Old 05-13-2006, 05:02 AM   #26
bugeyes
Member#: 64494
2001 V7 sti
Lots of money for little gain!
I had a personal discussion with Rigoli regarding heads when I was building my current engine. His advice came down a single line of recommendation-
"use sti version 5/6 heads (pre avcs), they have large ports. Give them a service and clean and throw them on with sti ver 5 cams. We have guys running 10's with them"
That was straight from the man.
When I asked about oversized valves and porting he said "dont bother".
bugeyes is offline   Reply With Quote
Old 05-13-2006, 10:06 PM   #27
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
I don't know much - but I do know ported Subaru heads flow around the same as some heavily ported eight cylinder SB Chevy heads. Considering we're aiming for eight cylinder power with a motor half the size I'm gonna disagree with Rigoli. And what constitutes "Lots of money for little gain!" Some have claimed 30whp gains with just head work - and no one has really done any clear tests regarding cam shafts.
PeteDucati is offline   Reply With Quote
Old 05-15-2006, 09:46 PM   #28
djviper
Member#: 107276
99 V.R.Special
WRC blue
so on the basis of one mans word your going to dis miss the advice and expertiese of everyone else?! it is widly regarded that scooby heads need work to flow above 400whp, yes you can hit 10's on a cleaned up head but youll be over working the turbo, that means its working harder for less!
djviper is offline   Reply With Quote
Old 05-16-2006, 03:15 AM   #29
Uwish
Member#: 63471
2004 MY05. 331kw atw
Crystal Grey
Guys, Rigolis ( TRP ) have the fastest rex in the world.
8.3 is a very good reason to listen to the man.
They know there ****!
I have also been told the same thing.
Thats why Im weighing up what do do with my V8 STI AVCS heads I have sitting on the garage floor
Damn subbies!
Uwish is offline   Reply With Quote
Old 05-16-2006, 09:40 AM   #30
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Exactly.
Listen to the misinformationet gurus, not the guys out there wrenching on the fast cars
Both myself and Nathan from TXS (nmyeti) posted a looooong time ago that the stock WRX heads flowed well enough for >500hp.....but the camshafts need to be replaced to support that.
S.
n2xlr8n is offline   Reply With Quote
Old 05-16-2006, 09:44 AM   #31
BALISTC
Member#: 24432
M800, TD06, EJ207
Originally Posted by Hopper
When you cut your valves and seats the valve will sink in the head, reducing the valve to bucket to cam clearance. The base circle on the crower with smaller base circle is at .025 smaller than stock.
My custom camshafts were a totally different base circle to the AVCS cams that came out of the complete STi heads that I bought, so I had the valve seats machined a bit, and stellite applied to the tips of the valves to extend them (ever so slightly, about 10 thousands of an inch), to set the clearances correctly.
I got the heads for really cheap, and doing the prep work on the valves and seats was cheaper than buying all new buckets to set the clearances correctly!
I also had the ports deburred and mildly ported, the splitters were knife edged too. They sit on top of a V7 Spec C EJ207.
The motor is still being run in. In combination with the cams, I've never felt so much bottom end torque from a 2 litre engine, even with the break-in tune in place!!
BALISTC is offline   Reply With Quote
Old 05-16-2006, 10:06 AM   #32
Shabib67
Member#: 61749
Off-topic anyone know how much crucial racing charges for head work? Second im thinking about buying v8 spec-c-ra heads and slapping them on to my ej257. What setup will make more power.
Stock Heads
Springs+Retainers+Shimless buckets
PnP + 3 angle valve job
DPR Stage 3 AVCS Cams
or
v8 Spec-c-ra heads
PnP+3 angle valve job
Shabib67 is offline   Reply With Quote
Old 05-16-2006, 02:49 PM   #33
djviper
Member#: 107276
99 V.R.Special
WRC blue
Originally Posted by n2xlr8n
Exactly.
S.
so 500 crankhp or 400 whp then?!!
Old 05-16-2006, 03:47 PM   #34
InfamousDX
Member#: 25413
Stock Heads
or
v8 Spec-c-ra heads
They have prices in their original vendor for sale thread about coatings and headwork. Or email them because Jeremy is quick like a fox.
Old 05-16-2006, 06:59 PM   #35
Hopper
Member#: 50829
If sinking the valves is too much you can install lash caps, or if your just installing regrind cams you can use the lash caps.
Iím glad to hear that youíre set up is working, keep us informed, maybe even a dyno pull with your boost graphed on the dyno sheet.
Hopper is offline   Reply With Quote
Old 05-16-2006, 08:32 PM   #36
BALISTC
Member#: 24432
M800, TD06, EJ207
I suppose lash caps were an option, but it wasnt too hard to put .01 of an inch of stellite on the tips of the valves whilst the heads were apart
Do the lash caps just sit on top of the valves or are they "glued"? I dunno if I'd want to risk having those if they are just placed on top of the valves, I already broke a shim in the head running too much anti-lag, and I went shimless buckets so I wouldnt have the same problem again...ie, no bits to float around if the antilag held the valves open again!
Old 05-16-2006, 09:45 PM   #37
burnin4
Member#: 59764
10 sec STi
10 sec Z06
I recently purchased a cobb stg2 block with a few upgrades (coated pistons, prof series bearings) as well as their stg2 head upgrade. I will be posting dyno results in 2 weeks. I look forward to seeing the benefits of a mild p&p.
burnin4 is offline   Reply With Quote
Old 05-16-2006, 09:49 PM   #38
700hp
Member#: 104164
'95 Impreza 800+hp
9.1 152mph
Damn subbies!
Yea, and i'll guarantee that the car you speak of that ran that time has extensive head work done to it. Its all about what you want to accomplish. My car made 678whp at 28psi with a 35r and this was only accomplished with extensive head work. I guarantee that at that same boost level with no head work it wouldn't have made over 600whp.
700hp is offline   Reply With Quote
Old 05-16-2006, 09:54 PM   #39
burnin4
Member#: 59764
10 sec STi
10 sec Z06
do you think your cams had anything to do with the increased power?
Old 05-16-2006, 10:00 PM   #40
700hp
Member#: 104164
'95 Impreza 800+hp
9.1 152mph
the car was never on the dyno before it had cams so i have no comparison #'s but Phil from Element tuned the car and he said that he has never seen a 2.5 with a 35r on put out so much power. He said that it had EVERYTHING to do with the heads.
This was my set-up if it does anything for you
272 cams
no AVCS
Jun adjustable cam gears
oversized Ferrea valves
Double Ferrea valve springs
Lots of porting
Old 05-16-2006, 10:18 PM   #41
djviper
Member#: 107276
99 V.R.Special
WRC blue
you can run the wildest cams, but if the heads cant flow the air theres no point!
interestingly 700 i was looking at the jun train, just trying to work out if there worth the rather tasty price!
Old 05-16-2006, 10:25 PM   #42
kinger
Member#: 49328
2004 WRB/Gold STI
I'm going to try locally doing a set and try to post some data on before and after.
kinger is offline   Reply With Quote
Old 05-16-2006, 10:48 PM   #43
djviper
Member#: 107276
99 V.R.Special
WRC blue
http://forums.nasioc.com/forums/memb...oster&t=172110
ask andy! i think being in the top ten fastest he must know his shizzle
Old 05-17-2006, 12:40 AM   #44
Member#: 106514
Originally Posted by kinger
What part of the ports are ported using the CNC machine, how does the bit get in there? Specfically the hard bend the one exhaust port takes to exit near the first port. Thanks
I will take detailed pictures of the ports, when I get back from the Wicked Big Subaru Meet. You would be surprised what a 5 axis CNC can do along with the small bits.
Jeremy.
Jeremy@Cobb is offline   Reply With Quote
Old 05-17-2006, 12:47 AM   #45
Member#: 106514
You are exactly right.. looking at a flow chart you are comparing flow vs lift. On our subaru heads (unported or ported) after a certain lift, larger cams will not gain any power but gradually move the powerband towards the right.
-Jeremy.
Old 05-17-2006, 01:33 AM   #46
Hopper
Member#: 50829
Jeremy,
Would you mind posting your flow charts for a stock WRX head and your Ported CNC head? At what test pressure? Iíd like to see the difference, if you donít mind. Could you share your port volume and combustion chamber volume also?
Old 05-17-2006, 01:40 AM   #47
djviper
Member#: 107276
99 V.R.Special
WRC blue
you dont expect much do you hooper! why not just ask for the technical disc for the cnc machine?
Old 05-17-2006, 10:13 AM   #48
InfamousDX
Member#: 25413
700hp... what heads did your worked ones start out as.. USDM STI?
Old 05-17-2006, 11:06 AM   #49
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Maybe they do it differently across the pond, but over here, most tuners are pretty open with their numbers on anything they are selling to the general public. And most customers get a copy of the bench flow numbers with their heads when they arrive. I know I did with mine. Now, if I were building a race engine, I may be wary to release my #'s, but on a stage I or stage II port job, it helps you sell product...
According to the numbers I have seen from Cobb, EJ205 heads, stock, flow around 245cfm intake and 170cfm exhaust at .4 lift, at 28", IIRC. These may be off by 5-10cfm because I am pulling off an old chart, but I am sure Jeremy will correct me if I am way off. I don't have after numbers, but at least that gives you a starting point...
And if you guys were paying attention to what Rigoli said, he was talking about using Ej207 v5 or v6 STi heads in stock form. These heads flow WAY better than the EJ205 heads. To get those kinds of numbers from Ej205 heads, you must port them.
Or, and I know that this is blasphemy around here, use DOHC NA Ej25 heads. They outflow Ej205 heads by about 10%, which is in the neighborhood of what a mild Ej205 port job will get you. Xephyr, and a handful of other people, have broken 400whp on those heads(with an Ej257 bottom end). It will require changing the manifold, and fuel rails, but anyone looking for those power levels is changing the rails anyways, and also likely using a front mount, so intake plumbing is a non-issue. It's very easy to tap the back of the heads for the oil and coolant since they are pretty much based on the Ej20K head castings, and just need to be milled out and tapped for threads. They already have the casting for the placement of those items. This is not to say they are the same heads, but they are based on them, and would be a viable low cost alternative to $1500+ worth of port work. And V3 HKS STi cams are a direct drop in...
Old 05-17-2006, 05:08 PM   #50
burnin4
Member#: 59764
10 sec STi
10 sec Z06
-Jeremy.
which cams would you suggest for the cobb stg2 block/stg2 head p&p?
port and polish heads living4surf South East Region Forum 1 09-27-2006 12:51 PM
port and polish heads? 93subi Normally Aspirated Powertrain 20 10-06-2005 02:47 AM
Socal ported and polished heads, Sard, Cusco, Sti, 350 hp package, gfb, and more! Turbo Juice Private 'For Sale' Classifieds 45 07-28-2005 04:55 PM
Ported and Polished heads redhat778 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-22-2004 07:27 PM
ej22 ported and polished heads 4sale dreromeo Private 'For Sale' Classifieds 1 12-13-2003 02:28 AM
