Old 05-03-2006, 07:26 PM   #1
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
Inexplicably rusting.....
Default my injen cai thumps when i turn the car on
ive moved it twice, doesnt seem to be rubbing anything. wtf?
hendo2.5 is offline   Reply With Quote
Old 05-03-2006, 08:23 PM   #2
impr25rs
Member#: 60162
04 Aspen RS
The One Not Turbo'd, NA!!
Mine does the same thing Oh well
impr25rs is offline   Reply With Quote
Old 05-03-2006, 08:27 PM   #3
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
It's the motor doing it's wake up shake.
group "N" motor mounts should help eliminate that. You could also surround the pipe with foam where it goes through the inner fender wall.
Tim Sanderson is offline   Reply With Quote
Old 05-03-2006, 08:43 PM   #4
hendo2.5
Member#: 89912
2005 Impreza 2.5rs
the thing is that it wasnt doing it last year. i just converted from shortram back to cai for summer and now its happening. regarding the protective trim for where it pass through the sheet metal, i changed the rubber trim that comes with the intake to a thicker weather stripping to hold it in place better. is it banging because the engine shakes more violently when turning over? i dont want to dammage anything.
Old 05-03-2006, 10:32 PM   #5
05rswagon
Member#: 75371
2011 WRX Prem Hatch
instead of using the included hole liner get some rubber fuel line and cut it down the center and use that instead thats what I did and it worked great
05rswagon is offline   Reply With Quote
Old 05-04-2006, 12:15 AM   #6
JonzFaSTi
Member#: 85575
2013 STi
Dark Gray Metallic
Put the foam on its due to the fact you went back to the CAI. Right where he said. its sort of a rattle, right? I alsmost stayed with the short ram because of that but just used some foam and its been good ever since.
JonzFaSTi is offline   Reply With Quote
Old 05-04-2006, 11:49 PM   #7
resident1155
Member#: 92659
2002 Impreza RS
what 05rswagon said. Go to the hardware store and buy some tube. Either will work.
resident1155 is offline   Reply With Quote
Help! When I turn the defroster on it makes a wierd noise! D Money Service & Maintenance 15 06-07-2011 02:31 PM
Strange click in the glove box when I turn the lights on pleadeezaru Newbies & FAQs 7 01-06-2009 12:43 PM
Would it be safe to turn the car on and move the wheels while on jack stands? Dragonbreak Newbies & FAQs 13 08-17-2007 03:33 AM
Turned the car on before putting MAF plug in Mdub Newbies & FAQs 2 08-01-2007 12:25 AM
