Old 05-24-2002, 04:54 PM   #1
edkwon
Member#: 453
2014 Audi S4 B8
2016 Porsche Cayman GTS
Default Upgrading front brakes alone - throw off brake balance?
I'm thinking of upgrading my brakes to the Sti 4 pot/2pot sets but I've heard from some ppl that upgrading the rear brakes is kind of a waste since braking transfers most of the weight to the front wheels and brakes anyway and its not worth spending the extra money on the rears? Is this true or will it throw off the brake balance and affect handling?
Ed
edkwon is online now   Reply With Quote
Old 05-24-2002, 05:54 PM   #2
JMFInkel
Member#: 14916
1999 Impreza 2.5 RS
Rally Blue Pearl
Hi, Ed.
I have the STi 4-pots and 11.6 inch rotors up front with the stock brakes and rotors at the other end (plus stainless lines all around). I haven't decided yet if the brake balance has been adversely affected.
Here's an option for you (one that I'm seriously considering, too) is to put on larger rear rotors. There's been a lot of talk lately about using the Legacy H6's larger rear rotors and caliper mounting brackets. I don't have the part numbers for you, but they're around here somewhere. I think it's only a couple hundred bucks for both rotors and brackets.
Hope that helped.
Jon
JMFInkel is offline   Reply With Quote
Old 05-24-2002, 06:52 PM   #3
romanom
Member#: 16215
2002 WR WRX wagon
Default Re: Upgrading front brakes alone - throw off brake balance?
Ed
Don't worry about it either way. For cars whose wheel base is over 80" it won't be felt. Especially with such a front heavy car as the Impreza.
What you do have to worry about is OVER braking the rears and then getting lock up all the time. Where that point is depends on the car. See what others have done that works. I would think the H6 upgrade should be fine on the rear.
By the way the 4pot/2pot that use the same rotors as stock will NOT get you better objective performance. It will significantly improve feel but not stopping distance.
http://www.i-club.com/forums/showthr...hreadid=168098
http://www.i-club.com/forums/showthr...hreadid=168033
http://www.i-club.com/forums/showthr...hreadid=159647
romanom is offline   Reply With Quote
Old 05-25-2002, 12:43 AM   #4
Yebisu69
Member#: 11989
2006 LegacyGT LTD
Brilliant Metallic Silver
Default Re: Re: Upgrading front brakes alone - throw off brake balance?
Hey Romanom,
I respect your brake knowledge. But I think you are crusading against multi-piston brake calipers without a whole lot of objective empirical data. I understand the brakes are systematic and as such upgrades must be systematic for it to balanced system.
I've had the RS stock 10.7" front rotors w/ a 2-pot calipers and I was fading them on the NYC highways. Panic stop distances were not as short as I would have like it.
So, I upgraded the fronts to OEM WRX 11.4 front rotors and the STi 4-pot caliper. I also got Goodrich Stainless Steel brakelines and ATE Gold DOT 3-4 fluid.
I can tell you for a fact, the car stops much better than it used to. I also had opportunity to engage the new brake system in panic stops and it was a lot shorter then before.
Also, the 2 pot rear set up uses an 11.4 rotor as opposed to the 10.3 stock rotor.
edkwon,
The front sti 4-pots will upset the balance of the braking system a bit. Torque oversteer on command with just the fronts as well as a little bit of dive. I am thinking about doing the rears to balance it out a little, but the rears are expensive.
If you can do both the front and rear at the same time, I don't think you will be disappointed.
Also, if you read Romanom's thread about braking, he emphasizes balance in the brake system. So, subaru developed this braking system for this model car and its' internal brake mechanics.
I think there is something to be said about leveraging all the research and design efforts that Subaru has already done when developing there performance products.
The popular concensus is to get new rotors, pads, steel brakelines, and fluid instead of 4-pots calipers.
I suggest doing the 4-pots with new pads, steel brakelines and fluid.
Yebisu69 is offline   Reply With Quote
Old 05-25-2002, 06:33 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
So why do ALL other markets get 'BETTER' brakes?
EDIT: I have the 4-pot fronts, w/ss lines and Syn fluid. MUCH better than stock...I want the 2-pot rears w/ larger, vented rotors for better balance.
Old 05-25-2002, 06:46 AM   #6
romanom
Member#: 16215
2002 WR WRX wagon
Default Re: Re: Re: Upgrading front brakes alone - throw off brake balance?
Originally posted by Yebisu69
Hey Romanom,
You went from a 10.7 to a 11.4 of course your getting better performance. The problem is many are just changing calipers and expecting to get better performance.
If you use a larger rotor that WILL help, period. That's why I said "if you use the stock rotors."
The front rear balance of brakes is not a completely direct system. You do not design the rears to match the front. You design them to brake the rears. With cars that have a long wheel base they're too far apart to look at them as a single system. You must look at them separately.
Old 09-30-2008, 01:22 AM   #7
bbarker1
Member#: 158206
06 WRX
This might be off topic, but i'm on a quest for knowledge. Even with a short wheel base, how would the affect that braking ability? When 'Above 80 inches' was mentioned, my mind wandered to my bike, err, heap of scrap metal i mean.
I know it's not a motorcycle forum, but I'm just curious about the physics of the whole balance of braking delima, so maybe if you would like PM me or something, that would be awsome, cause i dont wanna get you in trouble!
Thanks,
Brett
bbarker1 is offline   Reply With Quote
Old 09-30-2008, 01:54 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
i ended up doing the 'h6' rears on my bugeye
best damn mod i did to that car other than springs
Old 09-30-2008, 10:43 AM   #9
Davidwrx
Member#: 141028
2002 WRX Wagon
What was the improvement felt with this mod. I have a hard time justifying it in my mind.
Davidwrx is offline   Reply With Quote
Old 09-30-2008, 12:52 PM   #10
watchunglava
Member#: 168862
2007 ej253n/a 5speed
Red Sox Nation Lifer
Default abs
locking up the rears with abs???? really?
watchunglava is offline   Reply With Quote
Old 09-30-2008, 01:54 PM   #11
LoLoHax
Member#: 151648
2005 WRX Wagon
Another very good option is to get a higher friction pad in the rear.
ex. HPS up front, HP+ out back.
LoLoHax is offline   Reply With Quote
Throwing Off Brake Bias? kwan_1104 Brakes, Steering & Suspension 11 08-07-2009 11:46 AM
upgrade stock 06 brakes vs. sti stock brakes sonycrr Brakes, Steering & Suspension 8 01-23-2007 08:54 AM
(Please help) Brake pads or entire brake system upgrade? Jay04WRX Brakes, Steering & Suspension 8 10-30-2005 08:59 PM
Upgrade front brakes on your GC 2.5RS! Mach V Dan Suspension/Brakes/Handling 3 04-04-2005 06:01 PM
Problem with STI brakes, car brakes alone. Alfaneggio Brakes, Steering & Suspension 0 02-09-2005 01:23 PM
