Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 01-30-2003, 01:40 AM   #1
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Default Spring diameters, how about a single resource
Id like to compile a list of all the different spring diameters used. This would help when people have qestions of part interchanges.
I know many of you upgraded and have stock parts laying around. Help your fellow club members out
Make sure you check the upper and lower diameter and note the year of the vehicle (subaru has made in model changes before).
If a source already exists like this I wasnt aware. I know some of the data can be found in the forums so Ill start looking around to see if I can find it,
Old 01-30-2003, 03:20 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
Wow, great response guys
Anyways 92-94 AWD legacy have
Front spring 6 5/8 inch diameter on one side and 6 1/8 diameter on the other
Rear has 6 3/4 diameter on both sides.
The 89-91 AWD worldwide models have the same front and rears
The 89-91 AWD US models have same fronts BUT 5 3/4 upper diameter 6 3/4 lower diameter rears.
I know that the lower diameter for the springs hasnt change from at least 90-99 on all models of Impreza/Legacy/Forrester but upper diameters may have.
Old 01-30-2003, 08:39 PM   #3
Draken
Member#: 16
1968 Saab
Sonett II V4
Simply having the outside diameter of the spring isn't very useful, unless you can also include the free length, number of active coils, wire diameter. This will let you calculate the spring rate.
With this information, you could then decide what springs would be a good upgrade for a certain car. for example:
Model 1 has springs that are 10 inches long (free length) and a rate of 150 lbs/in.
Model 2 has springs that are 9 inches long (free length) and a rate of 170 lbs/in.
A person could then calculate how Model 2 springs would change the ride height of their Model 1 car.
Just a thought.
Chris H.
Draken is offline   Reply With Quote
Old 01-30-2003, 08:46 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
My point is not intended for spring interchanges but rather the application of items like struts and strut tops. Spring rates and uncompressed height is data that can be provided by the manufacturer of the aftermarket items you would use in the "kit."
Old 01-30-2003, 10:51 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
Okay, when does this become apart of the sticky FAQ and Threads of Note- Read me first! ?!
TADA! The numbers you see are example whiteline part numbers that have the correct weight from http://www.whiteline.com.au/docs/cat..._ED3a_full.PDF
rear 93-00 impreza -------------------- 80067a top=125mm bottom=141mm
Rear 93-00 Impreza, longer spr--------- 70384 top=125mm bottom=141mm
Seems that some cars have different rear mounts and hardware so they need the second longer spring to prevent sagging.
rear 89-94 legacy bc-T bf-NA-T ------- 70369 top=125mm bottom=141mm
Above is the normal spring
rear 89-94 legacy BC-NA--------------- 70368 top=95mm bottom=138mm
This spring is the weirdo, it seems that in the US MANY 4wd wagons and sedans got this spring.
rear 95-99 legacy BD sedan------------ 70381 top=134mm bottom=134mm
Rear 95-99 Legacy BG wagon ---------- 70385 top=134mm bottom=134mm
Rear 99+ Legacy BE sedan ------------- 73172 top=78mm bottom=82mm
Rear 99+ Legacy BH Wagon ------------ 73171 top=78mm bottom=82mm
Rear 00+ Impreza GD Sedan ----------- 83158 top=130mm bottom=130mm
Rear 00+ Impreza GH Wagon ----------- 83162 top=130mm bottom=130mm
Rear 00+ Outback --------------------- 73171 top=78mm bottom=82mm
Fronts:
Front 99+ Legacy BE BH (check) -------- 73170 top=124mm bottom=148mm
Front 89-00 Legacy ALL (99+ check) ---- 70198 top=146mm bottom=146mm
Front 93+ Impreza (all models) ---------- 80066 top=125mm bottom=148mm
Impreza, use the SAME spring from 93+ including WRX.
Front 00+ Outback --------------------- 70366 top=125mm bottom=146mm
edit: Basically if you look at it many parts like struts and strut tops can be intermingled to create a KIT for your vehicle of choice.
edit2: The bolt pattern for strut tops are the same for the different models. HOWEVER some of the parts between the spring and the body are different. A few models use a single part top in the rear while others use a 3 and even 4 part spring seat. You may end up with the right springs but different heights than expected.
Old 06-09-2003, 09:24 PM   #6
ciper
Member#: 15543
90BJ Legacy LS ABS
Looks like 04 WRX springs changed, so 02-03 WRX springs are a different size.
However 02-03 top hats will fit an 04 vehicle
http://forums.nasioc.com/forums/show...hreadid=372536
Old 04-21-2005, 02:35 PM   #7
NastyHabits
Member#: 24151
Default Spring Rate Info
Here's a much more complete chart:
RavensBlade Spring Rate Chart
NastyHabits is offline   Reply With Quote
Old 09-07-2005, 01:42 PM   #8
turboICE
Member#: 33979
2006 STi,'11 OBS
WRB & Black/Silver
Any information on the black STi Ver.9 Spec C springs? Are they the same ones listed in RavenBlade which is equivalent to USDM STi?
turboICE is offline   Reply With Quote
Old 09-07-2005, 07:15 PM   #9
davis10
Member#: 70011
do all these springs fit on regular struts or do you need coilovers (sry for the noob question)
davis10 is offline   Reply With Quote
Old 06-15-2006, 11:30 PM   #10
dome24
Member#: 111845
97 RUBAsU Tall2dr
96 Neota Tacoma 4x4
i bought 05 STI coils to put on my 97 ImpBriton with 99 legacy struts, will they work or not? the struts work right now with teh 97 coils but the 97's are shot
dome24 is offline   Reply With Quote
Old 06-25-2006, 10:05 PM   #11
Roy
Member#: 32241
1998 Impreza L Coupe
white
Please refer to my post on "05 WRX Springs Fit A 98 L Coupe".
Thanks,
Roy
Last edited by Roy; 06-25-2006 at 10:08 PM. Reason: Corrected year for WRX from 04 to 05.
Roy is offline   Reply With Quote
Old 10-07-2007, 04:02 PM   #12
soobiedoo55
Member#: 161150
2006 STi
UGM
heres a noob question for you all... will a 2007 wrx Tein S-Tech kit fit a 2007 2.5i? Im looking at a kit on ebay right now and I cant get a response from the seller so Im asking you guys. Thanks.
soobiedoo55 is offline   Reply With Quote
Old 10-08-2007, 08:27 PM   #13
wrxtool
Member#: 75589
2005 forester xt
yes, however your struts will wear quickly as a 2.5i has softer dampening than the wrx and sti.
wrxtool is offline   Reply With Quote
Old 07-08-2011, 09:37 AM   #14
Firebird2
Member#: 287495
Default 2010 WRX Spring Rates
Hi guys, can someone advise what the spring rates are on a 2010 WRX.
Cheers
Firebird2 is offline   Reply With Quote
Old 07-08-2011, 02:52 PM   #15
Back Road Runner
Member#: 60082
2004 Forester STI
Old 07-08-2011, 07:49 PM   #16
Firebird2
Member#: 287495
Thanks
STI Pink Spring Coils fit 08 WRX how about 09? wrxphantom Brakes, Steering & Suspension 6 04-03-2009 12:58 PM
How about some v7 struts with coilover springs? jetfan8178 Private 'For Sale' Classifieds 5 06-12-2006 01:21 AM
how about spring free length? Matt K Brakes, Steering & Suspension 1 04-09-2004 02:00 AM
How about a meet/drive to Wentworth Springs road (among other roads) next week? (sac) Kostamojen Bay Area Impreza Club Forum -- BAIC 25 06-20-2003 03:18 AM
How about springs? Tinkit Vancouver Impreza Club Forum -- VIC 2 02-17-2002 11:53 AM
