Old 07-24-2017, 06:39 PM   #4
EJ_Enthusiast
Member#: 341058
If you turn the ignition switch to the ON position and measure the voltage between ECM and a chassis ground. The connector on the ECM to test would be (B134) Number 13 (I believe that's the pin) and a chassis ground.
EJ_Enthusiast is offline   Reply With Quote
