#1 |
Member#: 423
E. Canada
Vehicle:2002 WRX wagon Silver |
Hi everyone, does anyone install an turbo boost control to your Legacy turbo?
If you do so, what is your set up? I just got an Apexi AVC-R, but don't know how to set it up!! Can I just install this turbo boost control without the intercooler? if without the intercooler, whats the highest boost ?
#2 |
Member#: 116
Did you upgrade your ECU? If you are not, I don't think you can increase any boost. The computer will cut off at 8.5 psi. Should upgrade the ECU first. MRT, Starchips, JCsports (If they still have it), Superchips (Call and ask them, they upgraded mine)
I hope this help |
#3 |
Member#: 166
Vehicle:2008 STi |
Actually, the AVC-R worked fine for me w/o an Boost Cut Controller. However, I have a AFC too.
W/o the IC I would not go over 13 psi or so. It seems that over 15 psi, w/o the IC the IHI turbo in the Legacy Sports Sedan becomes inefficient. Did you get the older AVC-R or the new one? |
#4 |
Member#: 116
Is that mean your AVC-R or AFC disable the boost cut control? I know that SFC-Hyper R can disable that because it said in the manual. So that's mean APEXi can do too. Thanks this is a new information.
#5 |
Member#: 132
Vehicle:1997 LGT Wagon 5spd '06 LGT 5spd Ltd Sdn |
As some of you guys know, I use the Hallman manual boost controller( very popular with the Mitsubishi guys). Not as convenient as an EBC but works almost as good. Anyway, I have it set right now at 9psi and it has touched 10psi on some cool nights with no problems( stock ECU). The Hallman is about $90.00 and takes about 5 minutes to install.
I believe the ECU activates the *supposed* boost cut off when it sees too much air going through the Mas air flow meter. If this is the case, I could see how the fuel computers that you guys mentioned would be able to get rid of this signal because all the MAS signals have to go through the fuel computer first before it gets to the ECU. I must thank you guys for discovering this as I was somewhat worried about what I would do when it cam time to start pushing the boost up a bit. Subaruist, 20psi !?! Tell us, what was it like? Was that with the stock fuel system and everything? |
#6 |
Member#: 423
E. Canada
My AVC-R is the new one that have a blue matrix screen!
I'm not install yet to my car, because someone told me that if I over boost the turbo , it may blow the engine!! Also how you guys install the boost control? Is it easy to install by myself? Could it use without the intercooler? Thanks for all the infomations!!! |
#7 |
Member#: 166
Vehicle:2008 STi |
The stock turbo I have is very efficient after 15 psi. So from 15 to 20 psi, I did not see any change. However, at 15 psi, the car felt much more like the RS/RA Legacy over in Japan. It was kind of scary at first since I didn't know what to expect.
I plan to get a more efficient IHI turbo soon, capable of 22 psi w/o any problems. |
#8 |
Member#: 166
Vehicle:2008 STi |
Upto 0.9 kg/cm^2 or 13 psi, the I/C would be nice but would not be a necessarily required. People do say that over 7 psi, you'll need one anyways.
I did not install my boost controller, but seeing what was done, it doesn't look too hard. Sorting out the wires from the ECU will be time consuming though. [Had units wrong] [This message has been edited by Subarist (edited October 22, 1999).] |
#9 |
Member#: 116
I didn't install by myself, and I don't want to mess around with the electrical stuff.
#10 |
Member#: 166
Vehicle:2008 STi |
In the manual, it did say that certain cars may need to buy the optional fuel cut controller, or boost cut controller. I was able to tweek the boost setting to 20 psi with no problem. As I have said, I do not no if this is b/c of the AFC as well, probably not but....
As far as I know, our cars aren't supposed to produce more than 10 psi without any ECU fooling. Maybe the AVC-R has this capability built in. |
#11 |
Member#: 423
E. Canada
Could you guys tell me how to conver the psi to bar or kg/cm??
Also , isn't that means I could boost my car to 10 psi to 11 psi without have the intercooler??? I don't have the AFC, so, will the car runs less fuel and damage the engine??? |
#12 |
Member#: 166
Vehicle:2008 STi |
Just don't go over 13 psi w/o the IC or AFC. The ECU in our unit does adjust itself, so I do not see an immidiate problem w/o a fuel managent system. However it would be nice to get one.
10 psi = 0.6895 Bars |
#13 |
Member#: 116
On my old turbo without intercooler, I ran 12 psi. Now I still run 12 psi, sometimes 14 psi. I don't want to run over 15 psi, even I have the fuel controller. I don't know how much psi the engine can hold. I want to be on the safe side. I have seen some of my friend blown the head gasket before, it's very expensive to fix.
#14 |
Member#: 166
Vehicle:2008 STi |
Since our car is a closed deck design, the car should be able to take more boost than the bolt-on Honda or even the Subaru. The Legacy in Japan can take well over 22 psi. Byrons car is running over 15 psi for over 2 years, since the JC Sports days. I would be more worried for the rods.
#15 |
Member#: 423
E. Canada
Thanks guys, your information are so helpful, I will try to install the AVC-R by myself next week, and lets see how much different between them! If you guys still have any advice just post or e-mail to me. my e-mail address is:
b.lam@usa.net! Unforturnaly , I got the wrong intercooler, hope some of the weld shop can solve my problem! Thanks for all the helpful info. Enjoy Your Legacy!!! (me too)(^_^) |
| Thread Tools | |
| Display Modes | |
| FS 18g turbo,Aquamist meth kit, turbo xs boost controller, turbo inlet | 04caliwrx | Engine/Power/Exhaust | 24 | 01-18-2013 11:34 AM |
| FS : Turbo XS Manual Boost Controller NIB | jsharp2280 | Engine/Power/Exhaust | 13 | 09-20-2010 07:03 PM |
| Electronics - Car Stero, STI Cluster, Turbo Timer, Boost Controller, A/F Controller | RavSpec | Interior/Dressup/Audio & Security | 16 | 01-15-2005 05:48 PM |
| turbo boost controllers..worth the money?? | fdu98 | General Community | 12 | 07-12-2004 06:57 PM |
| Fs: Blitz Sbc-id Turbo Boost Controller | aawen | Vancouver Impreza Club Forum -- VIC | 5 | 07-03-2003 02:59 PM |
