Old 02-06-2020, 09:14 AM   #20
Mach V Dan
Member#: 12029
Originally Posted by LesGubmit View Post
Threw P007 (‘15 WRX) just after filling up gas tank. Dealer provided me an estimate for replacing both TGVs and gaskets for $1297. Said only one “bank” was bad, but recommended replacing both. I am a noob and only moderately mechanically inclined so any simple DYI options or less expensive professional help ideas would be much appreciated.
The TGVs on the 2015+ WRX are very easy to access. I certainly would only replace the problem valve. TGV deletes are also a popular high-performance modification, and cost a lot less, although ECU tuning is required if you do that.
Contact us at the shop for more information. (571) 434-8333.
--Dan
Mach V
FastWRX.com
Mach V Dan is online now   Reply With Quote
