Old 06-11-2001, 04:13 PM   #1
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Post Did 95-99 Legacy GTs have a single-stage brake booster?
I want my Rex to feel like my GT's brakes. It feels really good right now, but isn't quite up to Old '98 in terms of pedal feel.
I know that the GTs had two-piston front calipers, just like Rex. I put stainless lines, KVR rotors and CF pads on that car.
Hence, the question. Did our cars have a single-stage booster, or did I just have a particularly good-feeling example?
Kevin
gtguy is offline   Reply With Quote
Old 06-11-2001, 04:59 PM   #2
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Post
Unfortunately, our GT's don't have the single stage booster
GTBGUY is offline   Reply With Quote
Old 06-11-2001, 07:57 PM   #3
gtguy
Member#: 2184
Post
That's good news, GTB. That means the same sorts of mods will work the same improvements on pedal feel.
Kevin
Old 06-12-2001, 09:43 AM   #4
GTBGUY
Member#: 2003
'99 BGP Legacy GT
Post
gtguy - Yup, that's right... get a set of stainless lines, use some good brake fluid, upgrade to x-drilled stock size rotors and run those KVR CF pads, and your brakes will be equally as good as the ones on the GT or even better on your WRX.
BTW, did you notice that the clutch pedel on the WRX doesn't have much feedback? Feels too soft!
Old 06-12-2001, 10:34 AM   #5
Ottawa
Guest
Member#:
Post
And don't forget the Cross Drilled Brake Lines from www.kalecoauto.com, only $150 for a set of 4:
"Want improved braking? Why just cross drill those rotors? Introducing KaleCo cross drilled brake lines! Improved airflow through lines provides superior brake cooling. Brake fluid is exposed to cool moving air, almost instantly reducing heat, and providing shorter stopping distances! All lines are made of quality latex. Brake lines come in: Black, Yellow, Red, or Blue. Please specify color when ordering!! Warning!! You must replace ALL brake lines at once as to prevent mismatched pressure feedbacks! You may mix colors."
[ June 12, 2001: Message edited by: Ottawa ]
Old 06-12-2001, 10:43 AM   #6
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
Post
Hahahaha!!! LMAO!!! That's good stuff, Ottawa!
Pat Olsen
'97 Legacy 2.5GT sedan
Stopping just fine with plain rotors, thanks.
Old 06-12-2001, 11:42 AM   #7
gtguy
Member#: 2184
Post
I won't upgrade the rotors, but the lines, fluid and pads, definitely. Should be great. The rotors are plenty big, and plenty fine.
My clutch pedal is pretty smooth, but it is a very "soft" takeup. I have the feel for it pretty well, though.
Kevin
NYC: Single stage brake booster -- look up the 'stiff brake pedal' mod jamesfacts Suspension/Brakes/Handling 4 01-12-2010 09:15 AM
$60 single stage brake booster GC8 and brake MC $50 supermoose Private 'For Sale' Classifieds 3 09-01-2005 02:58 PM
single stage brake booster GC8 and brake MC supermoose Private 'For Sale' Classifieds 9 06-28-2005 06:40 PM
99-01 RS Single stage brake booster and pump Leonardo Private 'For Sale' Classifieds 15 11-29-2003 08:46 PM
Anyone have the part number for the single stage brake booster? bill harvey Brakes, Steering & Suspension 5 04-26-2001 01:35 PM
