Welcome to the North American Subaru Impreza Owners Club Sunday April 19, 2015
Old 05-06-2006, 10:17 AM   #1
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Default Tire size for WRX rim on Outback
I own a Outback limited that has 205/70/15 tires on them. Currently i purchased a set of wrx rims that i want to put a wider tire on. How wide can i go without rubbing? Has anyone tried yet? discounttiredirect.com says i need to get 215/60/16 or 215/65/16 . . but how about a 225? Will those fit w/out rubbin? Just wonderin..Thanks.
vitai0 is offline   Reply With Quote
Old 05-06-2006, 12:41 PM   #2
redgrocerygetter
Member#: 42044
1998 Legacy GT
when I had my 2002 WRX I put 225 on it. I'm not sure how that will fit on a legacy, but it does fit a WRX without rubbing.
redgrocerygetter is offline   Reply With Quote
Old 05-06-2006, 06:36 PM   #3
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Quick Silver Metallic
The 2000-2004 Outbacks run with 16" alloy rims with 225/60R-16 Tyres. I am not sure if these larger sized wheels will fit the earlier first generation outbacks though.
Your basic concerns should be will the new size tyre through your speedometer readings off, and under extreme driving manouvers / or under heavily loaded situations will you encounter wheel rubbing issues.
Jonathan is offline   Reply With Quote
Old 05-06-2006, 10:30 PM   #4
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
did you used to live in europe, because you have a few alternate spellings in your post (tyre, manouver). However, it says you are in MA (definitely not a european state)...
janikphoto is offline   Reply With Quote
Old 05-06-2006, 10:39 PM   #5
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
he's in MA, but I think he's from another country originally.
Wiscon_Mark is offline   Reply With Quote
Old 05-06-2006, 11:07 PM   #6
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Mars ?
Old 05-07-2006, 01:27 PM   #7
Jonathan
Member#: 4021
1999 Legacy GT Ltd
Using an internet tyre size calculator http://www.miata.net/garage/tirecalcold.html I came up with the following :
A 215/60/16 size tyre at 771 revolutions/mile would be closest to your current 205/70/15 tyres 767 revolutions/mile. A 225/55/16 would be 783 revs/mi.
Old 05-07-2006, 02:09 PM   #8
Wiscon_Mark
Member#: 94945
1995 Legacy OB 5MT
2003 Forester X 5MT
Mars ?
you were just sounding like a Brit, that's all
Old 05-08-2006, 12:26 AM   #9
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Default thanks
Hey thanks guys. . ill prolly stick with the 215/60/16 becuase it has a lot better tires choices than the others.
Old 05-08-2006, 06:06 PM   #10
strat81
Member#: 106641
psm
215/60/16 should be fine...
i have 215/65/16's on my wagon and have very minimal rubbing at full lock. my tires aren't street tires though.
strat81 is offline   Reply With Quote
Old 10-31-2006, 10:39 AM   #11
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Sorry to bring this back up but i wanna know who is running on WRX wheels with there lowered Legacy. And if so, what tire size you are using. I know there is a good tire selection for 205/55/16 because its the WRX oem tire size, but i would like to close the wheel gap and also have a wider stance, so 215/60/16 should work, says tire rack, but concerned with the drop.... Anyone running these by chance?
Strat81 - What tires are you running?
thanks,
m.
Old 10-31-2006, 10:58 AM   #12
redlegacygt
Member#: 82994
1997 Legacy GT
Rio Red
you'll prob. want to know spence's old setup from when he first bought the car.. i dont believe his new setup would work on your lowered car....
redlegacygt is offline   Reply With Quote
Old 10-31-2006, 11:03 AM   #13
spdracr00
Member#: 65823
1996 Impreza L
Red
thanks,
m.
man, i run stock 205/55/16's on my slammed outback, and i cant fit a wider tire in the rear, i could in the front and i guess if i rolled the rear fenders, but 205's are what i'm stuck with.
spdracr00 is offline   Reply With Quote
Old 10-31-2006, 11:51 AM   #14
vitai0
Member#: 103245
1967 912 STi Spec C
Ivory White
Well im still running the 205/70/15s right now on my wagon and there doesnt seem to be any rubbing, other than the slight tiny bit in the front at locked turns, but then again i have not had an alignment down yet either....
Old 10-31-2006, 12:56 PM   #15
b4wantab
Member#: 21293
05 OB Black Bean
1969 W-30
I have 215/55 on older RS rims, 7" wide, on A BH GT without any rubbing. I have 225/55 winter tires on stock rims, 6.5" wide, and rub in the front. No problems in the rear.
I am unsure how much of a drop you are talking about? I believe WRX and Legacy wheels had the same specs from 00-04, 16" X 6.5" wide.
Peace,
Greg
b4wantab is offline   Reply With Quote
Old 10-31-2006, 05:44 PM   #16
janikphoto
Member#: 10471
2000 BMW Z3
good thread. I've been wanting to pick up a set of 17" sti gold ten spokes for my 2001 outback, but I don't want to throw off the speedo. I'll be researching tire choices when I finally do this (probably soon, as the current set of tires are showing their age) and may need some help as well...
Street / Track tire size for WRX on 16" rims? tittykaka7 Motorsports 51 05-08-2010 08:58 PM
Bigger tire sizes for stock rims on an 05 WRX? RChampion Tire & Wheel 8 01-25-2010 02:30 PM
Tire Sizes for 2008 STI on BBS Rims. scoobbee Tire & Wheel 2 02-16-2009 06:17 PM
Correct tire size for 15" rims Paul Sakai Brakes, Steering & Suspension 0 09-22-2002 05:40 PM
