Old 05-05-2006, 08:00 PM   #1
kingpumba1
Member#: 48793
1998 Legacy Wgn FXT
white
Unhappy '98 Legacy GT wagon 5spd
My sic Legacy swap has been halted because I can't find a driveshaft w/o having to make a custom one. I have tried posting in the wanted forum but have had no luck since this is a specialty item. I am looking for a complete front and rear driveshaft assembly for a '98 Legacy GT wagon w/5speed trans. If anyone knows anything else that will fit, please post. I have checked the yards and most only have Legacy outback which is listed not compatible. I should be approx. 61.5" in total length after the splined input shaft.
Thanks in advance
kingpumba1 is offline   Reply With Quote
Old 05-06-2006, 12:41 AM   #2
Speedwagon
Member#: 19681
1998 Legacy Wagon GT
Green
I just reread your post, and I'm a moron. I think Sybir covered it pretty well below...
Speedwagon is offline   Reply With Quote
Old 05-06-2006, 01:42 AM   #3
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
If it's the driveshaft, there's absolutely no difference. The tranny and rear-end mounting points are comptible.
Try www.4subarusuzukikiaparts.com
Tell them Aaron from S2 referred you and you need something compatible with a 95-98 5 speed. Sedan and wagon are identical.
sybir is offline   Reply With Quote
Old 05-06-2006, 03:15 AM   #4
kingpumba1
Member#: 48793
1998 Legacy Wgn FXT
white
sybir: Thanks!! I will check them out in the AM and hope for the best. Everyone at the yards and salvage searches has told me that they list Subaru Outback and SUS as the same, but Legacy 2.5 wagon 5 spd was different, only the same for 97/98 Legacy, non-Outback/SUS? The shop doing the swap had an Outback shaft lined up but it measured too short.
Old 05-06-2006, 09:34 AM   #5
sybir
Member#: 4615
05 FXT/01 OB/97 OB
Yes.
An auto driveshaft will be about 3 inches too short, IIRC. A 5-speed driveshaft should be the same across the cars. Regardless, they should be able to get you a driveshaft from a 97 or 98 if you need it.
Old 05-06-2006, 12:01 PM   #6
kingpumba1
Member#: 48793
1998 Legacy Wgn FXT
white
Unless we got the driveshafts mixed up somehow (with an impreza?), we tried the original 2.5 auto shaft and it was about 5 inches too short total. I can't remember which was which but somethig like 2 inches rear shaft, 3 inches front shaft? Keep in mind we also swapped out the original rear diff to the newer FXT 5spd LSD rear.
Old 05-07-2006, 09:44 PM   #7
Speedwagon
Member#: 19681
Green
Well that might make a big difference there. It's quite possible the diff housing is shorter than the stock one. Did you measure the stock diff housing and compare it to this one?
If this one is shorter, you will either have to make a driveshaft, or swap the internals of the diffs.
Old 05-08-2006, 01:42 PM   #8
kingpumba1
Member#: 48793
1998 Legacy Wgn FXT
white
sybir: I spoke with Tony @ www.4subarusuzukikiaparts.com, he confirmed that the '97-98 5 spd Legacy GT is a unique driveshaft, not compatible with much else, especially the Outback. The have different p/n's and he doesn't have one, but is searching for me. Anywhere else?
Old 05-08-2006, 01:44 PM   #9
kingpumba1
Member#: 48793
1998 Legacy Wgn FXT
white
Forgot to add: I checked on the new FXT rear and it is the same as the Legacy GT's. So a 5spd should bolt right in, if I can find one........................
Old 05-09-2006, 12:14 PM   #10
Speedwagon
Member#: 19681
Green
I wonder what seperates it from the rest of the cars then. Why would it be unique?
Old 05-09-2006, 11:21 PM   #11
kingpumba1
Member#: 48793
1998 Legacy Wgn FXT
white
Not sure what the difference is but even the local Subaru dealer said it is a unique shaft and unfortunately they no longer offer replacements. I believe i found one in the mid-west. Hopefully the car should be tearing up the road this weekend if all goes well.
Old 05-10-2006, 12:54 AM   #12
se7en2.5RS
Member#: 89785
01 Impreza
MBP
The Legacy GT Wagon is a rare vehicle. And it's probably the longest vehicle Subaru has ever made. Meaning kingpumba would need a driveshaft from one of those cars... hope everything works out for ya.
se7en2.5RS is offline   Reply With Quote
Old 05-10-2006, 01:14 AM   #13
kingpumba1
Member#: 48793
1998 Legacy Wgn FXT
white
I wouldn't exactly say its rare??? I had no trouble finding them when I bought it back in NY 2 1/2 years ago. At the time, most of the ones I saw there where 5 spds and the one I liked happened to be an auto. Once its done, I'll try to post some pics. It's been in the shop for the last 2 months undergoing the full FXT drivetrain swap and performance upgrades, obviously modifying manny of the turbo piping to clear the chassis. It will definately be unique and I am hoping for 400HP to the crank on stock internals.
WTB: WRX wagon 5spd or Legacy GT wagon 5spd NZFOLDWRC SCIC Private Classifieds 31 02-05-2010 12:00 PM
'98 legacy gt auto/5spd swap clutchkith Transmission (AT/MT) & Driveline 5 01-03-2007 09:28 PM
'98 Legacy Gt wagon, in CO for $12,988? Speedwagon Legacy Forum 3 11-28-2002 03:00 AM
'98 Legacy GT Wagon, factory sub or jes Car Audio, Video & Security 4 08-14-2001 04:12 PM
What kind of a pillow mount will work on the rear of a '98 Legacy GT wagon? gtguy Brakes, Steering & Suspension 13 02-01-2001 06:55 AM
