Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 05-04-2006, 11:29 PM   #1
kinger
Member#: 49328
2004 WRB/Gold STI
Default Port and Polished heads
What vendors are good and what is a good value on the service? There are lots of different 'levels' out there. Just fishing for everyones opinion. Thanks!
kinger is offline   Reply With Quote
Old 05-05-2006, 02:26 PM   #2
ejsportcom
Member#: 88905
cobb does very nice work you should check them out, they have alot of info on their site.
ejsportcom is offline   Reply With Quote
Old 05-05-2006, 08:54 PM   #3
testes1010
Member#: 47145
2012 Gas Saver
my jdm v8 heads are at Crucial getting P&P'd, 3angle valve job...Helix cams & valvetrain w/ 1mm over Supertech valves...
testes1010 is offline   Reply With Quote
Old 05-05-2006, 09:22 PM   #4
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
Cobb's machine shop does nice work, if you want who does cobb's work contact pro machine in salt lake, or ask ron at axis about his machinist here in salt lake too.
car_cursed is online now   Reply With Quote
Old 05-05-2006, 09:28 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
gruppe-s
Old 05-05-2006, 09:49 PM   #6
Blackboxracing
Member#: 90106
how much power could you expect to see with p&p your heads? i realize i will vary with power but i am just interested in a ballpark number for an ihi turbo/meth setup
Blackboxracing is offline   Reply With Quote
Old 05-05-2006, 09:54 PM   #7
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
i would say with just pnp, and no cams, around 20hp.
Old 05-05-2006, 09:54 PM   #8
Silverpike
Member#: 92399
This is a very good question. I am used to seeing comparisons of headwork by seeing photos of the finished heads. I have seen enough headwork to be a good judge of what works and what doesn't.
I am surprised that none of the major subie vendors have released any information about their headwork. No photos, CFM charts, or dyno plots. I have seen some real low-rez pics, and some anecdotal info, but nothing that constitues real information.
What does it take to get real data here on NASIOC?
Silverpike is offline   Reply With Quote
Old 05-05-2006, 09:57 PM   #9
testes1010
Member#: 47145
2012 Gas Saver
Crucial supplied me numbers w/ modded WRX heads....although at the time I do not believe they had p&p'd any big port heads...
Old 05-05-2006, 10:54 PM   #10
Blackboxracing
Member#: 90106
agreed, i would love to see a cfm chart comparison of jdm heads, worked heads, stockers......
isnt it worth a the sales to vendors to supply info?? and those of you with worked heads, any numbers? (haha i know som1 is gunna tell me to search, but i really havnt had much luck)
Old 05-06-2006, 12:17 PM   #11
ejsportcom
Member#: 88905
cobb and axis both have numbers on their sites, you just have to look for them.....
Old 05-06-2006, 06:40 PM   #12
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
Dan curves are ported wrx heads
Pat are semi ported jdm v7 heads
Pat1 is stock v7
pa1 is multi angle valve job?
pat2 is multi angle valve job+pnp
pat3 is pat2 with more pnp of heads
Heads ported at DPR racing in Torrance. Dan does fantastic work and is a very knowledgable person. He still needs to add the larger valves as well
petawabit is offline   Reply With Quote
Old 05-06-2006, 10:53 PM   #13
Blackboxracing
Member#: 90106
awsome post
Old 05-06-2006, 11:09 PM   #14
Jeremy@Cobb
Member#: 106514
I'm afraid you are mistaken. Our headwork/machining is done in house.. as we have our own valve grinder and tools. Note our heads are cnc ported.
-Jeremy.
Jeremy@Cobb is offline   Reply With Quote
Old 05-06-2006, 11:14 PM   #15
Beer
Member#: 114254
I know cobb does very very good work, but Cosworth does pretty good stuff too but of course your gonna pay for Cosworth's name aswell, but i can only attest to cobb's work because its the only one ive dealt with personally
Beer is offline   Reply With Quote
Old 05-07-2006, 02:30 AM   #16
ejsportcom
Member#: 88905
That makes all the difference, i don't care how well someone can port by hand, you will never match the consistancy of cnc. on that note when I'm done being broke, my spare set of wrx heads are going to cobb
Old 05-07-2006, 06:16 AM   #17
scooby-stu
Member#: 52890
Allhe name brands have a rep but also look into the ones that have the least issues and take a lot of pride in there work, Then you know for sure yours just aint just a production line type
scooby-stu is offline   Reply With Quote
Old 05-08-2006, 11:12 AM   #18
kinger
Member#: 49328
2004 WRB/Gold STI
-Jeremy.
What part of the ports are ported using the CNC machine, how does the bit get in there? Specfically the hard bend the one exhaust port takes to exit near the first port. Thanks
Old 05-08-2006, 02:32 PM   #19
car_cursed
Member#: 85327
1964 Miata
Hairdresser Red
okay, well last time i was at pro machine, there were heads there that said they were for cobb but that was before the move.
Old 05-10-2006, 08:40 AM   #20
Wagun
Member#: 106433
2004 WRX wagon
I'm sure someone will correct if I'm incorrect but I believe all porting jobs are first done by hand and a CNC machine is used to duplicate the best port job as determined by trial and error on a flow bench.
Wagun is offline   Reply With Quote
Old 05-10-2006, 06:25 PM   #21
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
RalliSpec in NJ uses a CNC program based on heavily ported v7 STi heads adapted for the WRX castings. I don't know the name of the shop that does the CNC work - but I do know it took almost 2 months to get my heads ported, the valves recessed, and the Crower cams installed - all for $1500. Since they recess the valves I didn't have to buy new buckets.
PeteDucati is offline   Reply With Quote
Old 05-10-2006, 06:57 PM   #22
303WRX
Member#: 35097
2002 WRX Sedan
When you say recess the valves, did they back cut the stems to shorten them?
303WRX is offline   Reply With Quote
Old 05-10-2006, 07:25 PM   #23
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
They didn't have to since the Crower's I had were the one's with the smaller base circle. But they will cut the stems or shave the buckets a bit if needed. All they did with mine was cut the valve seats.
Old 05-11-2006, 03:03 AM   #24
Hopper
Member#: 50829
When you cut your valves and seats the valve will sink in the head, reducing the valve to bucket to cam clearance. The base circle on the crower with smaller base circle is at .025 smaller than stock.
Cobb does not do there own CNC porting, Mike does it.
Hopper is offline   Reply With Quote
Old 05-11-2006, 11:55 AM   #25
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
As in Chapman?
port and polish heads living4surf South East Region Forum 1 09-27-2006 01:51 PM
port and polish heads? 93subi Normally Aspirated Powertrain 20 10-06-2005 03:47 AM
Socal ported and polished heads, Sard, Cusco, Sti, 350 hp package, gfb, and more! Turbo Juice Private 'For Sale' Classifieds 45 07-28-2005 05:55 PM
Ported and Polished heads redhat778 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-22-2004 08:27 PM
ej22 ported and polished heads 4sale dreromeo Private 'For Sale' Classifieds 1 12-13-2003 03:28 AM
