Old 05-25-2002, 09:33 AM   #1
Benjamin Tang
Member#: 4496
2009 Forester
red
Default confusion with oem subaru 4-piston front calipers
some people have told me that the stock usdm wrx rotors work with these calipers, but others have said u need the larger jdm rotors to work.... who is correct?
Benjamin Tang is offline   Reply With Quote
Old 05-25-2002, 10:02 AM   #2
Peaty
Techno Sapien
Member#: 449
2016 BRZ Limited
Ice Silver Metallic
Stock WRX rotors and the ones that come with the kit are exactly the same.
Look here:
http://www.scoobymods.com/forums/sh...tid=640#post640
There is a how to I did.
Peaty
Peaty is offline   Reply With Quote
Old 05-25-2002, 11:15 AM   #3
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
The pre-01 JDM rotors are the same size. As are the WRX rotors elsewhere in the world currently. The only larger-sized rotors are the new Brembo ones. The 4-pots fit fine with our stock rotors.
Old 05-25-2002, 12:20 PM   #4
WagonMonster
Member#: 3781
2002 Legacy GT Wagon
2009 Forester X Limited
I have the Subaru 4-Pot Calipers and I am using my stock rotors
WagonMonster™
WagonMonster is offline   Reply With Quote
Old 05-25-2002, 11:25 PM   #5
etam
Member#: 439
www
same size: 294x24mm
etam is offline   Reply With Quote
Old 05-26-2002, 11:13 AM   #6
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
I have said this many times before, and rechecked many times, but when I got the full kit (rotors and calipers) for my old RS, the rotors that came with that kit were 298mm, not 294mm. Not a big difference, but true.
Old 05-28-2002, 09:08 AM   #7
etam
Member#: 439
www
Old 06-04-2002, 11:53 PM   #8
Ken Levin
Member#: 1416
2/01 WRX SportWagon
Question
Is there a rotor available for the US WRX (front) larger than OEM that will fit with the Subaru 4-pot calipers?
Looks like the Brembo is too wide.
Thanks and Happy Motoring
Ken Levin is offline   Reply With Quote
Old 06-05-2002, 03:04 AM   #9
TerenceT
Member#: 9510
04 FX35
Pearl White
anything bigger in diameter would need a bracket
supposely, the Uk 4 pot comes with the larger bracket and uses a slighly larger rotor
TerenceT is offline   Reply With Quote
Old 06-05-2002, 09:35 AM   #10
etam
Member#: 439
www
I have UK 4pots/rotors and don't need any bracket. Still need to pull out the UK rotor to compare with US WRX rotor. I wouldn't surprise that they are the same size.
Old 06-05-2002, 08:29 PM   #11
Ken Levin
Member#: 1416
2/01 WRX SportWagon
IIRC the UK and the 02 WRX (US spec) front rotors are the same or within 2 - 4 mm.
Any other possibilities? I guess the width of the caliper is the big limiting factor.
Old 06-06-2002, 05:40 AM   #12
DBAsteve
Member#: 16839
The Genuine Subaru is 294mm x 24mm.
The 4 piston Subaru caliper will not fit a larger rotor without modification of the rotor clearance radius in the caliper body.
Not recommended !
Larger rotors should increase in thickness proportional to the diameter for stabillity.
294mm = 24mm
305mm = 26-28mm
330mm = 28-32mm
343-355mm =32mm
362mm = 32-34mm
381mm = 35mm
DBAsteve is offline   Reply With Quote
Old 06-06-2002, 08:50 PM   #13
Ken Levin
Member#: 1416
2/01 WRX SportWagon
Thumbs up
That's what I suspected. Bigger rotor = bigger caliper.
Happy Motoring!
Old 06-16-2002, 12:24 PM   #14
Benjamin Tang
Member#: 4496
2009 Forester
red
not wanting to add to the confusion but...
these came from a 22b. will they work on my gga wrx wagon? what will i need to make the rears work, besides rotors?
Old 06-16-2002, 02:00 PM   #15
jagcars26
Member#: 2394
2005 Legacy GT wagon
2009 Forester X
Godamn! those are some sweet pics,,where did you get those??
Rudy<<drooling
jagcars26 is offline   Reply With Quote
Old 06-16-2002, 03:40 PM   #16
Benjamin Tang
Member#: 4496
2009 Forester
red
yahoo japan auction site. my friend overseas keeps sending me this stuff to remind me what we are missing out. it's going for 90,000jpy. not sure how complete it is though, hence the question.
Old 06-16-2002, 04:13 PM   #17
DBAsteve
Member#: 16839
A Car !
Old 06-16-2002, 07:46 PM   #18
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
There is a user sti-wrx that has installed them. You need to remove the rear dust shield but from what I've seen of his install everything else fits. Teague's auto sells a rear setup with DBA rotors that includes new dust shields I believe, and that fits as well. There was alot of speculation of having to swap hubs and the parking brake no longer working, but I'm not sure that's the case.
Old 06-16-2002, 08:53 PM   #19
DBAsteve
Member#: 16839
This is the rear kit.
http://www.isrperformance.com/wrxbrakes.html
Take out what you don't need.
Regards
Steve
Old 06-16-2002, 09:28 PM   #20
Benjamin Tang
Member#: 4496
2009 Forester
red
thanks for the info! i have absolutely no luck with the search option on this site
Old 06-16-2002, 09:58 PM   #21
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Wow! That is a great deal. I would buy them if the shipping wouldnt cost an extra 100$ dollars.
Old 06-17-2002, 12:38 AM   #22
Benjamin Tang
Member#: 4496
2009 Forester
red
well, i'm not sure if the price is right because there are no front pads or rear rotors included in the price? but it does have those goodridge lines and new rear pads...
Old 07-15-2002, 07:51 PM   #23
subysouth
Member#: 5039
2007 Outback XT
Grey 5-speed
Default I was looking for something else
But Ben you got an excellent deal but I imagine you know that by now.
subysouth is offline   Reply With Quote
Old 07-15-2002, 11:19 PM   #24
Benjamin Tang
Member#: 4496
2009 Forester
red
i ended up not getting them because shipping was really expensive
however my friend in japan has a colleague that had his ver.4 RA totalled by a little old lady that crossed the center line... just waiting for the insurance company to write it off so i can buy it from him
Old 07-13-2006, 01:36 AM   #25
allday789
Member#: 95511
2005 WRX
where can i find the oem 4-pots
allday789 is offline   Reply With Quote
FS JDM 4 piston front calipers Kamikaze03084 Suspension/Brakes/Handling 2 08-20-2008 01:33 PM
Wilwood 4 piston front calipers moktod Suspension/Brakes/Handling 20 12-03-2006 01:31 AM
FS: PERRIN 4 piston front calipers elmer20 Suspension/Brakes/Handling 11 09-01-2006 04:53 PM
FS Subaru 4 pot front calipers car39 NESIC Private Classifieds 5 02-09-2006 05:01 PM
