Old 09-09-2011, 02:03 PM   #6
Mach V Dan
Member#: 12029
95 Impreza factory option
Offset: +55
Bolt pattern: 5x100
Weight: 14.5 - 15 lbs. each.
OEM-equipped tire size: 205/55R15
2006-07 Impreza 2.5i
Offset: +55
Bolt pattern: 5x100
Weight: 17.7 lbs. (estimated - see post #212)
OEM-equipped tire size: 205/55R16
1996-1998 JDM Legacy Twin Turbo GT-B Wagon (BG chassis) and TS-R Sedan (BD chassis)
Offset: +53
Bolt Pattern: 5x100
Wheel Weight: 17.8 lbs
OEM-equipped tire size: 215/45R17
2013 Legacy
Offset: +48
Bolt Pattern: 5x100
Wheel Weight: ?
OEM-equipped tire size: 215/50-17
2015 WRX
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: 23.2 lbs (Post 428)
OEM-equipped tire size: 235/45-17
2018 WRX
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: 24.46 lbs (Post 489)
OEM-equipped tire size: 245/40-18
Does NOT clear Brembos.
2015 STI BBS
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: 22.1 lbs (forged)
Available in silver, gold, and gloss black.
2015 STI Non-BBS (Enkei)
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: 24.25 lbs
2016+ Factory-option Sport Package STI Wheel (Enkei)
Offset: +55
Bolt Pattern: 5x114
Wheel Weight: 22.2 lbs
The wheel above is also available in a 17" size for BRZ (7.5" width) and Forester (7" width)
Size: 17x7" (Forester fitment)
Offset: +48
Bolt Pattern: 5x100
Wheel Weight: 18.2 lbs (post 465)
OEM-equipped tire size: 225/55R17
Mach V Dan is offline   Reply With Quote
