Old 02-22-2000, 12:41 AM   #1
Ben
Member#: 423
2002 WRX wagon
Question Information for Turbo Legacy downpipe?
Shik, any news for the Turbo downpipe ?
Ben is offline   Reply With Quote
Old 02-23-2000, 02:31 PM   #2
Shik
Member#: 132
2006 GT Ltd 5spd sdn
'15 WRX 6spd CWP, '02 WRX
Post
Ben, the Legacy is resting at Rallispec's shop as we speak. If all goes well, I should have it back by next week sometime. I'll post all the info as soon as I get it back.
Shik is offline   Reply With Quote
Old 02-24-2000, 12:17 AM   #3
Ben
Member#: 423
2002 WRX wagon
Post
Hi Shik, thanks for your reply, and I'm waiting for your review of the downpipe! Hope you'll have a positive come out for us!
Reply me when you get your car!!
Old 02-24-2000, 08:52 AM   #4
Racerboy
Member#: 270
Post
Hey,
Here's a update on the downpipe (on a technical standpoint). The stock flange that meets up with the turbo has a single round hole for the pipe. This lines up great for the turbine outlet but not for the wastegate. Our downpipe inlet will be ovalized and is going to open up a good bit more toward the wastegate outlet than stock; requiring us to port the exhaust flange. This accomplishes two things. First the exhaust flange opening will be of a larger area (a ovalized 3" tube) that will afford more flow. Second, the wastegate should flow much better, allowing better boost control and ward off boost creep if higher boost is pursued.
BTW. the stock downpipe seems to be around 60mm diameter (not too bad!). Plus with all the heatshielding, it is about the same size as the 3". This means there is plenty of room.
Andy - RalliSpec
Racerboy is offline   Reply With Quote
Old 02-26-2000, 04:02 AM   #5
Shik
Member#: 132
Post
Andy, I was going to mention something to you guys about the wastegate, but figured it might be too much of a hassle to mess around with, but that's fantastic that you are going to incorporate the wastegate into the downpipe anyway. It's surprising that the stock flange really doesn't allow the exhaust from the wastegate to go anywhere, but what's almost more surprising is that there are some (not so cheap) aftermarket downpipes with the same design.
Also good to know that everything should fit without many problems. Like I said before, if you run into any snags, give me a call or e-mail. I can't wait to finally see this thing!
[This message has been edited by Shik (edited February 26, 2000).]
Wtt: wrx turbo and intercooler for stock Turbo legacy turbo and intake 91turbosedaan Private 'Wanted' Classifieds 1 12-06-2008 06:17 AM
Replacement Studs for Turbo, Uppipe, Downpipe etc on McMaster? disque71 Newbies & FAQs 12 11-02-2006 06:58 PM
Where can I get a gasket for turbo xs downpipe? BlackRex05 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-02-2004 03:55 PM
Looking for Turbo Legacy Pressure Sensor suberboy Legacy Forum 0 03-13-2003 02:42 AM
Downpipe for turbo Legacy?? Ben Legacy Forum 0 01-17-2001 12:18 AM
