Old 10-08-2001, 08:12 PM   #1
barkall4
Member#: 6524
2001 GC6
Smile Mechanical Vs Electrical...
Hey guys...I just got my gauge pod and mask back from Derres Catalano...and although I need a new pod now due to some shipping problems...(USPS decided my box would work better as a soccer ball...so my pod is busted... that will only take a week or so get rectified)...I will be ordering some gauges. Now I've narrowed down some pretty good combo's to go with, what do you think?
1. Oil Temp, EGT, Vac
2. Oil Temp, Oil Press, EGT
3. Oil Press, EGT, Volts
4. Oil Temp, Water Temp, EGT
And most important, I'm not sure at all what to go with...MECHANICAL or ELECTRICAL?? Any Opinions would be EXTREMELY helpful!
Now, once I go turbo (coming very soon ), I'll mount the boost, A/F, and whatever on the Triple-Guage A-Pillar replacement that's in R & D right now.
Thanks,
Steve
p.s. If anyone thinks of a better combo of any of these, or unlisted gauges, please let me know.
barkall4 is offline   Reply With Quote
Old 10-08-2001, 09:59 PM   #2
kaos200
Member#: 2692
5) Water Temp, Oil Pressure, EGT
unless you know that you are going to engine management later that should display Water Temp. SO get oil temp in that case
HOWEVER
some gauges the oil/water temp gauges are one and the same, like GReddy
oh yeah...
ELECTRICAL!!
kaos200 is offline   Reply With Quote
Old 10-08-2001, 10:37 PM   #3
barkall4
Member#: 6524
2001 GC6
Talking Very valid point
Yeah I'm pretty positive I'll be going engine management a few months after the Turbo Install...unless the turbo install neccessitates the Eng Mgmnt.
Thanks Kaos!
Old 10-08-2001, 11:52 PM   #4
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
I myself am doing the same thing..you are ...shopping for gauges for Derres's Gauge housing..But I would suggest the following..
First off your RS already has a Water Temp Gauge...and a Volt meter is unnessary (I believe)
So My suggestion is the following Gauges
EGT, Fuel Pressure, and Oil Temp or Pressure...All of which Give you vital info on your Engine.. Oh yeah..unless you race professionally...Electrical gauges are the ticket....
Boost on Brother..
Old 10-09-2001, 01:52 AM   #5
barkall4
Member#: 6524
2001 GC6
Thumbs up That's the ticket!
Derres' setup is BEAUTIFUL! Too bad my pod was destroyed during shipping and today was COLUMBUS DAY! Who the he** decided this!!! I was totally unaware of this until I got the post office to see if the insurance would cover the damaged pod......and they were CLOSED!
Anyways, yeah I'm gonna probably just cover EGT, Oil Press, and Vac...unless I get that Oil Cooler which I would then go Oil Temp first.....but when I go turbo, I'll worry more about the Oil Temp, Boost, etc... and probably have a gauge for just about everything that can be monitored.
Also, I just emailed the guys at Auto Meter directly and a guy named Zach replied to my question about the Lunar Series, stating they will debut after the SEMA show at the end of this month.....so I'll wait to then to see the prices before I go with Apex-i or Defi. Their prices are INSANE!
Oh well..thanks guys,
Steve
Old 10-09-2001, 05:21 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
elelctrical for everything except boost, i have found mechanical to be the most reliable for vacuum/pressure but as far as ther others i am NOT one for running OIL pressure into my dash.
Jeremy
Old 10-09-2001, 12:46 PM   #7
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
Boost, Oil Pressure, EGT and A/F is what I run.
Boost- Mechanical
Oil Psi, EGT and A/F- electrical
EGT-VDO Cockpit series with Westech probe
Boost & Oil Psi are Autometer Phantom
A/F is J&S safe gaurd dual monitor
STiShawn is offline   Reply With Quote
Old 10-09-2001, 12:57 PM   #8
iodine23
Member#: 4071
2001 Impreza 2.5RS
Blue Ridge Pearl
That's why you use a pressure isolator so you're not running the fluids into your car. Autometer makes an isolator that is for all mechanical gauges and is rated up to like 200psi. It's safe for most pressurized stuff except nitrous.
Check under the accessories section of their web page, you should find it buried down at the bottom of one of those pages.
iodine23 is offline   Reply With Quote
Old 10-09-2001, 02:30 PM   #9
barkall4
Member#: 6524
2001 GC6
Default ok..so..
everything electrical but boost...makes sense...
So I'm set on EGT, Oil Press, and Vac....all electrical...probably will go with the Autometer Carbon Fiber Ultra Lite Series or the Lunar Series, should the timing permit. I was so set on going all Defi, or Apex-i until I priced it all out...and i'll be spending over $1,000 in just indiglo gauges! I'm like ***!!! Is there anyone who makes it cheaper for me??? I am hoping autometer will
Thanks guys, much appreciated
Mechanical vs. Electrical Boost Gage CWasko36 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 09-06-2002 03:25 PM
Mechanical Vs. Electrical Boost Gauge erice1984 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 07-26-2002 08:58 AM
Mechanical vs. Electrical Gauges mastervic27 Normally Aspirated with bolt-on Forced Induction Powertrain 3 03-28-2002 10:53 AM
Oil pressure gauge, mechanical vs. electrical vleeco General Community 6 02-28-2002 02:50 AM
Mechanical vs Electrical gauge. viodea Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 10-04-2001 04:32 PM
