Old 05-04-2006, 09:35 PM   #1
ASpec818
Member#: 37059
03 WRX
World Rally Blue
Default fuel pump install quick question!
I'm in the middle of my walbro fuel pump install into my 03 wrx. I noticed that the new walbro fuel pump's hardline that stick out the top (the metal nipple thing) of it would "butt up" against the stock fuel hardline's metal nipple. there is basically no gap between the two where you connect em. will this hinder fueul delivery/performance or cause any problems?
The stock fuel pump's hardline is about 1.5 inches away from the other line.
ASpec818 is offline   Reply With Quote
Old 05-04-2006, 10:18 PM   #2
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
I just cut the hose shorter and slid it up onto the hard line and put the pump right against the hard line ... Slid the hose down over the pump niple and clamped it like that. No problems in over 3/4 of a year it's been in.
wrxdrvr is offline   Reply With Quote
Old 05-04-2006, 10:51 PM   #3
sixpack subaru
Member#: 64974
1995 WRX,APEXi,HKS,$
Faded, Stonechipped Red
You may get some very fine metal/plastic particles from the pipes rubbing together due to vibrations etc but that's what the filters for....
sixpack subaru is offline   Reply With Quote
Old 05-31-2006, 12:25 PM   #4
prspect06
Member#: 33223
2003 '03 WRX Vf39
blue pearl
Is this the gss341 pump? Isn't the 342 a direct bolt-on that requires no modification?
prspect06 is offline   Reply With Quote
Old 05-31-2006, 12:41 PM   #5
ChgoJay
Member#: 71722
That is a common question with the walbro. It will work fine.
ChgoJay is offline   Reply With Quote
Walbro 255LPH Fuel Pump Installation.. Few simple questions.. xmystikx Newbies & FAQs 2 11-11-2006 04:27 PM
Turbo, Injectors, Fuel pump install question Happy_Days Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 02-03-2005 11:08 PM
WRX Injectors and Fuel pump installed have 2 questions 99SubRs Normally Aspirated with bolt-on Forced Induction Powertrain 1 10-04-2002 10:59 AM
Fuel pump install and nylon ties question Wombat North Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 07-20-2002 11:36 PM
Fuel pump install question roybfr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 05-12-2002 03:22 AM
