Old 05-07-2006, 12:20 PM   #1
elsanto
Member#: 34832
1989 M3
Default CEL with no Code? what gives
Friday (two days ago) got tuned up at XX tuning by Tony.
I am finally CEL free or so i thought.. with the help of ecutek he 'turned off' the CEL for my TGV deletes, Light Flywheel Misfires. get home and all is good no cel for 2 days now the light came on today. but the code reader reads "pass, no codes" wont let me erase or anything.
the section on the reader for MIL light, says "ON" and underneath reads, if the car is on and running the MIL light is on. not sure why that would be if there is no code.
3 readiness checks failed but i dont think any of them would cause the cel. o2, evap system, and catalyst are all Not Ready. not sure why as ive driven it quite a bit since friday.
if anyone can help or has had similar issues please let me know as i'd like to get inspected asap as my sticker is expired.
elsanto is offline   Reply With Quote
Old 05-08-2006, 09:30 AM   #2
elsanto
Member#: 34832
1989 M3
anyone ?
Old 05-08-2006, 09:37 AM   #3
TheMadScientist
Member#: 23717
2005 Big red
What did you use to scan the ECU? Some scanners will not read all of the codes. ie. Cobb AP
TMS
TheMadScientist is offline   Reply With Quote
Old 05-08-2006, 09:54 AM   #4
sonic rx
Member#: 33457
Chapter/Region: PRSIC
HAHA EVERYONE KNOWS
DYNO JET IS NOT REAL WHP
i to have been bitten by the cel light on with a code 20B0 it is a no code definition available. i have been posting on ecutek forums,but to no avail. no one seems to know what this is
sonic rx is offline   Reply With Quote
Old 05-08-2006, 10:27 AM   #5
elsanto
Member#: 34832
1989 M3
no no no i have NO cel. this is an actron (i believe) reader. I reset the ecu yesterday it hasnt come back yet.
only thing i can think of is it has something to do with the code in the ecutek software.
Old 05-11-2006, 06:47 PM   #6
Crawford/I-Speed
Vendor
Member#: 12347
ECU ReProgramming
Dynapack AWD Dyno
The 20B0 code is an unknown code to Subaru, or they have not defined it yet. A default code when nothing has been defined. When we see it, it usually happens with the misfire codes. So shutting off the misfire codes will get of those codes but still does not remove the "unknown" code.
Cheers,
William T. Knose Jr.
Lead Programmer
Crawford Performance / I-Speed USA
Crawford/I-Speed is offline   Reply With Quote
Old 05-22-2006, 02:01 PM   #7
The Phenx
Member#: 95823
2003 Imprezza Wrx
WRC BLUE
Question... so you permanently removed p301-p304 codes? Isnt that a bad thing.. just curious i have Cel issues possibly from my flywheel, exploring all the options.
Scott
The Phenx is offline   Reply With Quote
Old 05-23-2006, 09:56 AM   #8
elsanto
Member#: 34832
1989 M3
i dont think it permamently removes them it changes the sensitivity of the code (voltage reading iirc). you can reflash ecutek to get rid of it.. id suggest getting a knock sensor though.
Old 05-30-2006, 09:01 AM   #9
sonic rx
Member#: 33457
HAHA EVERYONE KNOWS
Cheers,
Lead Programmer
well my car was tuned fat for engine breakin,and i get the 20b0 after i let the car idle first start in the morning then drive . after 5 minutes or so the light will come on. i thought it was missfire when i first got it. you can feel it just a tiny little bit under very light throttle. anything else and it is smooth
CEL + Blinking Cruise with no code!?! hoppergrande Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 32 01-27-2009 08:47 PM
CEL with no code??? Any ideas? Ryandc AccessPort 3 12-06-2007 11:16 PM
CEL with No Codes in AP MossyRoc AccessPort 1 07-11-2007 06:09 PM
2004 STi swap, CEL and limp mode with no codes stored!? AcquaCow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 07-27-2006 12:29 PM
Quick CEL flash, no code Si2WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-01-2006 01:30 AM
