Originally Posted by maperformance
Wow. Good catch. Those numbers are backwards as a matter of fact. Going to fix that now!
Ian,
Was the dyno chart ever corrected? The Stage 1 OTS without filter showed a max power of 267.98 with 294.87 tq using 93 octane. Per this dyno with the filter, the max power would appear to be under 250. Is this correct?
I know the chart says it was using 91 octane but per your post, it says 93, which is correct?
Basically, I am looking for a dyno chart with the stage 1+ that shows improvement over the just the stage 1 using the stock filter & 93 octane. I see that this question was already asked but I wanted to follow up.
