Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 05-06-2006, 02:07 PM   #1
flwrx
Member#: 35944
'03 v7/6mt/30r wrx
MBP
Default Best way to store heads/cams
Ive got some built heads I recently acquired as well as a new set of cams which arent installed in the heads.
These wont be going in for a few months....whats the best way to safely store them?
flwrx is offline   Reply With Quote
Old 05-06-2006, 03:23 PM   #2
Peeblesmx445
Member#: 92202
Sleep with them under your pillow
Peeblesmx445 is offline   Reply With Quote
Old 05-06-2006, 03:24 PM   #3
solarin006
Member#: 109975
wrap the heads up in a old towel or something so you don't get critters/whatever in water passages
cams I don't think it really matters. put them somewhere where they won't fall.
solarin006 is offline   Reply With Quote
Old 05-06-2006, 03:47 PM   #4
flwrx
Member#: 35944
'03 v7/6mt/30r wrx
MBP
shouldnt they be coated with oil?
Old 05-06-2006, 04:30 PM   #5
Lennon
Member#: 34821
02 built usdm2.o
v6 sti heads
put them on a key chain. i just threw mine in a box (wrapped in bubble wrap) and they sat in my garage until i used them...maybe a month or two.
Lennon is offline   Reply With Quote
Old 05-06-2006, 09:39 PM   #6
kinger
Member#: 49328
2004 WRB/Gold STI
Not as critical with as short of cams as we have but I used to store all my older longer camshafts straight up and down with a light lube of motor oil on them and wrapped and sealed in plastic or garbage bags. Worked good, if you don't lube they will rust by sitting out and you'll need some sctoch brite to take the rust off when you go to install them.
kinger is offline   Reply With Quote
Old 05-07-2006, 01:33 AM   #7
ejsportcom
Member#: 88905
i agree with this one, though mine are in my closet for now
ejsportcom is offline   Reply With Quote
best way to store stock TR enkies w/ RE92s. 06WRXTRacer Tire & Wheel 2 01-23-2007 11:47 AM
What is the best way to store your wheels/tires for the winter? Bankie Tire & Wheel 3 11-13-2005 10:30 PM
Best way to store an almost new tire? silvercharged Tire & Wheel 7 07-05-2005 06:30 AM
Best way to store tires for winter is. . . skiteton Tire & Wheel 17 11-30-2004 09:48 AM
best way to change cams? JonofScio Normally Aspirated Powertrain 11 08-24-2004 09:40 AM
