Old 05-08-2006, 08:06 AM   #1
Trin_Starr
Member#: 102416
1995 Legacy L
red
Default Installed Grounding Kit, now battery is dead!!
Guys,
I installed a grounding kit on saturday and last night, my battery was completely dead!!!
I bought a ground kit from Ebay and connected the ends to:
1. Radiator support
2. Rear Engine Block
3. Left side exhaust manifold
4. Right side exhaust manifold
5. Driver side strut tower
6. On the back of the alternator.
I removed the old ground connections and replaced them with connections from the new grounding kit.
The alternator connection has me thinking that this is what caused the battery drain.
There is a long bolt that holds the A/C compressor and the alternator. At the end of the bolt, there is nut that I connected the ground wire to.
Any ideas what caused the dead battery?
Trin_Starr is offline   Reply With Quote
Old 05-08-2006, 10:09 AM   #2
spdracr00
Member#: 65823
1996 Impreza L
Red
you hooked to the Negative terminal right?
spdracr00 is offline   Reply With Quote
Old 05-08-2006, 10:13 AM   #3
Trin_Starr
Member#: 102416
1995 Legacy L
red
Yup, from the pic, you can see the -ve terminal connector that i put on the -ve battery terminal
Old 05-08-2006, 10:24 AM   #4
KD7000
Member#: 16653
2012 Mazda 3
2004 Honda Pilot
Exclamation
Take some pictures of your engine bay & wiring and post it.
You either screwed up your wiring somehow, or it's a purely coincidental dead battery.
KD7000 is offline   Reply With Quote
Old 05-08-2006, 10:44 AM   #5
Trin_Starr
Member#: 102416
1995 Legacy L
red
i wish i had a camera on hand so i could snap some pics...
The wiring looks pretty normal and is really straightforward...maybe it could have been just concidental as u said....
Now i have to figure out if it was the battery that was old or if the problem is really with the alternator.
When I tried to start my car last night, I turned on the headlights and then started the car...the ignition just made a click and all the lights went off.
I waited a little while, and then when I put the key back in, the instrument cluster came on but I tried to start...everything went off.
I got a jump and the car was idling for about 15-20 mins, then when I turned on my headlights to drive off, the car shut off.
If the alternator was bad, the car wouldn't be idling for 15-20mins right?
Which means the battery is the trouble maker?
Old 05-08-2006, 11:43 AM   #6
fibuz
Member#: 53410
BE-> GD->GR->SG->BL
WAawd.org
I'm gonna guess coincidence and just replace the battery.
fibuz is offline   Reply With Quote
Old 05-08-2006, 11:53 AM   #7
legacy1907
Member#: 94024
05 WRX CGM
95 YJ Flat black
make sure the positive terminal is clean...I hooked up my grounding kit and my car wouldnt start. realized that the terminal was corroded and cleaned it off and it was all good again.
legacy1907 is offline   Reply With Quote
Old 05-08-2006, 07:16 PM   #8
janikphoto
Member#: 10471
2000 BMW Z3
sold Outback & ForesterXT
So, did you drive the car any in between the kit install and the dead battery? Did the car sit overnight? Give a few more details and we will try our best to help. I'd check the alternator connects, but that's a stab in the dark since I don't have enough important info (like did you drive the car as asked above or did it just sit, etc)...
by the way, do you have a multi-meter? A few measurements can REALLY help...
janikphoto is offline   Reply With Quote
Old 05-08-2006, 09:58 PM   #9
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
I'd say put the stock grounding wires back on in addition to your upgraded wires.
Plays_With_toys is offline   Reply With Quote
Old 05-08-2006, 10:20 PM   #10
Wiscon_Mark
Member#: 94945
2012 Impreza
Sport Limited DGM
+1
+1
Wiscon_Mark is offline   Reply With Quote
Old 05-09-2006, 10:51 AM   #11
Trin_Starr
Member#: 102416
1995 Legacy L
red
Play with toys - I did something similar to what you said.
The ground kit I bought off ebay was not designed well.
The roundish plate did not sit completely flush on the -ve terminal vertical post even though how much i tightened it.
This improper connection caused the car to not start intermittently.
I removed the plate and connected the ground wires to the main factory -ve terminal connector with its factory grd wire and now every works great!!
By the way - the grounding kit does really work.
My car is smoother in idle and there is a definite greater pull taking off from the line
Old 05-09-2006, 11:41 AM   #12
Plays_With_toys
Member#: 82556
1996 Legacy L wagon
Glad you got it working! I'd keep the factory connections no matter what anyway. They are a very thick cable, much thicker than most any of those aftermarket ground kits, the other wires are more of a boost than anything.
aloha ppls of the brutal OT my phone battery is dead so here I am shaggadelic Off-Topic 37 11-06-2008 04:31 PM
Subaru battery is dead after 2 weeks!!! BBBsti LTD Electrical & Lighting 17 08-03-2008 11:48 AM
effin battery is dead... PhilDis Off-Topic 18 01-14-2008 11:45 PM
Whoops, factory battery is dead Imprezme05 South West Impreza Club Forum -- SWIC 13 12-18-2006 01:51 PM
Question How to install grounding kit? sti-bullet Vancouver Impreza Club Forum -- VIC 4 03-24-2006 01:28 PM
