Old 04-05-2006, 03:32 PM   #1
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
It tastes like burning
Default EJ20G injector o-rings and spacers
EDIT:
Part numbers down below.
Hi all,
I am looking for part numbers for the replaceable injector parts. What I found pulling my injectors and rails off is more parts than are shown in the manual. On my engine I have;
Insulator doughnut that goes on the head (listed in the manual)
2 o-rings for the injector in the rail (listed in the manual)
injector cap rubber isolator (listed in the manual)
thin nylon injector to rail spacer (NOT in the manual)
plastic spacer ring (NOT in the manual)
I will take some pictures tonight. I was hoping someone could shed a light on part numbers suitable for replacement.
Thanks,
Rob
rob is offline   Reply With Quote
Old 04-05-2006, 04:02 PM   #2
tweakling
Member#: 33072
'95 EJ20g v1 STI RA
BRP, 2001 GC8 chassis
You may want to consult sixpack subaru. He's hooked up a lot of people with JDM part numbers.
tweakling is offline   Reply With Quote
Old 04-05-2006, 04:09 PM   #3
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the real question is
are there any other usdm cars that use the pintle style injectors?
i don't know ..
i made custom rails (combo of 1.8 +ej20G)
i used (93) 1.8 rail to manafold doughnuts .. which were identical to the G
Old 04-10-2006, 07:06 PM   #4
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
Here's the pic;
Can anybody identify part numbers that work for the 6 pieces? Numbers 3 and 4 are the ones I don't see in the various US service manuals.
Thanks,
Rob
Old 04-11-2006, 11:36 AM   #5
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
sorry i got nothign for you .. post this over in the pre 2002 forum
Old 04-11-2006, 12:52 PM   #6
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
So the 1.8 injectors you played with did not have the extra spacers (3 and 4)?
Old 04-11-2006, 01:02 PM   #7
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
hmmm,
I don't remember there being more than 3 o-rings on the Ej20G injectors I pulled and sent to Silvialost. You might shoot him a PM and ask him about it since I no llonger have the parts in hand. The injectors looked the same as the ones you have pictured...
Old 04-11-2006, 01:19 PM   #8
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
Old 04-16-2006, 11:05 PM   #9
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
still need some help with this.
Old 04-16-2006, 11:45 PM   #10
99WRXEJ20
Member#: 34545
1999 GC8
74f
hrmm I dont have a clue I know that some nissan injector parts are useable. NOt too sure about the ej20g ones though.
99WRXEJ20 is offline   Reply With Quote
Old 05-03-2006, 11:11 AM   #11
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
A kind fellow in Australia looked up the parts for an RS Liberty. Here they are for future reference;
1 16608aa020 Seal-fuel Injector x4
2 16698aa020 O Ring-injector x4
3 16697aa000 Ring-injector x4
4 16696aa000 Spacer-injector x4
5 16698aa010 O Ring-injector x4
6 16607aa031 Insul Fuel Inject x4
It's a little spendy for a full replacement, but injector fuel leaks are bad m'kay.
-Rob
Old 05-15-2006, 10:44 AM   #12
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
might as well keep this stuff together
http://forums.nasioc.com/forums/show....php?t=1004263
Old 12-07-2006, 10:40 AM   #13
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Got a quick question.
Im about to put STi injectors into my EJ20G using RS fuel rails, from what i can tell ill need all the listed part numbers from the top except the #6, sense this a ball style. can someone correct me?
thanks
Kirill
snowman4us is offline   Reply With Quote
Old 12-07-2006, 12:12 PM   #14
rob
n00b Moderator
Member#: 811
2000 RS-Ej20G
I wouldn't think so. I am pretty sure the ej20g injectors are the only ones that need the extra spacers. I would guess you would only need the standard o-rings that come on the STi injectors.
-Rob
Old 12-07-2006, 12:19 PM   #15
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
So would i wana use 2.5rs fuel rail to manifold O-ring, and for Inj. to fuel rail i wana use STi?
I know that there are a couple of ppl that have done this, and i just want to make sure that i get the proper parts.
Im flippin my manifold, doing STi injectors and a parallel fuel system, that im all trying to do in 5days, so i dont want to get held back becouse of wrong o-rings.
thanks
kirill
Old 12-07-2006, 01:15 PM   #16
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
rs rails ?
thats new to me
Old 12-07-2006, 02:34 PM   #17
kheff46
Member#: 66739
2002 WRX wagon
what style is an EJ20K using? and around what cc/min do they flow? i am going to check mine(may have them cleaned n blueprinted) soon and wouldlike to try and source replacement in the US first.
thanks in advance guys!
--keith
kheff46 is offline   Reply With Quote
Old 12-07-2006, 03:17 PM   #18
Matt Monson
Member#: 832
99 2.5RS, '85 911
My EJ20K is using yellow top injectors, which I believe are 440cc, just like the Ej20G greytops. I have both a '96 and '97 manifold sitting on the bench in my garage right now, and other than some changes to the larger rails to accomodate the under manifold inlet, I see no difference on the little stub rails that actually hold the injectors. Let me check tonight and I will see if the part numbers are the same...
And the only RS rails I ever heard about being used for injector upgrades were '99's that supposedly take STi pink top feeds, and were used some by RS-T guys back in the day...
Old 12-07-2006, 08:16 PM   #19
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yeah take some pictures ... it would be awesome if the stis fit the K rails
Old 12-07-2006, 08:59 PM   #20
oldhat
Member#: 113036
I thought the EJ20G greys were 380cc. Is that only on the older models?
oldhat is offline   Reply With Quote
Old 12-07-2006, 09:46 PM   #21
scoobydorift
Member#: 43128
92 RWD, 96 FWD
05 AWD
I checked today and the USDM STi yellow tops WILL fit the 98RS fuel rails.
Thanks
Kirill(snowman4us)
scoobydorift is offline   Reply With Quote
Old 12-07-2006, 10:43 PM   #22
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
ah 98rs
greys are 440s tested by at least 3 sources that i know of
legayc SS pinks are 380(ish)
Wrx Top Feed Injector O-rings And 06 Sti Bumper c'dalerider Private 'Wanted' Classifieds 0 11-06-2009 11:38 AM
Wtb: ej20G heads w/ intake and cam gears fuel injectors etc 91turbosedaan Private 'Wanted' Classifieds 1 01-07-2009 11:33 AM
FS/FT Injector O-rings and BOV Gasket. NEW Rexwagon03 Engine/Power/Exhaust 10 01-05-2009 06:54 AM
stock wrx parts, turbo,IC,injectors, ring and pinion gotti Private 'For Sale' Classifieds 17 01-31-2006 11:04 AM
legacy injectors, 3.9 ring and pinion gotawd Private 'Wanted' Classifieds 2 05-04-2005 04:21 PM
