Old 05-07-2006, 08:51 PM   #1
Starkiller
Member#: 82741
2007 350Z Silver
Default Coated bearings question
Can these coated bearings be re-used?
I have no experience dealing with them, so any advice is appreciated.
Starkiller is offline   Reply With Quote
Old 05-08-2006, 12:43 AM   #2
02Toyowrx
Member#: 56520
Yes they can be reused, when reused .. bearing clearances should be checked again.
02Toyowrx is offline   Reply With Quote
Old 05-08-2006, 05:01 AM   #3
Starkiller
Member#: 82741
2007 350Z Silver
bump for more opinions
Old 05-08-2006, 06:58 AM   #4
djviper
Member#: 107276
99 V.R.Special
WRC blue
i see 4 con rods but alas no image of bearings! dependant on the condition i.e are they overly worn? when you move the crank are there any loose/tight spots? if ya answer no to all then re use em
if in doubt mate bin em, new shells cost considerbly less than a new crank!
djviper is offline   Reply With Quote
Tial Exhaust Housing GT30R, Calico Coated Bearings S L O W W R X Engine/Power/Exhaust 11 02-23-2010 03:24 PM
Coating rims question Anthonyx Tire & Wheel 4 11-10-2006 05:01 PM
Release bearing, throw out bearing question benyl Transmission (AT/MT) & Driveline 2 09-21-2006 11:26 AM
Coated bearing Paul Built Motor Discussion 12 06-19-2006 12:03 PM
powder coat cleaning question? yuzo Brakes, Steering & Suspension 2 03-19-2002 03:37 PM
