Old 05-05-2006, 07:14 PM   #1
vica153
Member#: 76586
1994 GF6
Default Electrical/Blower problem, ......ok maybe it is the resistor.
My blower stopped working a while back and I am just now getting around to looking at it.
I tested the blower motor and it works fine.
The blower resistor seems fine.
The problem is power, there isn't any getting to the blower. (Well .13Volts is..)
There isn't any getting to the resistor. (.2 volts....)
The ony place I can find power is if I unplug connector the back of the speed selector. Then I can get power between the far left and far right wires.
I have no wiring diagram. Should there be power at other parts of the connector?
Any ideas?
vica153 is offline   Reply With Quote
Old 05-05-2006, 07:55 PM   #2
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
you did check all the fuses right?
Old 05-05-2006, 08:09 PM   #3
vica153
Member#: 76586
1994 GF6
Old 05-05-2006, 08:32 PM   #4
vica153
Member#: 76586
1994 GF6
Does 0 resistance for any combination of 2 of the 4 leads mean the resistor is broken?
I kinda figure it does...?
Old 05-05-2006, 08:49 PM   #5
matt7102
Member#: 12051
1999 Impreza
That Silver color
Default Resistor Repair
It has been a few years since a leaking windshield fried step 4 on my resistor- this is how I fixed it-The resistor has a protective 'screen' around it. Carefully pry it open to allow access to the solder contact- the solder melts away as a fail-safe. I resoldered mine, all is well.
HTH,
Matt7102
matt7102 is offline   Reply With Quote
Old 05-09-2006, 10:18 PM   #6
vica153
Member#: 76586
1994 GF6
With the resistor in, only .13 volts is getting to blower if the switch is on 1,2,3,or4.
With the resistor out there is no power getting to the blower unless the switch is on 4, then there is .13 volts again.
So it seems to me that power is the issue not the resistor.
What else could have crapped out? Or is it really just the resistor and it will magicly power the blower if i replace it?
Old 05-09-2006, 10:43 PM   #7
vica153
Member#: 76586
1994 GF6
Crap. Now my running lights will not shut off. Its like there is a mouse going thru my wiring harness wire by wire.
Old 05-09-2006, 11:47 PM   #8
avk
Member#: 17252
'06 WX8
59E
If there's no power at any setting, it could be the relay. You're testing it with ignition on, right? The lights are on 'cause you flipped the little switch atop the steering column while fussing around.
avk is offline   Reply With Quote
Old 05-10-2006, 11:31 AM   #9
vica153
Member#: 76586
1994 GF6
DOH! I remembered the switch right after I posted. hahahah
Anyway, back to the blower. Yes I'm testing it with the ignition on.......I guess after the stupid running light question you have to ask things like that.
Where is the relay?
Old 05-10-2006, 02:10 PM   #10
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
uh, if you unplug the resistor there will be NO power at the blower motor regardless of what switch setting. The .13v you are seeing is not power, it's EM Field interference. You need to check for power @ the resistor connector.
Old 05-10-2006, 02:30 PM   #11
vica153
Member#: 76586
1994 GF6
At the resistor there are 4 wires. There is about .2 volts at a wire, which wire it is varies with where the speed selector position. So i seems the selector switch is working fine too.
So somewhere in between the switch and the blower the voltage is being lost......
Relay maybe? Where is this relay?
Any Ideas?
Old 05-10-2006, 02:33 PM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
sounds like a relay or fuse issue to me, but i don't have a wiring diagram for that car, sorry
Old 05-10-2006, 02:46 PM   #13
vica153
Member#: 76586
1994 GF6
I was looking at the diagrams of the hvac system and I was wondering about the "Thermo Amp", i think it sits just above the resistor. Anyone know what it does?
Old 05-10-2006, 03:04 PM   #14
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
That is probably the control module for the AC temperature sensor. The sensor is located in the evaporator, it connects to the module which determines when to cycle the compressor when the AC is running.
Old 05-10-2006, 03:52 PM   #15
vica153
Member#: 76586
1994 GF6
Wooo for air conditioning! It was the relay. Its just above the fuse box. Removing the fuse box and plastic peice below steering wheel allows you to get at it pretty easily.
<<<<<<<<<<Slightly less noobish now.
Dash Cluster LIghts not working. Haynes Wiring Diagram Isn't helping! dimwittedmoose Electrical & Lighting 0 11-27-2009 07:06 PM
Need wiring diagrams please! parker_is_neat Subaru Conversions 0 07-08-2007 02:41 PM
EJ20H wiring diagrams. please help snowman4us Subaru Conversions 2 01-17-2006 01:45 AM
Wiring diagram please subbyspeed Normally Aspirated Powertrain 1 08-07-2005 10:02 AM
is the jdm wiring diagram different from the usdm one? D Spec Dc2 Subaru Conversions 4 06-11-2003 11:58 AM
