Old 05-06-2006, 07:29 PM   #1
FD777
Member#: 84820
2005 WRX Sedan
Crystal Gray
Default Oil Analysis - Mobil1 10w-30 - 4000 miles - 2005 Subaru WRX 2.0L Turbo
Original post can be found on BITOG here .
Good results with this oil. Used the Subaru OEM filter (Tokyo Roki - 15208AA100).
Onto the nitty gritty:
I drive the car moderately. I ALWAYS let her warm-up. ~3k RPM shifts when the she's cold and ~4k RPM shifts when she's warm. The car see's redline more than enough
Car averages two 7-mile city trips on weekdays and 30-50 mile highway trips on the weekends.
I'm trying out GC (German Castrol) now, so we'll see how it goes.
Code:
EQUIPMENT MAKE: Subaru			OIL USE INTERVAL: 4,000 Miles
EQUIPMENT MODEL: 2.0L Turbo		OIL TYPE & GRADE: Mobil 1 10W/30 (Gas)
FUEL TYPE: Gasoline (Unleaded)		MAKE-UP OIL ADDED: 0.5 qts
These 2.0L Subarus are nice wearing types and yours is not the exception. Universal
averages show typical wear metals for an oil from this type engine after about 4,745 miles run on the
oil. Your oil was in use just short of those miles, and we found wear generally at better than average
levels and in the correct balance to show normal mechanical parts. Air and oil filtration appear normal.
This was 10W/30 engine oil with no gas moisture or anti-freeze in it. The TBN for this oil was 4.7, still
plenty high. Try 5,000 miles for the next sample. Wear will stay normal.
ELEMENTS IN PARTS PER MILLION (PPM)
MI/HR ON OIL	4,000		Universal Averages
MI/HR ON UNIT	15,000
SAMPLE DATE	04/08/06
ALUMINIUM	2		3
CHROMIUM	1		1
IRON		4		8
COPPER		7		4
LEAD		2		5
TIN		0		1
MOLYBDENUM	67		79
NICKEL		0		0
MANGANESE	0		1
SILVER		0		0
TITANIUM	0		0
POTASSIUM	0		1
BORON		35		85
SILICON		9		8
SODIUM		4		6
CALCIUM		2171		2486
MAGNESIUM	11		114
PHOSPHORUS	601		745
ZINC		713		888
BARIUM		0		0
		cST		SUS		VISCOSITY	cST		SUS		FLASHPOINT	FUEL%	ANTIFREEZE%	WATER%	INSOLUBLES%
		VISCOSITY	VISCOSITY	INDEX		VISCOSITY	VISCOSITY	IN F
		@ 40 C		@ 100 F			@ 100 C	@ 210 F
VALUES										59-68		>365		<2.0	0		<0.1	<0.6
SHOULD BE
TESTED										61.4		370		<0.5	0.0		0.0	0.3
VALUES WERE
FD777 is offline   Reply With Quote
Old 05-07-2006, 02:02 AM   #2
v8eaterWRX
Member#: 108547
2013 RAM 2500 4x4
6.7l Cummins
I assume this is for the full syn? You didnt say, so I want to clarify Glad I have been using it
v8eaterWRX is offline   Reply With Quote
Old 05-07-2006, 04:18 AM   #3
FD777
Member#: 84820
2005 WRX Sedan
Crystal Gray
Yep! Mobil1 full Synthetic - not the extended performance stuff (which is still synthetic).
Just FYI, anything called Mobil1 is synthetic and plain Mobil is dino And I don't think Mobil has any blends...
Old 05-07-2006, 11:23 AM   #4
z&cobb
Member#: 12344
2002 2JC
blue
Was there any comment on the copper?
z&cobb is offline   Reply With Quote
Old 05-08-2006, 09:34 AM   #5
bluesubie
Member#: 767
04 FXT
Nice report, although it should be for such a short interval.
Your car is breaking in really well! When did you switch to synthetic? GC going in next? Don't bother with a UOA before 6k miles, IMO. Currently going with a 7,500 mi. OCI on my FXT. Silicon is good. Are you running an OEM air filter?
v8eaterwrx - Don't assume this oil will have similar results in your car, especially in AZ in a modified WRX. Get an analysis!
-Dennis
Old 05-08-2006, 04:49 PM   #6
FD777
Member#: 84820
2005 WRX Sedan
Crystal Gray
Nope, I posted every detail from my report. Hopefully it's just left-over from my previous oil. (See below)
I'll give you the full details . Given in the mileage when I changed the oil:
2.5k - 5w-30 Chevron - Dino (Done at dealership and 1st oil change)
5k - 5w-30 Castrol GTX - Dino
8k - 5w-30 Castrol GTX - Dino
11k - 10w-30 Mobil1 - Synthetic
15k - 0w-30 Castrol Syntec (a.k.a. German Castrol) - Synthetic
Running OEM air filter. Used OEM oil filter everytime.
The GC is in now, I'll change it in 4k just to get a fair comparison with Mobil1. But I am confident to take it beyond that . The UOA results will tell me for sure.
Old 05-09-2006, 09:16 AM   #7
bluesubie
Member#: 767
04 FXT
No synthetic until after 10k and OEM air and oil filters. The results speak for themselves.
-Dennis
Old 05-10-2006, 02:47 PM   #8
mossie4
Member#: 83997
2008 STI
Question
Ok, stupid question from Montana. Have never once had an Engine oil analysis done. Who exactly provides this analysis?
Just switched to Mobil 1 at 46K and would like to see what condition the oil is on its way out!
Yes, yes... a newb question!
mossie4 is offline   Reply With Quote
Old 05-10-2006, 02:53 PM   #9
Skeete
Member#: 52569
2004 STi
Skeete is offline   Reply With Quote
Old 05-10-2006, 03:03 PM   #10
Kean
Member#: 25187
'08 Foz Prem TGM
'10 Challenger R/T Blk
http://www.blackstone-labs.com/
EDIT: didn't see the above response. .....sorry.
Kean is offline   Reply With Quote
Old 05-10-2006, 04:42 PM   #11
mossie4
Member#: 83997
2008 STI
Thanks a bunch, I will look in to it although I now have a few thousand miles before I am due for another change!!
Old 05-10-2006, 04:54 PM   #12
Kean
Member#: 25187
'08 Foz Prem TGM
....why wait? Have them send you the kit now so you'll have it when you're ready for your next oil change. ....there is no up-front charge.
Old 05-10-2006, 05:07 PM   #13
mossie4
Member#: 83997
2008 STI
Smile
Sweet, just hit their website and will do that immediately. I will get in a couple of Auto-X events over the next couple of weeks and send it in then! It is not a daily driver so it won't be many miles but will still be great to know whats going on in that 4-year old engine.
Old 05-10-2006, 10:32 PM   #14
bluesubie
Member#: 767
04 FXT
It's better to ask how to go about getting an oil analysis, than to ask a bunch of nuts like us how long to run an oil in your car.
-Dennis
FS (IL): Cobb AccessPort V2 2002-2005 Subaru WRX 2.0L Turbo dylanhauge MWSOC Private Classifieds 13 08-20-2009 02:14 PM
02 WRX 2.0L Turbo Motor W Turbo 84K Miles! Farvardeen Engine/Power/Exhaust 9 04-11-2009 01:28 PM
FS: Cobb Tuning AccessPort 2002-2005 Subaru WRX (2.0L Turbo) AP-SUB-001 rmrf Engine/Power/Exhaust 11 09-05-2008 09:22 AM
(AUTOMATIC) 2002 Wrx 2.0L Turbo, Midnight Black Pearl, 71,000 Miles stevey323 Private Vehicle 'For Sale' Classifieds 1 01-09-2007 06:50 PM
What Oil is the best for Wrx 2.0l turbo? Fc3sblue Service & Maintenance 8 01-10-2005 06:57 PM
