Old 10-08-2001, 06:44 PM   #1
b00st3d
Member#: 9891
2015 RC-F
Ultra White
Default air fuel ratio gauge
how accurate are these? i hear that it isnt as good as using egt gauge??
methadon
b00st3d is offline   Reply With Quote
Old 10-08-2001, 08:27 PM   #2
Jon [in CT]
Member#: 2992
02 WRX Sedan
It depends on what you mean by accurate. If you're talking about a gauge that connects to a standard 0V-1V switching oxygen sensor and indicates "Lean" when the sensor voltage is less than .45V and "Rich" when the voltage is greater than .45V, then it is very accurate. If it connects to a standard 0V-1V switching sensor and has indications of HOW rich or lean, then it isn't very accurate.
Model year 2000 and newer Imprezas also present a problem for a gauge that connects to a standard 0V-1V switching oxygen sensor because their front sensors are the wrong type and can't be used with such a gauge. That means you'd have to either connect the gauge to the Impreza's rear oxygen sensor (which is the correct type but located downstream from all of the catalytic converters) or you'd have to install yet another oxygen sensor of the correct type near the stock front sensor.
I'll let someone else discuss the pros/cons of tuning via EGT versus tuning via A/F ratio.
Jon [in CT] is offline   Reply With Quote
How and where to hook up my air/fuel ratio gauge PumpsGOTAWD Electrical & Lighting 2 02-24-2003 09:33 PM
('93-'01) How and where to hook my air/fuel ratio gauge PumpsGOTAWD Impreza Forum 2 02-24-2003 01:38 PM
Auto Meter Air Fuel Ratio Gauge? wrx842 Newbies & FAQs 6 11-23-2002 03:13 PM
Autometer Air-Fuel Ratio Gauge Diversion Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 15 09-13-2002 06:27 PM
Air Fuel Ratio Gauge Install Up Online North Ursalia Normally Aspirated Powertrain 12 07-22-2001 11:07 PM
