Old 03-02-2011, 08:56 PM   #1
Stealth_RS
Member#: 95677
2004 WRX
Default First enging build need some noob advice W/ Pics
Alright long story short my 140k miles engine developed some serious knocking in my last AutoX
so I bought this used 35k short block want to know if there is anything I should look for before I go ahead and swap it with mine. Planning to send the heads to a machine shop to have them looked at.
Block came with water and oil pump, I was thinking of doing 08 oil pump and new water pump. Should I run the the ones on the block or new ones?
here are pics. All advice will be appreciated
Also I have read many post i could find about builds, just looking for some direct advice.
Stealth_RS is offline   Reply With Quote
Old 03-02-2011, 09:26 PM   #2
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Since you bought the block used you have no idea if the ringlands are ok or not. Since it is out i would take out the pistons and inspect them, and the bearings, and if they are stock i would put them in the trash and install some nice forged ones. Also get a set of ARP head studs since the heads are off. Also change the water pump to a Gates one and inspect the pullys.
Old 03-02-2011, 10:06 PM   #3
jamal
Member#: 71875
98 Legacy GT
my wheels fit
yes it's quite the risk to just throw it in there. At the minimum pull the pistons to check them but I wouldn't even recommend that. New bearings, new rings, and a clean and hone would only set you back about $500 if can do the assembly yourself. For another ~550 you get forged pistons (and I'd step up the bore size at that point to get a good fit).
jamal is offline   Reply With Quote
Old 03-02-2011, 10:34 PM   #4
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
That isn't always needed. The rest of it I do agree with. I'd have a machine shop measure the bore and then see if you can still have a good PTW clearance on 99.5mm. If so, he can still keep another rebuild in the block.
Old 03-03-2011, 03:26 AM   #5
alcoolaid
Member#: 134949
'07 SWP STi
Instagram | arthurlam89
When you're moving parts over from your original engine don't forget to clean out everything out and buy a new oil cooler!
Old 03-03-2011, 10:33 AM   #6
Stealth_RS
Member#: 95677
2004 WRX
Well engine did come with a 30 day warranty so I was not planning on tearing the block apart. I was going to clean it and install it as is.
So I should deff do new oil pump and water pump, also about the pulleys how do I know they are good or not?
Is a new oil pickup tube a must? was planning to install one for safety sake.
Also should I go with a 02-05 clutch or a 06-07 one? I have my 04 transmission.
Old 03-03-2011, 11:42 AM   #7
Homemade WRX
Member#: 33782
96 bastard child
which oil pan/pick up tube do you have?
Should be the old EJ20 style which isn't known to have the save issues as the EJ25 pick up tube.
Old 03-03-2011, 02:18 PM   #8
Stealth_RS
Member#: 95677
2004 WRX
the shortblock has the stock 07 EJ25 oil pan
Old 03-18-2011, 03:48 PM   #9
99imprezd
Member#: 198964
2015 WRX
crystal white pearl
You can remove the pistons without splitting the block to have a look...
99imprezd is offline   Reply With Quote
Old 03-18-2011, 08:45 PM   #10
stu
Member#: 25768
35R bugeye
Slowbaru
I would definatly take the pistons out and get a forged set. It would suck if you did all that work and it had a cracked ringland.
stu is offline   Reply With Quote
another build need some advice builtsubie Built Motor Discussion 1 08-11-2010 06:06 PM
First Subaru build..... have some questions blacktyper01 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-03-2010 08:33 PM
Alright, some Guru insight please. I've searched, and need some direct advice. NorCalEnthu Newbies & FAQs 7 05-10-2007 07:58 PM
Need some info/advice from the build engine guru's JeffrWRX Built Motor Discussion 1 01-16-2007 04:00 PM
Building a new PC... need some hardware advice dr_wheel Off-Topic 19 04-25-2006 10:22 PM
