Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 05-03-2006, 10:45 PM   #1
cdigerlando
Member#: 6070
2015 STi
Dark Gray Metallic
Default Boost Controller with TEC II
I have a boost control solenoid for my Tec II. I believe that the controller just hooks into the wastegate line to the mechanical boost controller via a tee. I believe that the small hole on the tee goes to the boost control solenoid which is vented to atmosphere. Is this a correct assumption?
cdigerlando is offline   Reply With Quote
Old 05-18-2006, 12:50 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
from the ancient vishnu pem manual i have a copy if you want it
Place the brass tee into the wastegate signal line with the restricted “leg” pointing towards the turbo’s compressor outlet (as per our labeling). This restrictor effectively reduces the boost signal, giving our solenoid more authority in the wastegate signal manipulation game. Next, route the supplied thick vacuum line between the remaining tee output and the barb-equipped boost control solenoid. You can tie wrap the solenoid to the AC lines just aft of the passenger side strut tower. Since you wouldn’t want any wastegate lines popping off, firmly secure the vacuum lines with the supplied little hose clamps. With the plumbing complete, lengthen both of the solenoid wires (if necessary) and route one to Output Pin 6 (GPO) and the other to Output Pin 9 (SW BAT).
pming you about something else
Boost problems with Stage II screamin04wrx AccessPort 12 04-18-2006 04:11 PM
Help With Tec Ii maxiav Mid Atlantic Impreza Club -- MAIC 3 03-26-2004 01:13 PM
Passing DEQ with TEC II and tubos??? Cusco Normally Aspirated with bolt-on Forced Induction Powertrain 1 12-12-2002 12:38 AM
Using the stock boost control with a larger turbo/eliminating boost spiking Red Rocket Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 10-18-2002 09:39 PM
Boost controller with nothing else but a boost guage, good or bad idea? Corn-Picker Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-08-2002 09:07 AM
