Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > UTEC
Old 05-06-2006, 03:24 PM   #1
INERT
Member#: 114309
Default Hickup/backfire on tip-in
When tiping in from idle my car has a hickup and some times makes a pop. It shows up in the logs as the ecu pulling timming for a split sec. Any ideas what would cause this?
mods:
utec
565's
20g
tbe
2.0
INERT is offline   Reply With Quote
Old 05-06-2006, 04:45 PM   #2
VWGrk1
Member#: 57882
2004 WRX
I had to lean out the 0% fuel column. It was too rich and the car would rev, almost pause at 1000 rpm and then continue revving. If you know anybody that can check your fuel trims, then you could see where your long term trim is. Should be +/- 5%
Why are you running a 20G on STi injectors? Do you have alky or something?
VWGrk1 is offline   Reply With Quote
Please post some tips on driving in the snow scrappydoo North West Impreza Club Forum -- NWIC 113 12-20-2008 05:53 PM
Stumble on tip in, low boost, slow to build.. ugh OvrClkdPmp Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-28-2006 12:10 AM
Backfires on my brand new car? Julio Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 04-24-2002 01:06 PM
Backfiring on MY00 2.5RS w/ MT Gadget6 Normally Aspirated Powertrain 10 05-02-2001 09:56 AM
Backfiring on Brand New RS 2.5 csmetana Technical Forum Archive 15 09-21-2000 12:28 AM
