Old 10-08-2001, 08:00 PM   #1
xephyr
Member#: 665
1998 2.5 RS-T
Question B-Spec USA engine question
How many people out there have a B-Spec built engine? Is it a 2.5 or a 2.2? How much boost are you running and does it burn oil or have any other problems?
The reason I am asking is because I have a 2.5 B-Spec engine with chromoly rods, forged pistons, knife edged crank, etc, running 20+ pounds of boost. There is just one problem: it burns a lot of oil. If anyone else has this problem please respond.
xephyr is offline   Reply With Quote
Old 10-08-2001, 08:15 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
are you running synthetic?
Old 10-08-2001, 09:53 PM   #3
kaos200
Member#: 2692
what CR are you running with 20psi?
engine management?
turbo?
Where have you been!? lol, only 7 posts and you must be pushing 350hp easy if tuned right?
kaos200 is offline   Reply With Quote
Old 10-08-2001, 10:22 PM   #4
xephyr
Member#: 665
1998 2.5 RS-T
Injectors are 550 cc/min RX-7 version 2 injectors. Compression is about 8.5:1. Engine management is the stock ECU, and a S-AFC(compensating at -50%). The car ran great except for the blue smoke because of the burning oil. The fastest timeslip was a 13.9 at Bandimere. I have a feeling all the oil in the exhaust was plugging up the cats and causing excessive backpressure. B-Spec's engine was only in the car for 1 week, and has been sitting on the workbench for the past six months. We just recently found why the engine is burning oil and it appears to be a problem with the oil rings on the pistons. Right now the car has a stock 2.2 L Turbo Legacy motor running 20 psi and it runs equally well, and doesn't burn a quart of oil a day! There is some significant loss of low end torque. I've been running this setup for quite some time now (since I pulled B-spec's motor out) and I like the easy availability of Turbo Legacy motors. Despite all the hype out there about running 20 psi of boost on the Turbo Legacy motor, the motor does fine. People here in Colorado do it all the time. As long as you have enough fuel, and intercooling capacity, those motors will run 15-20psi of boost ALL DAY.
Old 10-08-2001, 10:54 PM   #5
kastle
Frank Army
Member#: 1457
1999 Outback Sport
Steel Blue Mica
kastle is offline   Reply With Quote
Old 10-08-2001, 11:46 PM   #6
kaos200
Member#: 2692
Default Is your name Chris Moreno?
if you ARE running 20 psi on that block somehow, and with that setup, why in gods name wont you get engine management and do it right, youll have alot more power and drivability. I dont understand how anyone can run what you are without engine management, its just asking for trouble.
Old 10-08-2001, 11:53 PM   #7
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Simple, he got it from B-Spec. Xephyr, you might want to go make your the fuel lines on your car are actually fuel line, otherwise you might have a fire on your hands. 13.9 on 20psi in an EJ25 is absolutely pathetic. You should be running low 12s with that.
Ben
bsquare is offline   Reply With Quote
Old 10-09-2001, 12:00 AM   #8
xephyr
Member#: 665
1998 2.5 RS-T
Jaxx:
No, I was not using synthetic oil. At a quart a day, I wouldn't be able to afford it!
As I said earlier, the problem appears to be with the oil ring. B-Spec custom machined a set of pistons using Ford wrist pins. The wrist pins are heavier duty pins, yet the outside diameter of the pin is smaller than the Subaru specifications. The benefit of using these wrist pins is not simply in the added benefit of the stronger pin, but more importantly in the ability to move the piston rings farther down from the top of the piston because the hole in the side of the piston is smaller. Why is moving the rings down away from the top a good thing? Because now you have more material between the top of the piston and the top of the 1st compression ring. This added strength makes a piston very resilient against detonation, and in general a much stronger piston.
The problem with B-Spec's particular set of pistons, is that they moved the rings TOO far down. Some of you reading this are probably very familiar with how wrist pins are installed in a Subaru. There are 2 holes in the front and 2 holes in the back of the block used for assembly, where the wrist pins are allowed to slide into the piston through the side of the cylinder wall. When you align the piston at bottom dead center, and look through the respective wrist pin hole, you should be able to see the side of the piston and the wrist pin. You should NOT see the oil ring of the piston. On B-Spec's pistons, I see the oil ring very clearly. Remember, the oil ring is supposed to keep oil from reaching the the other two rings. Because B'Spec's oil ring protrudes down to the wrist pin access hole in the block, the oil seal is breached, and oil is able to get around the oil ring.
Old 10-09-2001, 12:01 AM   #9
kaos200
Member#: 2692
nvm
Old 10-09-2001, 01:28 AM   #10
DaveK
Member#: 2338
1988 323 GTX
black
Since you ran at bandiemere, I'm assuming you live in the denver area. I'm running 9psi on a TEC-II with stock internals, and I'd bet I'm somewhere in the same ballpark on 1/4 times. Let the CO people know the next time you're headed out to the track.
Dave
DaveK is offline   Reply With Quote
Old 10-09-2001, 02:12 AM   #11
inpreza kid
Member#: 3334
keep in mind that this engine has a built up bottom end. with low compression pistons, stronger rods, and crank i'm sure it can handle quite a bit of boost.
inpreza kid is offline   Reply With Quote
Old 10-09-2001, 02:43 AM   #12
kaos200
Member#: 2692
I realize that, but that doesnt mean squat without the right engine management controlling everything.
That and 550cc injectors using a stock ecu (from a 2.5 no less) and an SAFC???
no timing control?
Old 10-09-2001, 02:57 AM   #13
xephyr
Member#: 665
1998 2.5 RS-T
Hey DaveK: You've ridden in my car. You've seen me up at JC Sports. Remember, I was messing around with that programmable ECU from England? I am the guy with the black 98 RS and gold wheels. I can't remember if you ever saw my car with Byron's engine though. Next time I go to Bandimere I'll call you. I have to get a new tranny first. I blew second again last night. Come up to JC Sports tomorrow sometime; I should be there.
Old 10-09-2001, 05:19 AM   #14
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
kaos i am with ya on the BS flag. But as far as the piston rigns go that DOESN'T suprise me. But the qestion is WHY did your Oil control rings fail??
jeremy
Old 10-09-2001, 05:39 AM   #15
bsquare
Member#: 1911
2000 Impreza 2.5RS
This really sounds like another B-Spec engine hack job.
Ben
Old 10-09-2001, 06:07 AM   #16
xephyr
Member#: 665
1998 2.5 RS-T
Angry
You guys don't read very well.
Number one:
The rings didn't fail. THEY ARE IN THE WRONG PLACE. When the pistons were machined, the groove for the oil ring was cut in a location too far from the top of the piston ( or too close to the wrist pin, however you want to look at it). Therefore, each time the piston hits bottom dead center, the oil ring comes down all the way to the area where the wrist pin installation holes are located. These holes therefore allow oil to pass around the rings, where there is not supposed to be oil, and into the combustion chamber. THE RINGS THEMSELVES ARE FINE. There are no damaged components at all. The pistons were just designed wrong.
Number two:
The timeslips were slow because I was burning a TON of oil. We're talking about 1 quart in 2 hrs., which is about all I drove the car in a day during this time period. When you are burning this much oil, you are seriously choking the combustion process, no matter how much boost you are running.
Number three:
I placed this post to find out how many other people had problems with engines from B-Spec, not to be publically lynched and scrutinized by a bunch of amateur wanna be Subaru techs who obviously think that if someone they know on the I-club has not done something, then it can't be done. I did not post this thread to write an in depth article on all the stupid mods I've done to my car. The reason we are using a stock ECU is because we are experimenting to see how much power can be extracted from a stock ECU. IT IS VERY OBVIOUS THAT A PROPERLY TUNED PROGRAMMABLE ECU WILL OUTPERFORM A STOCK ECU ON A HEAVILY MODIFIED ENGINE.
Once again, I implore you to help me with any information regarding people who have had any bad experiences with built engines from B-Spec. I already know of one (thank you very much kastle).
P.S. - What I have on my car DOESN'T matter. In case you are wondering, I have had 5 separate motors and three different turbos on my car in the past year (along with many other things). I do a lot of experimenting with Subaru's to pioneer and further OUR CAUSE, the continuous and further advancement of Subaru aftermarket technology. If you don't believe me, ask anyone you know from Colorado who has seen me at JC Sports. I am the guy with the 98 black RS and gold wheels.
REMEMBER: This message board was created with the positive intention of the advancement of OUR sport. Useless bashing, critical inquisition, and other assorted BS do not accomplish any of the aforementioned goals.
Old 10-09-2001, 06:52 AM   #17
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
yoooooosh
I will back you... xephyr
Although i don't know if you are BS ing... I run a EJ22t motor and I run 15 psi on street and 18-20 on track. I don't have my SBC-id yet but I am running an MBC which creeps the boost to 20 in 4th and 5th when i set it to higher boost. It runs fine i have 440 injectors and SAFC virtually the same thing as xephyr. And it does fine (1/2 yr of TC'd). Compression test was good... (touch touch)
Though i have no experience with B-Spec, your setup is plausible though cause i have it.
BTW i don't know why you wouldn't go with Cobb's stuff.. if you were to build the motor like that... Thats what i'm planning to do along with some Engine mgmt when i get serious.
Hok
HOK is offline   Reply With Quote
Old 10-09-2001, 06:52 AM   #18
bsquare
Member#: 1911
2000 Impreza 2.5RS
xephyr:
Relax, don't take it so personally. I don't think anyone meant to attack your abilities or intentions (but if they did, who cares? They don't know you!). Good luck with your engine, and from all the information on this board, I'd say don't let B-Spec near it again.
Ben
Old 10-09-2001, 09:34 AM   #19
SteveS
Member#: 6
2007 BMW Z4 M Coupe
Interlagos Blue
Xephyr ~~ Sounds like you know exactly what is wrong with your B-Spec engine. I would bitch and complain to them. Did B-Spec even run the engine after building it? How could they not notice this? B-Spec has also done a spectacular job for Dan Evander.
If you guys were reading, he posted up front that he's running 550cc injectors...
SteveS is offline   Reply With Quote
Old 10-09-2001, 12:25 PM   #20
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Have you read Dans comments in "How not to turbo your Impreza"..sounds like B-Spec strikes again with yet another ppor design..
STiShawn is offline   Reply With Quote
Old 10-09-2001, 03:22 PM   #21
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
like was said you seem to know exactly what is wrong with your setup. I dont think much people have b-spec built up 2.2 engines. Cobb Tuning makes lots of stuff and you should check em out.
Also how does your car handle the 550cc injectors and a stock 2.5L ecu? Mine didnt drive very well with the stock ecu 550cc injectors and turbo in. drove even worse with a bigger fuel pump in too.
NickSTi is offline   Reply With Quote
Old 10-09-2001, 06:37 PM   #22
xephyr
Member#: 665
1998 2.5 RS-T
Default B-Spec update
Just to clarify a few more things:
1. B-Spec did not tune my car. B-Spec has never seen my car. They sent me a custom shortblock. I do most of my own work (except engine internals fabrication). I assmebled the heads, shimmed the lifters, etc, myself. Therefore, B-Spec should not be held accountable for any of the tuning of the car.
2. I am not bashing B-Spec. For the most part, I have not had any problems with B-Spec. I have dealt with them numerous times in the past, and they have been more than fair, and have tried to be as accomodating as possible.
Once again, I do not have a problem with B-Spec. I DO have a problem with the pistons they sent me. I am pulling the pistons out this week. Byron has contacted us and has arranged to send me the correct specification pistons.
Old 10-09-2001, 07:10 PM   #23
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default Educational
xephyr - Your information has been enlightening and informative. That critical bit of knowledge about the piston ring groove location is a real jem. Please skip over those few know everything guys who have a need to tell you what you really mean. Don't bother to justify your report; those who have actually taken a Suby boxer engine apart will know and appreciate your information.
Especially appreciated is your mature comments quoted above. Not blaming someone else but instead getting the problem corrected will go a lot further than raising "BS Flags". I hope you continue to share your experiences for the people who enjoy improving Suby engine performance.
I barely know the B-Spec people, and have never had business dealings with them, but now would be a great time to get a 2.2 short block from there. I am totally confident they have learned from this experience and the next one will be perfect.
Hooray for the people who solve problems, not make more of them.
Mike McBride
MZM is offline   Reply With Quote
Old 10-09-2001, 07:13 PM   #24
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default sp
I meant gem, not jem. Please excuse.
MM
Old 10-09-2001, 07:43 PM   #25
Danny5
The Emperor Protects
Member#: 13
2014 Chevy Cruze
Diesel
My short block was built to their (B-Spec's) specifications and did not burn oil. (Well, until it crushed pistons )
YMMV
-Danny
Danny5 is online now   Reply With Quote
B-Spec USA (merged thread) adamsrs Vendor Reviews 6 08-03-2002 04:21 AM
Attn B-Spec USA buddies Longitude Southern California Impreza Club Forum -- SCIC 5 11-06-2001 08:46 PM
('93-'01) question about J-Spec and US-Spec WRX engine FuJi K Impreza Forum 6 07-10-2001 11:49 AM
Question for the Subaru engine builders: Cobb Tuning, B Spec USA, Rallispec, et al. Digital_Boy Normally Aspirated Powertrain 0 01-31-2001 04:13 AM
B-Spec USA Clutch @ 10% savings vkracing Hawaii Impreza Club Forum -- HIIC 0 01-09-2001 06:37 PM
