Old 04-30-2012, 09:08 PM   #17
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Originally Posted by Porkchop-WRX View Post
Back in 2010 when I had my 03 WRX i went to DMV in Edison in with NO cats and had no problem passing. I don't know if something has changed since then but in your case you may get stuck putting on the stock downpipe to be able to pass.
When you get home swap it back. Its more work but it will get you a valid sticker.
I'd be all over that if I wasn't rotated with a pe5857. I'd have to change the whole exhaust system and reinstall the coolent resivoir, turbo inlet, and all that other stuff. the cost in gaskets alone would make it worthwhile to pay somone off
Bad Noodle is offline   Reply With Quote
