Old 05-04-2006, 05:01 PM   #1
35th
Member#: 105239
2004 Red-ish Legacy
09 FX Prem. 07 Suzuki M50
Question stereo install questions
How do I take off the trim around the stereo?
How do the door panels come off?
I did a search the other day and only found Impreza info.
Thanks,
Brian
35th is offline   Reply With Quote
Old 05-04-2006, 05:20 PM   #2
skunkfifty
Member#: 73102
1998 legacy outback
white
this should apply to you
http://www.butkus.org/subaru/outback...ack_stereo.htm
cant help you with the doors. usually you undo whatever screws there are and then pop it off.
skunkfifty is offline   Reply With Quote
Old 05-04-2006, 05:31 PM   #3
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
97 LegacyGT Wagon 4EAT
Since you have a later model Legacy, maybe try legacygt.com
GTWagon_Phreak is offline   Reply With Quote
Old 05-04-2006, 05:54 PM   #4
IDMO
Member#: 91819
2004 FXT
There's a detailed .pdf floating around that I used to install my stereo, I'll upload it and post it when I get home if someone else doesn't post it first.
IDMO is offline   Reply With Quote
Old 05-04-2006, 09:21 PM   #5
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
I'd be interested in that as well. I can take the doors off just fine, but the deck is another thing entirely.
DLC is offline   Reply With Quote
Old 05-04-2006, 09:24 PM   #6
hybrid gti 2
Member#: 67004
02 vf30 pnp wagon
silver and cf
center part near deck is a pop out part, flat blade screw driver. sterio held in with 6 screws. careful with door part as it cracks ez.
Old 05-04-2006, 10:08 PM   #7
IDMO
Member#: 91819
2004 FXT
Here ya go, two documents. I have no idea who created the first one, so if I'm not giving credit where it's due I apologize.
This link should work for a while, if not I'll just email them to someone to host.
http://beta.yousendit.com/transfer.p...77E7A954F49DFD
Old 05-04-2006, 10:11 PM   #8
IronMonkeyL255
Member#: 38120
1991 Rio Red
Legacy Turbo
The door panels are held in with 2 screws apece and a bunch of little trim snap thingies along the perimeter.
One screw is behind a little plastic cover below the arm rest while the other is under the power window switch plate. It's a little difficult to get out, but be gentle in your prying and it will pop out. there are basically 2 clips holding it in, one at either end.
After that, just gently pull off the door panel (a small prybar helps).
If your doing front speakers, be aware that you may need spacers if the speakers are too deep, otherwise they will hit the windows when they are rolled down.
Installation is reverse of removal.
IronMonkeyL255 is offline   Reply With Quote
Old 05-05-2006, 12:30 AM   #9
35th
Member#: 105239
2004 Red-ish Legacy
The speakers have a 2.25" mounting depth, would you recommend spacers and if so where can I get them?
I bought 2 sets of AUDIOBAHN AS65Q 6.5", anyone have any experience with these?
Old 05-05-2006, 01:30 AM   #10
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
For most decent speakers, you WILL need spacers for a Subaru door. They are VERY shallow doors, and the window usually hits the magnet.
Cheaper speakers don't normally require the spacers though. But with Audiobling, you probably will need a spacer.
Best way to tell, is put the window down with the panel off. You either want to put the window all the way down, or slightly better, is to put the very bottom of the window in the center of the speaker hole. Then push the speaker in. You'll be able to tell if it hits the window easily then.
Speedwagon is offline   Reply With Quote
Old 05-05-2006, 04:28 PM   #11
35th
Member#: 105239
2004 Red-ish Legacy
Thanks to all of you for your help, I'm going to try installing the stereo this evening.
Old 06-12-2006, 02:23 AM   #12
RusEvo
Member#: 82000
1995 Legacy
Mines just an old 1995 Legacy but you have to undo screws on the centre consol & then work forwards. Also you need to unscrew the cup holder above the stereo.
RusEvo is offline   Reply With Quote
Old 06-12-2006, 03:22 AM   #13
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
If you are going for very good sound quality, well... I'm sorry to hear about your purchase.
If you are looking for something a bit better than stock, well... congratulations, you got what you wanted!!!
How much did you pay per pair?
janikphoto is offline   Reply With Quote
Old 06-12-2006, 03:26 AM   #14
janikphoto
Member#: 10471
2000 BMW Z3
YIKES!!! I just googled those bad boys... Here's a hint for anyone with less than a hardcore soundquality competition stereo system:
do NOT buy three-way speakers. ever. The extra tweeter is a waste and it just winds up blocking even more of the mid...
But, hey... those are STILL an uprade from stock, so no worries.
Old 06-12-2006, 09:35 AM   #15
GTWagon_Phreak
Member#: 95645
2006 LGT Stg2 5MT
While I was still on the low-end of speakers back in the day, I was using Sony 6x9 2-ways and tried Pioneer 6x9 3-ways (back of my 93 Concorde at the time). The Sony's had really good bass for just a pair of 6x9's, but the Pioneers had much clearer mid-range sound and the high was a bit sharper as well. Bass wasn't as plentiful, but still not bad at all.
There may be no point to 3-ways in a high end configuration, but those not wanting to spend hundreds upon hundreds on their stereo (as I did when I got my BK) it might be a better alternative.
Old 06-12-2006, 11:20 AM   #16
35th
Member#: 105239
2004 Red-ish Legacy
Well I only put 1 set in and they are a major improvement over factory and the Infinity Ref. I had in my Rs. I'm hearing things on cd's that I never knew were there.
BTW I got the 2 sets for $115 shipped, but I have to sell the second set since it will be way too much work to put them in the rear doors. I'll pick up a set of 5.25s and be happy.
Old 06-12-2006, 06:34 PM   #17
janikphoto
Member#: 10471
2000 BMW Z3
well, that is a cheap price. I can only imagine they sound better than the stock, but I've heard the infinity ref before and they were excellent for the price.
My favorite two-ways ever... a/d/s made some, but they were DEEP and hard to fit in japanese doors.
I strongly suggest you keep the other audioblah's and put them in the back doors too. One thing that can really improve sound quality is matched speakers. The sound will be more uniform.
Even if it is a bit of work, it will improve the sound that much more over a set of mismatched spkrs. remember, every model of spkr has a different frequency response, and though sometimes a different brand or model can complement the first pair, they usually just end up clashing...
STi stereo install question... David03WRX Car Audio, Video & Security 10 04-28-2004 10:39 AM
Stereo install questions Ruff Car Audio, Video & Security 5 07-10-2003 04:51 PM
novice stereo install questions in WRX PeeHoLe Car Audio, Video & Security 2 04-28-2002 11:23 PM
Some '96-99 Legacy specific stereo install questions Patrick Olsen Car Audio, Video & Security 3 07-17-2001 12:54 PM
Some '96-99 specific stereo install questions Patrick Olsen Legacy Forum 4 07-16-2001 12:19 AM
