Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-06-2006, 01:47 AM   #1
TheMainFrame
Member#: 104251
2002 Impreza WRX
Pearl Silver Metallic
Default Tuned Boost, Suggestions?
Hello,
Ive got a 2002 Silver WRX w/ full 3" TBE, UTEC rev 5.0, and a catless upipe.
Im running the stage 2 map and I modified the boost map to reach my desired 16.5 psi
Here is what I am logging after the modifications of the boost map.
Here is a chunk where I did 3000 to 6500 in 3rd gear. (i meant for it to goto 7k)
Code:
2997 -13.0 1.4   0  00    00   24.0 +11.6    4.2 ECU.   +0.0 ECU.   1.4
 2936 -13.2 1.4   0  00    00   23.7 +11.6   34.5 ECU.   +0.0 ECU.   1.5
 2934 -12.8 1.9   6  00    00   23.7 +27.9    6.8 ECU.   +0.0 ECU.   2.0
 2976 -12.0 2.0   7  00    00   20.4 +37.6    7.0 ECU.   +0.0 ECU.   2.0
 2984 -11.2 2.2  12  00    00   16.2 +39.8    7.0 ECU.   +0.0 ECU.   2.4
 2984  -9.1 2.4  15  00    00   14.9 +32.7   14.2 ECU.   +0.0 ECU.   2.5
 2994  -7.3 2.6  19  00    00   13.7 +32.7   16.8 ECU.   +0.0 ECU.   2.6
 3003  -5.7 2.6  19  00    00   13.1 +32.3   16.5 ECU.   +0.0 ECU.   2.6
 3049  -3.8 2.7  20  00    00   13.1 +32.0   16.5 ECU.   +0.0 ECU.   2.7
 3097  -2.6 2.8  22  00    00   13.5 +30.5   19.8 ECU.   +0.0 ECU.   2.8
 3121  -1.6 2.9  23  00    00   13.3 +29.0   20.9 ECU.   +0.0 ECU.   2.8
 3183  -0.2 3.0  28  10    00   13.3 +27.2   28.0 +24.8  -0.2 ECU.   3.1
 3242  +2.1 3.1  42  30    00   12.3 +21.3   33.7 +21.1  +0.7 268.00 3.2
 3326  +4.1 3.3  60  40    00   rich +15.5   40.3 +16.9  +1.0 325.00 3.4
 3387  +7.0 3.4  91  60    00   rich +11.7   52.5 +16.0  +3.6 400.00 3.6
 3486  +9.8 3.5 100  70    00   rich +11.3   60.8 +14.5  +3.8 425.00 3.6
 3568 +11.9 3.6 101  80    00   rich +10.9   62.1 +14.0  +3.9 425.00 3.8
 3687 +13.7 3.6 101  80    00   rich +11.3   63.7 +14.0  +3.8 425.00 3.8
 3796 +14.5 3.6 100  80    00   rich +12.0   65.5 +14.3  +3.7 425.00 3.9
 3903 +14.5 3.7 100  80    00   rich +13.3   66.3 +15.0  +3.7 425.00 3.8
 3977 +15.1 3.7 100  80    00   rich +14.3   70.3 +15.6  +3.6 425.00 3.8
 4040 +15.1 3.8 101  80    00   rich +14.5   73.5 +16.2  +3.4 425.00 3.8
 4161 +15.3 3.7 101  80    00   rich +14.2   77.3 +16.6  +3.2 425.00 3.9
 4208 +15.3 3.8 101  80    00   rich +13.8   74.6 +16.9  +2.9 425.00 3.9
 4334 +14.9 3.8 100  80    00   rich +13.9   79.4 +17.0  +2.9 425.00 4.0
 4380 +14.9 3.8 100  80    00   rich +13.5   80.6 +17.0  +2.9 425.00 4.0
 4456 +15.1 3.8 100  90    00   rich +13.9   80.3 +17.1  +3.0 425.00 4.0
 4553 +15.5 3.8 100  90    00   rich +14.3   83.5 +17.8  +2.9 425.00 4.0
 4668 +15.5 3.9 100  80    00   rich +14.7   82.7 +18.6  +2.7 425.00 4.0
 4728 +15.3 3.9 100  80    00   rich +14.9   86.8 +19.5  +2.3 425.00 4.0
 4844 +14.3 3.9 100  70    00   rich +15.7   88.7 +20.1  +1.5 425.00 4.0
 4938 +14.1 4.0 100  80    00   rich +17.2   85.6 +20.4  +0.5 425.00 4.0
 5027 +14.5 4.0  99  80    00   rich +18.1   88.9 +20.3  -0.1 400.00 4.0
 5027 +14.7 4.0 100  80    00   rich +18.7   89.2 +20.8  -0.1 425.00 4.0
 5274 +15.5 4.1  99  80    00   rich +19.6   89.7 +21.0  -0.4 400.00 4.0
 5257 +15.1 4.1  98  80    00   rich +19.6   92.7 +21.0  -0.1 400.00 4.0
 5393 +14.7 4.1  99  70    00   rich +19.6   95.1 +21.0  -0.3 400.00 4.0
 5428 +14.1 4.1  99  70    00   rich +20.9   94.2 +21.0  -0.5 400.00 4.1
 5537 +13.5 4.1  99  70    00   rich +22.3   95.2 +21.0  -0.6 425.00 4.1
 5564 +13.3 4.1  99  70    00   rich +22.2   91.8 +21.0  -0.7 400.00 4.1
 6038 +13.1 4.1  99  70    00   rich +20.2   93.7 +21.0  -0.8 400.00 4.1
 5807 +12.9 4.1  99  70    00   rich +20.3   97.3 +21.0  -0.9 400.00 4.1
 5797 +12.9 4.1  99  70    00   rich +20.6   92.5 +21.3  -0.9 400.00 4.1
 5920 +12.7 4.1  98  70    00   rich +21.0   98.6 +21.5  -0.9 400.00 4.1
 6006 +12.5 4.1  98  70    00   rich +21.3   97.5 +22.0  -1.0 400.00 4.1
 6060 +12.7 4.1  98  70    00   rich +21.7   96.5 +22.0  -1.0 400.00 4.0
 6172 +12.3 4.1  96  70    00   rich +21.9   93.7 +22.0  -1.1 400.00 4.1
 6195 +11.9 4.1  93  60    00   rich +22.5   96.8 +22.4  -0.7 400.00 4.1
 6230 +11.9 4.1  92  60    00   rich +24.2  ---.- +22.2  -0.8 400.00 4.1
 6410 +11.7 4.1  92  70    00   rich +24.9   95.2 +22.0  -1.3 400.00 4.1
 6447 +11.7 4.1  92  60    00   rich +25.2   94.7 +22.2  -0.8 400.00 4.1
 6510 +11.9 4.1  81  70    00   rich +25.8   97.8 +22.0  -1.5 377.50 4.0
 6242  +9.4 2.1   0  40    00   rich +11.0    6.2 ECU.   -0.1 276.00 1.8
 6184  +3.9 2.0   0  10    00   rich +10.9   10.7 ECU.   -1.7 ECU.   2.0
 5868  -2.2 2.0   0  10    00   rich +11.0   10.5 ECU.   -1.8 ECU.   2.0
 5611  -8.1 2.1   0  10    00   rich +11.2   10.6 ECU.   -1.7 ECU.   2.0
 5274 -12.0 2.0   0  10    00   rich +11.1   10.0 ECU.   -1.6 ECU.   2.0
Here is a chunk of my log when I gave it some hard throttle in 5th on the highway
Code:
2798 -10.2 2.2  11  00    00   14.1 +35.4   11.3 ECU.   +0.0 ECU.   2.2
 2791  -8.7 2.2  11  00    00   13.7 +34.8   12.6 ECU.   +0.0 ECU.   2.3
 2798  -7.7 2.3  12  00    00   13.3 +34.4   10.8 ECU.   +0.0 ECU.   2.3
 2801  -6.7 2.3  12  00    00   13.1 +34.1   12.5 ECU.   +0.0 ECU.   2.3
 2794  -5.9 2.7  36  10    00   13.4 +33.1   23.2 +31.5  -0.6 244.00 2.8
 2794  -3.8 2.8 102  10    00   12.8 +27.3   21.5 +28.9  -0.6 425.00 2.8
 2827  -1.4 2.9 101  20    00   12.6 +23.5   23.5 +25.2  -0.7 425.00 2.9
 2824  +1.5 3.0 101  30    00   12.7 +19.4   26.6 +21.8  +0.3 425.00 3.0
 2849  +4.3 3.1 101  40    00   12.1 +17.1   30.8 +18.8  +0.7 425.00 3.2
 2815  +6.4 3.2 101  50    00   rich +13.9   37.5 +16.0  +2.2 425.00 3.3
 2873  +8.6 3.3 101  60    00   rich +11.0   39.7 +15.4  +3.6 425.00 3.4
 2926 +10.8 3.4 101  70    00   rich +11.1   45.8 +14.2  +3.9 425.00 3.5
 2952 +13.1 3.4 101  80    00   rich +11.1   47.5 +14.0  +4.3 425.00 3.6
 2893 +14.9 3.4 101  90    00   rich +11.1   47.6 +13.8  +4.4 425.00 3.5
 2960 +15.9 3.4 102  90    00   rich +11.1   50.4 +13.6  +4.5 425.00 3.5
 2989 +16.4 3.4 101  90    00   rich +11.1   47.5 +13.9  +4.6 425.00 3.6
 2992 +16.1 3.4 101  80    00   rich +11.0   50.2 +14.0  +4.5 425.00 3.6
 3046 +15.9 3.4 101  90    00   rich +11.0   52.3 +14.0  +4.6 425.00 3.6
 3046 +16.1 3.4  98  90    00   rich +11.1   52.1 +13.6  +4.6 425.00 3.6
 3083 +16.1 3.5  96  90    00   rich +11.1   52.0 +13.7  +4.6 400.00 3.6
 3124 +16.4 3.4  96  90    00   rich +11.1   50.6 +14.0  +4.6 400.00 3.6
 3168 +15.9 3.4  96  80    00   rich +11.0   49.1 +14.0  +4.5 400.00 3.5
 3129 +15.5 3.4  96  80    00   rich +11.0   53.4 +14.0  +4.5 400.00 3.5
 3189 +15.3 3.4  95  80    00   rich +10.8   53.9 +14.0  +4.5 400.00 3.5
 3205 +15.5 3.4  96  80    00   rich +10.8   53.6 +14.0  +4.5 400.00 3.6
 3208 +15.5 3.4  95  80    00   rich +11.1   52.9 +14.0  +4.5 400.00 3.6
 3245 +15.7 3.5  96  80    00   rich +10.8   52.8 +14.0  +4.5 400.00 3.6
 3274 +15.5 3.5 101  80    00   rich +10.8   54.0 +14.0  +4.5 425.00 3.6
 3267 +15.7 3.4 101  90    00   rich +10.5   56.1 +14.0  +4.6 425.00 3.7
 3313 +15.9 3.5 101  90    00   rich +10.6   55.8 +13.7  +4.5 425.00 3.7
 3303 +16.4 3.5 101  90    00   rich +10.5   56.3 +13.6  +4.5 425.00 3.7
 3363 +16.6 3.5 101  90    00   rich +10.5   56.8 +13.7  +4.4 425.00 3.7
 3363 +16.6 3.5 101  90    00   rich +10.4   60.2 +13.7  +4.4 425.00 3.6
 3380 +16.6 3.5 101  90    00   rich +10.4   60.5 +13.7  +4.3 425.00 3.7
 3350 +16.6 3.6  95  90    00   rich +11.6   59.2 +13.6  +4.4 425.00 3.7
 3415 +16.6 3.5  29  90    00   rich +12.6   18.7 +13.8  +4.3 ECU.   2.3
 4025 +11.7 1.9   0  40    00   rich +30.9    7.7 ECU.   +0.5 ECU.   2.0
 4192  +5.3 2.0   0  00    00   rich +19.3   36.9 ECU.   +0.0 ECU.   2.1
 3968  -1.4 2.0   0  00    00   18.4 +11.4   36.9 ECU.   +0.0 ECU.   2.0
 3667  -7.9 2.0   0  00    00   24.0 +11.4   36.9 ECU.   +0.0 ECU.   2.0
 3370  -9.8 2.0   0  00    00   23.7 +11.5   36.9 ECU.   +0.0 ECU.   1.9
 3106 -10.2 1.9   0  00    00   23.7 +11.6   36.9 ECU.   +0.0 ECU.   1.8
I guess now I need to learn to tune the Fuel map and see if I can stop the richness in the run... Im not sure where to start tho...
Also why dident the boost make it to 16.5 in the 3rd gear pull but it had no trouble on the highway pull? And if i tune the 3rd gear run to include 16.5 wouldent the higway pull go higher then recommended?
TheMainFrame is offline   Reply With Quote
Old 05-06-2006, 08:56 AM   #2
bcblues
Member#: 17256
04 STi
Blue w/ custom bug splat
You really should have a wide band O2 sensor before you start tuning your fuel.
bcblues is offline   Reply With Quote
Old 05-06-2006, 12:51 PM   #3
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
You will make more boost in higher gears due to engine load. Thats perfectly normal that you make more in 5th than 3rd.
You want the factory O2 to read "rich" during the pulls because it will say that for any AFR leaner than ~ 13:1 because of its poor resolution. If it says anything but "rich" under power thats no good. You need to have proper equipment to tune the fuel such as a wideband O2.
Boost curve looks great, you are off to a good start.
cdvma is offline   Reply With Quote
Old 05-06-2006, 01:41 PM   #4
TheMainFrame
Member#: 104251
2002 Impreza WRX
Out of curiosity is this an expensive item for a quality unit?
Old 05-06-2006, 01:54 PM   #5
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Expensive is subjective but generally you are looking at ~ 300 for most units. They do get a lot more pricy but there are at least 3 or 4 picks in that range.
Old 05-06-2006, 03:05 PM   #6
AaronWRX
Member#: 7194
2011 997.2 Turbo
If you have utec you should ONLY consider a tuner or tuner pro.
The tuner with the VW sensor has been selling for right around 370 dollars.
AaronWRX is offline   Reply With Quote
Old 05-06-2006, 07:48 PM   #7
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Used is also a good option. I got a used Tuner pro w/Bosch used for 330 over a year ago.
Old 05-06-2006, 09:33 PM   #8
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Same here! Got my Tuner Pro for $350 with only 7K miles on it with the Bosch sensor. Works great with the UTEC.
Crazykev is offline   Reply With Quote
Old 05-08-2006, 04:20 PM   #9
xeve
Member#: 67088
2003 WRX
Hope I don't get flamed for going against the grain (and being a newbie), but I just got the LC-1 from Innovate and use it with the MPS UTEC Logger. Easy install (really easy) adn only $199 from Summit... Just a though.
Xeve
xeve is offline   Reply With Quote
Old 05-09-2006, 08:06 AM   #10
bcblues
Member#: 17256
04 STi
I have a normal TXS Tuner (not pro). I bought it used for $240. The nice thing about the TXS Tuner or Tuner Pro is that they will log AFR right in your UTEC log files, which makes it far easier to use as you tune. I think that there are some bridge programs to allow you to log directly into your UTEC logs while running a non-TXS wideband, but I have no expereience with them. Running a stand alone AFR is better than nothing (of course!), but FAR less useful than one which logs wideband AFR values right into your UTEC log. My 2 cents worth.
Old 05-12-2006, 04:56 PM   #11
JDM 3SGTE
Member#: 35479
another lc-1 user here. works well with both mpsuteclogger and UTI. logging from hyperterminal is a pain anyway. UTI ftw.
JDM 3SGTE is offline   Reply With Quote
Old 05-12-2006, 10:10 PM   #12
Crazykev
Member#: 93667
'03 Build'n a 2.12L
331whp/331wtq
Xeve
No flame here man It's all good!
Old 05-14-2006, 10:39 AM   #13
bcblues
Member#: 17256
04 STi
I have been using UTI as well. Nice program!
getting tuned, any suggestions before i go in? WRXout Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 09-28-2005 01:39 AM
UTEC, boost tuning, boost gauge vs map psi SJWWRX Engine Management & Tuning 2 07-09-2004 10:22 AM
getting tuned any suggestions? WRXout Engine Management & Tuning 1 07-03-2004 07:46 PM
Subaru Performance Tuning (SPT): Suggestions Needed! Samirr76 General Community 70 03-26-2004 08:06 AM
Subaru Performance Tuning (SPT): Suggestions Needed! Samirr76 Tri-State Area Forum 37 03-04-2004 05:03 PM
