe they include?
Also, I hear that you have to either drill or remove your heatsheild because the sensor is on the wrong side for one of the 2 sensors on the header....not sure if that effects your year, but its not that big a deal, just thought maybe you would want to know that...
dan
bahboy20 is offline   Reply With Quote
Old 05-04-2006, 04:03 PM   #17
Rally_wgn
Member#: 62629
1996 OBS in Green
2.5 N/A w/ full exhaust
Actually the sound of the EL header is more along the lines of a Porsche motor than a Honduh. There are a couple of threads on the EL header sounds on RS25.com. Maybe some here too.
Rally_wgn is offline   Reply With Quote
Old 05-04-2006, 04:45 PM   #18
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Your muffer / cat / resonator has more of an effect on exhaust sound / tone than a header does.
Although yes, the El header almost eliminates the boxer rumble.
Old 05-04-2006, 05:12 PM   #19
SyntheticDefect
Member#: 107546
2005 Impreza RS
Red
I'm not worried much about the sound ( honda, porsche, subby ), i just dont want it to be ridiculously loud and annoying. Im only looking for hp and torque gains, mainly torque. just want to get more pull from the start. And i didn't run my Injen intake cold air because i heard somewhere you lose low end torque. Also its a pain to get to the filter when it comes time to clean it. I have the extension to run it cold air just don't want to.
Old 05-04-2006, 05:15 PM   #20
SyntheticDefect
Member#: 107546
2005 Impreza RS
Red
Also i know about the o2 sensor bung being located in the wron place. doesn't bother me. i might get the resonator taken out and get a high flow cat welded in its place instead i think, we'll see.
Old 05-04-2006, 07:09 PM   #21
jimbobrand
Member#: 21935
2010 '13 BRZ Premium
WR Blue Pearl
In order to use the O2 extender you will need to have the rear O2 bung relocated as the sensor is very close to the driveshaft as is. Once you get the header installed you may want to add a resonator back into the system to mellow out the sound and make it quieter.
-Jim
jimbobrand is offline   Reply With Quote
Old 05-04-2006, 08:24 PM   #22
SyntheticDefect
Member#: 107546
2005 Impreza RS
Red
Im running the car without a resonator now and i like the way it sounds, and as i mentioned before i plan on adding a high flow cat back into the system so that should relocate the o2 sensor bung. And i read somewhere that the equal length headers quite the system a little bit, not sure how true that is but we'll see. Do you have an OBX header on your car and if you do do you like it?
Old 05-04-2006, 09:10 PM   #23
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Are you still running the stock cat section? That really quiets the exhaust down.
Once you get the OBX installed you'll understand.
Old 05-04-2006, 09:17 PM   #24
SyntheticDefect
Member#: 107546
2005 Impreza RS
Red
nope, got a custom catback exhaust from my local muffler shop. Got 2 1/4 inch pipes, resonator removed flo-pro stainless exhaust and a 4" stainless tip
Old 05-04-2006, 09:38 PM   #25
BlkTS02
Member#: 50142
2002 2.5TS
MBP
Ok, but cat-back means after the cat section. It's the part that bolts to the headers and where the two oxygen sensors thread into.
OBX EL header on 06 07 2.5i Jerry Xu Normally Aspirated Powertrain 75 11-13-2008 12:32 PM
2004 2005 2.5rs OBX el Headers with cat-delete fulltimeW.O.T. Engine/Power/Exhaust 2 03-03-2008 10:44 PM
WTT: OBX EL header for borla replica firefighter1 NWIC Private Classifieds 1 02-25-2008 01:56 AM
OBX EL header. Whiteghost 2.5 Normally Aspirated Powertrain 7 01-17-2006 12:09 PM
OBX EL headers for 2.5RS NFJ79 Normally Aspirated Powertrain 216 01-09-2006 12:50 PM
