Old 05-08-2006, 01:18 AM   #1
KailuaWRX
Member#: 114016
Question best up pipe/ catback exhaust diameter for stock turbo set up
i don't plan on upgrading from my 05 wagons stock turbo, and i heard that an up pipe with a diameter less than 2'' is the best for it.?.? And if so, what companies are less than 2''? Im also getting the catted helix DP, and am looking at a friends used tanabe ultra which is a 3.1 " exhaust off a STi. Or would i be better off going with a 3" or less on the stock wrx turbo? Im a daily driver that doesnt want to loose any low end torque, or have to get engine managment(maybe later for an upgrade). Also want to keep it on the quiet side. Need to know b4 i buy a set up. Thanx in advance
KailuaWRX is offline   Reply With Quote
Old 05-08-2006, 01:29 AM   #2
-Kevlar-
Member#: 82378
for the TBE go for 3" or so anything bigger would just be overkill..... as for the up try and get something the same dia as stock...(not sure off hand)....
-Kevlar- is offline   Reply With Quote
Old 05-08-2006, 01:33 AM   #3
Crawdads
Member#: 30907
SWP GDB-G
If you are not going to use any engine management, don't mess with anything related to the engine on your car. The stock programming sucks...bad.
If you have some money burning a hole in your pocket, buy a catback. You will get some sound and your mind will think its faster..spend the extra money on a rear sway bar.
If you want to do engine mods, either get an accessport first, or save untill you have enough money to get a tune when you put on the up/turboback.
as for an up pipe, cheapest solution is to gut your own, next cheapest buy a gutted stocker off here, next cheapest after that is buying a used STi pipe (they dont have a cat at all)...up pipes are pretty much all the same, I wouldn't worry about it too much. FWIW, i have a helix (flex) up, because i got it in a package deal with the downpipe
Crawdads is offline   Reply With Quote
Old 05-08-2006, 01:40 AM   #4
KailuaWRX
Member#: 114016
i want to buy the helix up but i heard its a little bigger than the stock turbo inlet?
Old 05-08-2006, 03:11 AM   #5
DeKaP
Member#: 90627
2005 Impreza WRX
Obsidian Black Pearl
i believe stock perrin up pipe is 1.75in.......dont quote me though and 3" is good for you....
DeKaP is offline   Reply With Quote
Old 05-08-2006, 07:06 AM   #6
KailuaWRX
Member#: 114016
so the 3.175" tanabe is probally too much? loose some low end?
Old 05-08-2006, 07:42 AM   #7
-Kevlar-
Member#: 82378
have you read the faq's yet??
Old 05-08-2006, 04:22 PM   #8
KailuaWRX
Member#: 114016
really wanted the Tanabe Ultra bcuz its Titanium and am getting it used for 400$ and it sounds great
Old 05-08-2006, 04:32 PM   #9
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Yeah, they are only stickied at the top of this forum.
WTT: Turbo upgrade setup for stock turbo set up (2007 Sti) swift2fly SCIC Private Classifieds 16 06-14-2010 09:47 PM
WTT--gt35r setup, utec, stock ecu, etc for smaller turbo set up ASAP!!! skate enjoi Engine/Power/Exhaust 19 01-07-2009 09:23 PM
WTT--gt35r setup, utec, stock ecu, etc for smaller turbo set up ASAP!!! skate enjoi Engine/Power/Exhaust 15 11-12-2008 05:05 PM
WTT--gt35r setup, utec, stock ecu, etc for smaller turbo set up ASAP!!! skate enjoi MWSOC Private Classifieds 4 11-12-2008 02:23 PM
-FOR SALE-02/03 stock axleback exhaust, mid pipe, up pipe, and exhaust man -FOR SALE- SedonaScooby SWIC Private Classifieds 7 09-23-2008 02:25 PM
