View Poll Results: So which is more fun to drive and own???
02-05 WRX Stage 2 FTW! 58 46.03%
Damn, even a Stage 1 02-05 is more fun than that 06 lux-mobile 9 7.14%
Stock 06 WRX, bish! No replacement for displacement! 50 39.68%
Farking get a Marauder! 9 7.14%
Voters: 126. You may not vote on this poll
Old 05-06-2006, 04:07 PM   #1
Petrus
Member#: 71795
2006 Impreza WRX5spd
FREAKIN' BLUE!!!
Default 02-05 WRX at Stage 2 vs. 06 WRX Stock/ Stage 1 fun factor poll
So what's more fun? #'s torque specs blah blah blah, which car is more enjoyable to own and drive? People with experience in the matter are a plus
... BATTLE!
Petrus is offline   Reply With Quote
Old 05-06-2006, 04:11 PM   #2
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
I'm going from Stage 2 WRX to a 2.5L block (no AVCS) so I'll let you know in a few days, although I'll still be Stage 2 with the 2.5L block. I'm gonna make an educated geuss and go with the 06 WRX though.
wrxfactor is offline   Reply With Quote
Old 05-06-2006, 04:38 PM   #3
ScobyWRX
Member#: 49690
2006 WRX limited
Gray
I had a Stg 2 02 WRX and now I have a 06 limited and I think it is a better car in every way, it handels better the inside is nicer and the power is much improved I cant wait to get my AP
ScobyWRX is offline   Reply With Quote
Old 05-06-2006, 05:55 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
... BATTLE!
.........uuuummmmmmmmyagottabekiddingonthisimeanRE ALLY???????
Old 05-06-2006, 06:08 PM   #5
REX8
Member#: 24038
The 2.0l makes MORE lowend power... so the no replacement for displacement line is out.
Obviously the 06 has a lot of other things goign for it that the 2.0l doesn't...but the motor (in THIS case) is not one of them...
Old 05-06-2006, 06:10 PM   #6
REX8
Member#: 24038
Its MUCH improved over a stock WRX. Your stage II was more powerful...
Old 05-06-2006, 06:11 PM   #7
REX8
Member#: 24038
I'd still take an 06 in a heartbeat....
Old 05-06-2006, 06:15 PM   #8
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
Where did this chart come from? I find it hard to believe.
Snowphun is offline   Reply With Quote
Old 05-06-2006, 06:17 PM   #9
REX8
Member#: 24038
They are Cobb's dynos...laid over each other...
How could that be hard to believe? Its being forced a lot of boost in the low end to make that power.... Thats a STOCK 06 motor...
You can clearly see where the 2.0l gets boost shoved at it around 3k, where the 06 motor isn't nearly making as much (thats where the 2.0 takes that big jump...make perfect sense and you can feel it driving...)
Low 13's at 100+ sure as heck has to come from somewhere...
I would hope a modified 2.0 could hold its own against a stock engine...
Jump on the gas in a stock 06, then do it in a 2.0l. They feel fairly similar, the 06 just runs out of gas up top.
Done plenty of test pulls with a neighbors 06...the 2.0l on an OTS map is without question a near dead match through the low-middle RPMs for a stock 06...after that...I creep away
Again, I'd still take the 06...
If you want to see the stage II vs. stage II overlay, I have it from a guy on here...
Old 05-06-2006, 07:41 PM   #10
EnterTheDragon
Member#: 6511
I want to see
EnterTheDragon is offline   Reply With Quote
Old 05-06-2006, 07:41 PM   #11
waktasz
Member#: 86356
2015 s1000r
wheelie monster
The 06 is a better daily driver. Easier to drive in the city and in traffic because of the low end torque. It doesn't kick you in the ass when boost comes on strong at higher RPMs like my 05 did. A stage 2 06 WRX should be fun though
waktasz is offline   Reply With Quote
Old 05-06-2006, 08:36 PM   #12
Petrus
Member#: 71795
FREAKIN' BLUE!!!
hmmmm... for cheaper-ness and kick in the ass I think I'm going to have to go with the 02-03 then, fun > *
Old 05-06-2006, 09:01 PM   #13
EnterTheDragon
Member#: 6511
You missed the point, the kick in the ass happens because those models have no guts before the turbo spools up, where as the 06 has some go at low rpms.
Old 05-06-2006, 09:06 PM   #14
Snowphun
Member#: 1800
WRX /WRX/Cooper S
awd/awd/fwd
It's easy to find it hard to believe: the 2.5l car feels like it has better low end. I have a Cobb stage 2 MY02 and a stock MY02 and the low end is improved with the AP, but not to the point where it feels better down low than a 2.5l. I'm not saying it has more power, just that it feels like it does.
Old 05-06-2006, 09:18 PM   #15
totalburnout
Member#: 72861
Lightened flywheel + lightweight pulleys on the 2.0L block + Stage 2 map and parts = a feeling of more power down low.
In reality the power comes on faster downlow because of the uppipe, but the pulleys and flywheel get the revs up faster so you achieve power in the same range but you're quicker to get to this range.
***Add in port and polished stock headers and you'll get more low end and top end power, plus a more linear powerband.
***Add in an upgraded TMIC or FMIC and you'll get a more linear powerband and *MIGHT* (depending on engine management) see more boost that would give you more power and earlier.
***Add in a port and polished td04 turbo and a port and polished downpipe. Now you have all the bolt ons to get as much power as possible out of the stock turbo. After these bolt ons, if you want more power downlow or anywhere - you're going to have to start building the engine.
This is what I'm doing for my 2.0L block (minus the lightened flywheel atleast until my clutch goes and I'm down there anyway).
The 2006's will always have a handicap over us, because there's no replacement for displacement.
My ideal setup would be H6 or inline six with a quick spooling turbo, or a 2.5L block bored over to 3.0L - thats the only way that we'll ever make power downlow.
totalburnout is offline   Reply With Quote
Old 05-06-2006, 09:34 PM   #16
02wrbrex
Member#: 103061
98 Impreza EJ207
FJC
Originally Posted by totalburnout
My ideal setup would be H6 inline six with a turbo.
Um a horizontally apposed inline six. Doesnt make sense?
02wrbrex is offline   Reply With Quote
Old 05-06-2006, 09:44 PM   #17
EtoS
Member#: 102238
08 DGM STi
*RIP* 06 WRX TR
Wow comparing stock to stage 2. I wonder where the chart for stage 2 2.0 and stage 2 2.5 is and let's see where it stands then.
EtoS is offline   Reply With Quote
Old 05-06-2006, 10:43 PM   #18
HAL1
Member#: 58926
2013 WRX 5dr ISM
2011 Infiniti EX35
I really liked the thread title and was hoping to read more than just "I'd rather drive an '06". My view is that I have an '05 and am jealous of the '06 but I'm not going to trade it in, but after stage 2 on my '05 will I be just about as happy as to how compares with an '06?
HAL1 is offline   Reply With Quote
Old 05-07-2006, 12:22 AM   #19
totalburnout
Member#: 72861
h6 or* inline six
Old 05-07-2006, 12:24 AM   #20
totalburnout
Member#: 72861
Read the question.
It wasn't "Oh a 2.0L Stage 2 will make more power than a 2.5L Stage 2. It was what does a Stage 2 aka modified 2.0L feel like in comparison to a stock 2.5L.
There's no replacement for displacement. Of course the 2.5L is going to be a better platform, so long as it flows equally as well as the 2.0L.
Old 05-07-2006, 12:33 AM   #21
boostinscooby
Member#: 91560
2012 STi Hatch
buy a marauder ftw
boostinscooby is offline   Reply With Quote
Old 05-07-2006, 07:19 AM   #22
dj_booduh
Member#: 70861
2005 Scoobie WRX
/ thread FTW!!!
dj_booduh is offline   Reply With Quote
Old 05-07-2006, 07:21 AM   #23
D fresh
Member#: 95459
the activity level
of AutoX is > than F1
What's better, a chicken sammich or a ham sammich?
D fresh is offline   Reply With Quote
Old 05-07-2006, 07:41 AM   #24
dj_booduh
Member#: 70861
2005 Scoobie WRX
Chkn FTW!!!
Old 05-07-2006, 07:46 AM   #25
D fresh
Member#: 95459
the activity level
No way man, ham is teh fastar through my system.
2005 STI stage 2 vs 2000 WRX type RA maurim3 General Community 37 07-29-2009 02:02 AM
07 wrx stage 2 vs 09 wrx stage 1 alphaomega0 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 38 07-28-2009 07:39 AM
Completed Stage 2 on 06 WRX justinpool2000 Car Part Reviews 14 04-29-2006 04:23 PM
cobb stage 2 on 06 WRX!!! toekneeyo Newbies & FAQs 44 12-22-2005 10:33 AM
05 wrx stage 2 vs 06 wrx stage 2? dodiox Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 11-11-2005 11:31 AM
