Old 03-23-2015, 11:32 AM   #1
02rusWRX
Member Sales Rating: (23)
Member#: 99334
2006 Baja
Default (CO) HID Retrofitted Headlights, 00-04 Legacy/Outback/Baja
SOLD!
Custom retrofitted headlights for 00-04 Legacy, Outback or 03-06 Baja. Started off with OEM Legacy single bulb headlight housings. Orange reflectors removed, housings painted satin black, modified to fit FX-R bixenon projectors with satin black shrouds. Sealed back up using OEM sealant, so no condensation or leaks. Using Phillips 4300K D2S bulbs, Matsu****a ballasts and a custom wiring harness that pulls power straight from the battery via a relay and its own fuse for reliability and safety. Uses stock 3 pin connector for plug n play install. Only problem is that drivers side light won't go into hibeam mode. I think the solenoid that activates the shield is bad but not certain. Asking $450 obo. shipped. Less if picked up in Denver, CO.
02rusWRX is offline   Reply With Quote
