Old 05-03-2006, 08:44 PM   #1
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Default EJ257 block with ported WRX heads and bigger cams
I am now getting a 2.5L longblock to run with my '02 ECU which will probably be ECUTeked before I drive home in less than 2 weeks. However, when I get home, I'm thinking of swapping the heads with AVCS to my WRX heads, which will get ported and rebuilt with bigger cams, different valves, etc. This way, I won't need more EM to run the AVCS and won't have to deal with switching to DBW, which I don't want to do. Any ideas on what cams I should be looking at? Only looking to make 300-350whp, and I'm stage 2 right now.
wrxfactor is offline   Reply With Quote
Old 05-07-2006, 06:43 PM   #2
swift2fly
Member#: 70810
07 impreza STi
Jizz White.facial anyone?
crower stage 2(264) cams should be enough for the power you're looking to make.
swift2fly is offline   Reply With Quote
Old 05-07-2006, 06:59 PM   #3
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
Would you say that I just need cams? I was looking at the Helix 264 cams and valvetrain package.
Old 05-07-2006, 09:14 PM   #4
Subaroooooooooo
Member#: 114204
05 2.5 Legacy
Blood Red
You'll need upgraded springs etc. depending on how hard you drive or want to bullet proof your set up. I'd spend the extra money. Labor to do the work would be about the same.
Subaroooooooooo is offline   Reply With Quote
Old 05-07-2006, 09:49 PM   #5
Antonios Kintos
Member#: 81122
08 STi white
I did a 2.5 shortblock with wiseco pistons with my untouched wrx heads and a DB tdo6h 20g. My goal after the final tune 330-340 whp. I was one phone call away from doing crower stg2 cams. After doing a ton searching I discovered cams were not needed for my goal. If you have the EJ 257 longlock you already have the sti valves and a more aggressive cam profile.
Antonios Kintos is offline   Reply With Quote
Old 05-09-2006, 01:21 AM   #6
swift2fly
Member#: 70810
07 impreza STi
i would do the cams and like Subaroooo said, spend the extra money on the valves. u may reach your goal with stock wrx heads but the power delivery though out the band of bigger cams w/ wrx heads is much much better.
Old 05-09-2006, 11:27 AM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
well, a guy in our club is running a set up of similar description with good results:
http://forums.nasioc.com/forums/showthread.php?t=915612
it's actually the setup I wanted to do for my poor college student budget but I've since changed my mind
wrx crank in EJ257 - With 04 wrx heads and sti cams morrocco88 Built Motor Discussion 64 09-05-2009 08:48 PM
Noob builder - Questions: EJ257 block with '06 WRX heads? saab-on-the-cobb Built Motor Discussion 2 03-13-2009 10:51 PM
Ported WRX heads and bigger cams on 2.5L block wrxfactor Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 8 05-04-2006 06:35 PM
EJ257 longblock, ported WRX heads and larger cams wrxfactor Built Motor Discussion 8 05-04-2006 10:29 AM
Ej257 block w/ ported WRX heads? wRxbeater11 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-14-2003 10:57 PM
