Old 05-07-2006, 12:59 AM   #1
vader wagon
Member#: 43440
03 WRX Wagon
Default Legacy GT Brake Conversion on WRX
I tried a search but didn't find what I'm looking for. I was hoping someone could steer me in the right direction. I'm looking for information what it takes to do a Legacy GT brake conversion on a WRX. I have an 03 WRX wagon, to be specific.
I'm particularly curious about whether the e-brake parts need to be converted and whether SS lines for the Legacy work on the WRX's hardlines. I'd assume the SS lines aren't the same, but maybe I'm wrong.
Anyway, any help would be appreciated. Thanks!
vader wagon is offline   Reply With Quote
Old 05-07-2006, 02:39 PM   #2
BillJC
Member#: 31002
For the SS lines use lines intended for the WRX. Also, you will need at least 17 inch wheels to clear. You don't need to do anything to the e-brake since the rear hub is the same size. Everything bolts right up. You will have to modify the backing plate dust shields though. Or, just remove them which is what I did. All in all it took about an hour including time to bleed them. BTW, the pads that come stock, suck. Upgrade the pads from the beginning. I'm using Carbotech Panther Plus pads now. They are a little loud but, the pedal feel is great and I haven't overheated them yet.
Bill
BillJC is offline   Reply With Quote
Old 05-07-2006, 02:59 PM   #3
vader wagon
Member#: 43440
03 WRX Wagon
Default legy brakes
Cool. Just to make sure I got it:
1) Make sure you got 17" rimes (done)
2) The WRX's SS braided lines swap over
3) The e-brake parts swap over
4) Dump the backing plates (or modify 'em--is it obvious what needs to be mod'd?)
5) OE pads suck--up-rate them off the bat
Here's an odd one, I was thinking about up-rating the rotors right away as well--never even running OE Legacy GT rotors. Perhaps something like PowerSlots, or similar. Any reason not to just make that jump at the same time as the conversion?
BillJC, any pictures of your conversion? I'd love to see them, if you got 'em. Were there any websites or tech information you ref'd before doing you conversion?
Thanks for you help!
Old 05-07-2006, 07:21 PM   #4
ten80
Member#: 53625
00 EJ205 LGT-4SALE
There's no swapping or messing with e-brakes, just change the rotors and install the calipers with brackets. the backing plates com off with some persuasion from a rubber mallet (spot welds break easliy). only reason not to do rotors at the same time is cost and the fact that they are mainly for bling unless you race on the track! You can upgrade pads, might as well do it for the rediculous power!
ten80 is offline   Reply With Quote
Old 05-08-2006, 07:47 AM   #5
AutoXRex
Member#: 21650
2015 STI
Go find a copy of the latest issue of SubieSport magazine. They do a complete install on a wrx wagon and review the effectiveness of this swap.
AutoXRex is offline   Reply With Quote
Old 05-08-2006, 10:30 PM   #6
BillJC
Member#: 31002
The stock rotors are fine. A little heavy but they get the job done. I'm trying to source a set of two piece rotors to lighten the setup a little. I just drilled the spotwelds and hit the backing plate with a hammer and they came right off. No need for them if you only drive on the street. I wouldn't spend any money upgrading the rotors in the begining. You won't notice any difference in performance. Just get a set up good pads, such as the Carbotechs and some good fluid, Motul or Castrol GTLMA and you're good to go.
Bill
Old 05-08-2006, 10:58 PM   #7
LastResort
Member#: 99289
I'm contemplating doing just the rear Legacy GT breaks on my WRX to get rearward bias, but skipping the front upgrade. Any chance you could share the source for the two piece rotors?
LastResort is offline   Reply With Quote
Old 05-08-2006, 11:04 PM   #8
vader wagon
Member#: 43440
03 WRX Wagon
Cool. I get mine at a local magazine store and I haven't wandered down there yet this month. Now I've got a reason I gotta go!
I was also curious about just a rear conversion, but it seems like the bias would be too rearward. I dunno.
Old 05-09-2006, 12:09 AM   #9
BillJC
Member#: 31002
I was going to piece together a setup from Coleman but, I was just informed that DBA has a kit as well. I'm going to look into that as well. It's easier to buy a ready kit than to try and piece it together myself.
Old 05-09-2006, 12:51 AM   #10
LastResort
Member#: 99289
The diameter is the same as an H6 upgrade, and uses the same pad. The only difference is the additional width for the vented rotor. The H6 upgrade is a very well thought off improvement in terms of bias, so I figured this would be a good jump as well. I'd love to see a solid comparison between the legacy GT upgrade, the 4pot/2pot combo, OEM Brembos, and some after market kits. I'd like to go best bang/buck and those really run the range of prices.
Old 05-09-2006, 01:39 AM   #11
vader wagon
Member#: 43440
03 WRX Wagon
Hmmm... that's interesting. I can't wait to see the new SubieSport, I hope they've got some info in it like that. I certainly wouldn't mind doing the rear, then the front down the road.
Old 05-09-2006, 08:09 AM   #12
AutoXRex
Member#: 21650
2015 STI
Sale on the legacy break kit:
https://www.subarugenuineparts.com/i...sort=1a&page=3
I really believe this is the way to go if you are on a budget or want OE quality / reliability.
Old 05-09-2006, 11:20 AM   #13
electricpork
Member#: 9498
03 Bugeye
Junkyards are fun!
I've done just the rears (w/ Legacy B4 rears seriously 2 months before someone discovered the LGT conversion would work, haha), but the rear bias shift is only 2% with the 10% increase in rear brake torque. Bias goes even more rearward with 4-pots on the front, like how the JDM WRX NB comes from the factory.
I would suggest using a 3/8th-inch drill bit to drill out the spot welds before popping the dust shield off with a hammer, makes the job much quicker and easier. Just hit each weld for 10 seconds and you're good to go. Like butter.
Ben
electricpork is offline   Reply With Quote
Old 05-25-2006, 12:10 PM   #14
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
So, do you reuse the stock WRX caliper brakets?
dbrier is offline   Reply With Quote
Old 05-25-2006, 12:15 PM   #15
Sharky NRK
Member#: 29549
2003 WRX
I would say no to the reuse of the brackets due to the larger size rotors
Sharky NRK is offline   Reply With Quote
Old 05-25-2006, 12:54 PM   #16
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
Then how are they fitting on? The LGT brake kits don't include them.
Old 05-25-2006, 02:15 PM   #17
Sharky NRK
Member#: 29549
2003 WRX
are you sure they don't include the calipers and the brackets or just the brackets and reuse the calipers, hell let me search a bit, but generally brackets are matched to disk diameter
Old 05-25-2006, 05:58 PM   #18
dbrier
Member#: 6598
2012 Mazdaspeed3
Crystal White Pearl
I have searched many threads about the LGT brake upgrade, but not of them mention brackets. I hope someone who has done the swap will chime in.
Old 05-25-2006, 06:45 PM   #19
vader wagon
Member#: 43440
03 WRX Wagon
I haven't seen a need for the brackets yet... haven't done an install yet either. One more car payment and I own my WRX, finally. I'll be doing the conversion soon, at least on the rear. Hopefully someone will post been-there-done-that info before then! :^D
Old 05-26-2006, 02:17 PM   #20
Sharky NRK
Member#: 29549
2003 WRX
that is an extremely interesting question, my search has lead to no mention of the brackets, bit similar style oem upgrades on both hondas and nissans that I have done required the use of brackets that matched the rotors diameter so I too hope someone will chime in
Old 05-26-2006, 09:48 PM   #21
keaniegenie
Member#: 94494
2005 Element 92x
Are the calipers different from these legacy gt brakes to H6's? I have H6's and would love to get a different looking caliper to match my BBK look.
keaniegenie is offline   Reply With Quote
Old 05-27-2006, 12:58 AM   #22
LastResort
Member#: 99289
I've never seen a pair in life or compared the photos that are in other threads, but my guess the legacy GT rear caliper looks almost exactly like the current calipers on the WRX, just "fatter" depth wise.
Brembo and Legacy GT brakes installed on Saabaru rdy4flt Member's Car Gallery 43 07-30-2009 07:51 PM
Legacy GT engine cover on WRX??? KB21 Interior & Exterior Modification 3 11-02-2008 12:21 AM
Legacy GT Brakes on WRX Brake Line Problem Aegon Brakes, Steering & Suspension 28 05-22-2006 06:34 PM
05 Legacy GT side mirrors on WRX? Jonnyfilmboy Interior & Exterior Modification 12 11-18-2004 11:59 AM
Legacy GT 16" wheels on WRX - Pics???? PunksWRX Brakes, Steering & Suspension 1 08-13-2001 12:33 AM
