Old 05-05-2006, 06:50 PM   #1
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
Default cylinder misfire?
cylinder misfire...you guys think it could be the spark plug wires? coilpack? what else do you guys think...spark plugs were done recently but im ordering the wires.
legacy1907 is offline   Reply With Quote
Old 05-05-2006, 07:21 PM   #2
scoobiegt
Member#: 57876
1997 GT Wagoon
Valve Adjustment Maybe?
scoobiegt is offline   Reply With Quote
Old 05-05-2006, 07:39 PM   #3
spdracr00
Member#: 65823
1996 Impreza L
Red
mine was caused by a bad headgasket... fixed the HG and the misfire went away...
spdracr00 is offline   Reply With Quote
Old 05-05-2006, 07:42 PM   #4
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
could definitely be the wires. did you do a full visual inspection? Any charred parts of the cable?
Wiscon_Mark is offline   Reply With Quote
Old 05-05-2006, 07:46 PM   #5
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
The wires are the same length... switch them front to back on the misfiring side, and see if the problem follows.
LetItSnow is offline   Reply With Quote
Old 05-08-2006, 08:34 AM   #6
tekkitan
Member#: 111884
2000 Legacy GT Ltd
White Birch
I had a cyl 1 misfire a couple months ago. I believe it ended up being the gas I filled up with (BP ew). I cleared the code and put something other than BP in it, havn't had a misfire since.
tekkitan is offline   Reply With Quote
Old 05-18-2006, 07:58 PM   #7
rossiski
Member#: 33670
2001 Legacy GT LTD
Titanium
I replaced my plugs and wires and my cylinder 1 misfire code went away.
My plugs had arc marks from the terminal end, across the porcelain, to the boot end.
rossiski is offline   Reply With Quote
Old 05-19-2006, 07:16 AM   #8
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
I had a misfire in the 4th cyl. I pulled the wire off and pushed it back on .. . cleared the code and havent see it for two weeks, BUT i did have my HGs give me grief just a few days ago. Hope its something small on your end.
vitai0 is offline   Reply With Quote
Old 05-19-2006, 11:24 AM   #9
tekkitan
Member#: 111884
2000 Legacy GT Ltd
White Birch
i had a 1st cyl misfire. i cleared it and have been fine. i think it was that darn BP gas i had to get in an emergency
Old 05-19-2006, 11:28 AM   #10
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
You say that like BP is some small station that everyone avoids. Any of the major oil companies have good gas, although sometimes an individual station is crappy.
Well, technically, almost ALL gas stations have the SAME gas, it's the additives that make it their own.
Speedwagon is offline   Reply With Quote
Old 05-19-2006, 12:01 PM   #11
tekkitan
Member#: 111884
2000 Legacy GT Ltd
White Birch
Actually, BP is know to have crappy fuel because of the additives they put in it.
Old 05-19-2006, 05:54 PM   #12
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
They put 10% ethanol into it. I've never had a problem with it, I fill up there all the time (because the station is a mile from my house).
Old 05-24-2006, 11:15 PM   #13
ooberdoob
Member#: 70418
Five Subarus later I
drive a lifted TJ.
i just got a flashing CEL.
IMMEDIATELY cut it off and rolled to the side thinking WTF?! considering a flashing CEL on any other car means CUT THE ****** OFF NOOOW and apparently not in this case. looked in the manual and it said misfire. so i said ok, i cranked it and eased home. like stayed on, but never flashed again. odd thing is, i never felt the misfire. perhaps it has to do with thte hard starting. i'm gonna replace the plugs tomorrow as well as read the codes. i can use the big stuff at school, should be cool.
ooberdoob is offline   Reply With Quote
Cylinder Misfire help skinart76 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 290 06-30-2008 11:53 PM
Cylinder misfire detected!? All 4 cylinders blublurwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 09-04-2007 10:05 AM
attn: Cylinder Misfire survey RiftsWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 75 11-09-2002 01:41 PM
3rd cylinder misfire update Avey Warranty Issues & SOA Problems 0 02-23-2002 12:33 AM
Sparkco Wires and 3rd Cylinder Misfire Yeoman Normally Aspirated Powertrain 3 02-08-2002 07:32 PM
